The ac adapter pin has snapped of the housing on my laptop.
    Genius:
  • 1,325 Answers
Hi
is the housing from the mainboard (computer) still in tact, or is it loose ? if its in tact, without it being loose, you can simply replace the AC adapter . If the power connection on the mainboard is loose, the repair center can de-solder it and try to re-solder it back . it should not be a big deal, unless it is severely physically damaged.
you will have to bring it to an authorized (respective : ie, HP IBM, dell) computer notebook repair center.
thanks for using FIXYA
Posted on Apr 11, 2011
The charge dock on tablet broke so we can not charge tablet can it be fixed? We just got it this October.
Juello. Did some research on your tablet at Amazon, (http://amzn.to/1xWx6S5) and see that they also have an AC charger (AC charger adapter with a 3.5mm power jack and delivering 5VDC 2A). Available for $5: iRulu Black AC Home Wall Adapter Cable Charger for Tablet PC 5V 2000mAh or a there's a nice replacement KB and cover: iRulu New Portable 10 1 10 5 Android Tablet USB Keyboard Case Black . I would guess the connector snapped off inside the tablet, so you will have to remove it with some tweezers. If the pin for the AC adapter broke off inside the tablet, that's a problem, but most everything can be charged from the USB port too see this website:
How To Charge Samsung Galaxy Tab 2 Via USB Port On Computer Laptop PCNEXUS (Samsung used as an example). GL
Jan 08, 2015 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
Dell Inspiron 1521 battery not charging
Laptop batteries power a laptop when it is not connected to an electrical outlet. If the laptop battery fails to charge when the laptop is plugged into an electrical outlet, the battery is likely dead and needs to be replaced. Unfortunately there is no way to fix a dead battery. However, while a dead battery is the likely cause, it is not the only cause. The AC adapter may be broken, in which case the battery won't charge, or the battery contacts may be dirty and need cleaning. Prior to replacing the battery, perform simple tasks to ensure a dead battery is the cause of the problems.
1.Power down the laptop. Gently pull the AC adapter from the side of the laptop for removal.
2.Place the laptop in front of you, bottom side up. Locate the battery release mechanism. This can be a button that slides or needs to be pushed to unlock or release the laptop battery from the housing unit. Press or slide the mechanism. Slide or lift the battery from the battery bay for removal.
3.Insert the AC adapter into the side of the laptop. Power on the laptop. If the laptop does not power on, ensure the AC adapter is securely plugged into a working electrical outlet. If the electrical outlet is working and the laptop won't power on, the AC adapter is not properly working and needs to be replaced. Remove the AC adapter.
4.Dip a cotton swab in a small amount of rubbing alcohol. The cotton swab should be damp, not dripping wet. Lightly rub the dampened cotton swab onto the battery contacts and battery bay contacts to remove dust, buildup and grime. Allow the contacts to air dry.
5.Align the battery over the battery bay. Either press or slide into place. A clicking or snapping noise produced from the locking mechanism will confirm the laptop battery is securely locked into place.
6.Install the AC adapter. Allow the AC adapter to fully charge the battery for 8 hours.
7.Remove the AC adapter. Power on the laptop. If the laptop does not power on, the battery needs to be replaced.
Sep 01, 2011 | Dell Inspiron 1521 Laptop
I have sony vgh-cr590 laptop. For some reason there is no power. The AC adapter has the green light but I am not sure there is power to the computer. The battery will alos not work. I am computer savy...
sounds like a issue with your new ac adapter, or you can be dealing with a broken power pin, This is very common in Laptops, The Power Pin is a connection between your Ac adapter and the motherboard, often this pin is accidently broken causing no contact between the power port and the mother board causing your power issue. If it is the power pin, it will more than likely need professorial work, because the pin needs to be re-soldered back onto the mother board. Total cost for the power pin averages about 40 bucks and most techs will charge around 200 for the labor.
Hope this helps, take care and have a great week.
May 26, 2011 | Sony Vaio VGN CR590 Laptop Universal AC...
The pin in the laptop of my ASUS model G73JW that plugs into the AC charger has broken off twice. I sent it in once already and not two weeks later the same thing happened. I am not rough with my computers...
I've seen this issue on an HP computer before. For some odd reason, some models decided to use "cost efficient" housing around the AC power unit on the inside of the laptop housing. If you know how to replace it yourself, I would recommend just acquiring the piece and replacing it on your own. There are some sellers on eBay who do provide quality products which are assembled with the highest standards.
Jul 28, 2017 | ASUS AC Adapter- Universal Notebook AC...
The laptop just went dead. Does not power up off
check the pins on the adaptor connector that goes into the laptop socket....
they all must align correctly....
normaly it will have three pins, even if one is bent or mis-aligned it will not work....use a small screwdriver to slighly adjust the pins to the aprox correct postion...use a mignifying glass to have a look into the pins....
Dec 17, 2009 | Toshiba Satellite A105-S1712 Notebook
Dell precision m50 will not boot power light just flashes when I push the power on button. I have reseated all of the connection in the laptop. I have tried different batteries and different power...
remove external peripherals. remove battery. use ac adapter alone. check if ac adapter has sufficient power or check if ac adapter led is solid green or blue. if not then ac adapter might not giving laptop enough power to power up.
if ac adapter led stays on but some problem check the ac adapter - laptop pin socket if loose or damage. if not then replace mobo.
Dec 07, 2009 | Dell Precision M50 Notebook
Battery wont change
A problem is just like a mountain. You don't jump over the mountain, you climb it in steps, one step at a time.
1.How old is the battery? 1 to 2 years old, you can expect it to be at the end of it's Life Cycle. Batteries are rated in so many hours of usage.
Best bet is to let the battery charge 24 hours, then try it.
Would be nice if you someone else that has an Inspiron 1525, and they would try to charge your battery. If it doesn't charge up, you would know it's the battery. If it does charge up you can move on down the charging system, to try to find the problem.
2.AC adapter, (Charger) If you have a multimeter, set it to the 50 volt DC scale.
Laptop and desktop computers use DC current. (Direct Current) Your house, for example, uses AC current, (Alternating Current)
AC is converted to DC by the AC adapter, (Charger)
An example of DC current are flashlight batteries, and your laptop battery.
DC current has a Positive pole, and a Negative pole.
The center pin of the plug of your AC adapter is the Positive pole. Any of the four outside pins on the plug, are Negative.
The Red, (Positive), probe of the multimeter goes to the center pin. The Black, (Negative), probe goes to any of the outside four pins on that plug.
Example of a DC Power Jack, for the Dell Inspiron 1500 Series of laptops, 1525 and 1526, (This is the jack inside your laptop, where you plug the AC adapter into),
http://www.megaemarket.com/dc-power-jack-for-dell-inspiron-150150015011505.html
3.It may be that DC Power Jack itself is bad, or one of the solder connections is cracked. It's hard to see it clearly on the link I provided, (So I Right-clicked on it, Save Image As, and put it right in my My Pictures folder. Then I magnified it), but in the photo you will see some metal pins sticking out of the rectangular body.
The metal pins are sticking up. In reality those pins go down, when the jack is mounted on the motherboard. They go through the motherboard, via holes, and are soldered on the other side.
It is these solder joints that may crack, is what I'm referring to.
Solution to 1?
Obviously buy a new battery.
Solution to 2?
If your multimeter findings show lower voltage than needed, it's time to buy a new AC adapter. They have generic ones that can be used on a variety of laptops. The voltage will be stated on the top of the AC adapter.
Example: 19.2V-1.0A
That's 19.2 Volts at 1 AMP.
It may just be the plug end on the AC adapter itself. The plug end that goes into the DC Power Jack, on your Inspiron laptop.
Solution to 3?
Unless you are a skilled Electronics Technician, and have Excellent de-soldering/soldering skills, I advise taking it to a computer repair shop. It may not just be cracked solder joints. The DC Power Jack may need to be replaced. Maybe the motherboard is one of a bad design, and where the DC Power Jack attaches to it, has cracked.
Jul 25, 2009 | Dell Inspiron 1525 Notebook
Toshiba Satellite A55-S306
Sounds like you have snapped the centre connector in the laptop. If you look at the AC connector on the laptop there should b a "pin" in the centre. These frequently snap off, symtoms are :
Battery will not charge
Will not turn on from AC supply.
There are some firm which will replace the ac jack for you but it will cost.
Interent search .. replace DC jack on toshiba
Sep 05, 2008 | Toshiba Satellite A55-S306 Notebook
Acer 3680 ac pin broken
That's really not advisable. At our shop we do socket repairs, I suggest finding someone local who specialises in laptops and asking them to replace it. You can get the sockets on e-bay, etc, if you wish to try it at home, though I don't advise it.
Don't forget to take static safety precautions!
Aug 19, 2008 | Acer Aspire 3680 Laptop
Toshiba Portege 7100 AC Adapter
all are not same but you buy through ebay you cant replace it go the shop and verfy onces
Jun 11, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
