Question about Yamaha Audio Players & Recorders
My amp cuts off every time I turn it on.. even with n without the wires connected!!!! N if I do cut it on the volume is on -7 n cuts off automatically n won't come back on unless I replug n plug it up again but it does the same thing... pls help
  • mshon3yb33_l Apr 11, 2011
    Thank you soooo much for answerin me :/... wat does the protect light looks like
    WAT DOES THE "PROTECT" LIGHT LOOK LIKES.......
    Scholar:
  • 83 Answers
Does the "protect" light turn's on when it shuts off? If it does then theres a problem with your wiring or worse this might be a Thermal Protect. The amp shuts off because its lacking of voltage from your battery & alternator. Post your system so i could help you further.
Posted on Apr 11, 2011
  • 1 more comment
  • tom 11 Apr 28, 2011
    I have the same problem with the Yamaha RX396. I cleaned everything. I put the mother board out and checked for short circuits. Nothing. Still the receiver turns off after some time (between 1 hour or even immediately), even if the speakers are not connected. Where is the thermal protection circuit? I see a circuit attached to the cooling metal fins, but the circuit is looking fine. Could the mechanical relay be damaged due to the softening of the spring? Do you have a circuit plan?
  • daomingsu69 Apr 28, 2011
    my rx v440 i dissconect all the speakers and when i push d power its on after 3 sec... its turn off by its self... i need help
  • Rik D May 20, 2012
    my rx-v640 does the same.
Why does stereo amp cut out at higher volume
You seem to have the answers to your question. I would just resolder the connections anyway without checking. If it solves the problem you have saved yourself a lot of money. If it doesn't follow the other steps in order of cheapness!
May 03, 2013 | Audio Players & Recorders
Subs cut in and out
The amplifier may be going into protect mode (even briefly) because you are driving them too hard. Back off on the volume and see whether the problem goes away.
Mar 11, 2017 | Alpine MRP-M1000 Car Audio Amplifier
I have a power acoustik ibm12000d amp had it installed to weeks ago wired at one ohm to a 15inch acoustik p3 sub worked good for to weeks hit good and everything but now its cutting off when turned up I...
Sounds like an over current condition. Your sub may be the problem. Does it go into protect mode when it cuts out? remove the sub and turn up the volume and see if it cuts out when you keep increasing the volume. If not, then it may be that the sub shorts out when turned up too much, kicking the amp into protect mode. If it still cuts out, then it may be the amp. Try another sub if you have one or borrow one from a friend.
Aug 06, 2011 | Power Acoustik OVN1-2000D 1-Channel Car...
My subwoofer doesn't receive power, all amp fuses are fine, amp powers on, remote wire and rca wires are connected and intact. Before it stopped working all together the woofer would cut out and after...
If you are getting power to the amp, try this....Find a small speaker, unhook your sub and wire speaker to amp. Turn on your system at a low volume....If the other speaker is playing through amp, then your sub is shot.....If the small speaker doesnt work, then its either your channel is gone on the amp or the rcas have quit off off your head unit.
Oct 07, 2010 | Kenwood eXcelon X1200M Car Amp
RADIO CUTS OFF WHEN VOLUME IS TURNED UP
It could be your wiring as well. Sometimes, when speaker wire gets cut and grounded, like your factory wiring to your door speakers or you tap into facrotry speaker wires to add more, the load on your deck increases. When the volume gets to a certain level, it will cut off because of the heat produced to maintain the load.
Feb 23, 2010 | Pioneer DEH-P4000UB CD Player
Subwoofer Turns Off when volume is turned up
check your earth from the amp i had same prob and the vibration broke earth connection once secured it was fine
Aug 24, 2009 | Pioneer TS-SWX310 Car Subwoofer
Stops playing if i turn im up louder if i restart than he plays and wen i turn up the volume everything stps even the licht goes out
Disconnect speakers and test. Crank up the volume and see if it still cuts out. Then re connect one speaker at a time and test. if it cuts out, check for a short in a speaker wire or a bad speaker (blown or shorted coil) Hope this helps
Aug 08, 2009 | Lightning Audio S2.500 2CH 500W Amplifier...
Receiver won't turn on
Disconnect all the speaker wires, then turn the unit on. If it does not power on and the standby light is "out" pop the top and check the internal fuse by the power cord. Beyond that, without the proper testing equipment, it's all a guess. If the unit turns back on with all the wires disconnected, then reconnect your speaker wires one by one and test each time. If it does not cut out, you found the problem. Wire touching. If it cuts out, disconnect wire at the speaker and re test, if it still cuts out, replace the wire and try again. Then re connect the same speaker to the new wire and test. If your lucky, all will be well. If not, it will need to be serviced or replaced, based on cost. Hope this helps
Jun 29, 2009 | Sony STR-DE310
Volume turned up, kenwood shuts off briefly...
does it keep cutting in and out?
if so i think you have your polarities crossed
make sure you have negative to negative positive to positive
Jan 27, 2009 | Kenwood KDC-X692 Car CD/ MP3 Player
SUBS
Hi , you need to replace with thick wire , if possible attache fuse or circuit trip overload protection you may ask to thew radio store .
May 07, 2008 | Polk Audio EX12 Car Speaker
960 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
