Question about GPS
White line across the garmin 1490 screen after I updated
    Brigadier General:
  • 3,917 Answers
There is no reason for the white line to appear after updates. It sounds like the problem is with the screen itself. Garmin at http://www.garmin.com has an excellent repair program. They repair your out of warrant GPS for a flat fixed rate. The GPS is like new when you get it back. Please visit the Garmn web site click on the support tab and follow the menu selections from there.
Thank You
Posted on Apr 11, 2011
  • e-Guru
    e-Guru Apr 11, 2011
    Hi
    Also the symptom indicates a damaged or cracked or defective LCD screen. This is either caused by an intermittent LCD display or the lock down flap for the LCD is not putting enough pressure on the LCD flex cable. The solution is to replace the LCD screen.
    Please check the link bellow to diagnose your problem:-
    http://www.sharc.net/gps_LCD_repair.htm
    Please get back to us if you have further query else please accept the suggestion.
    Thank you for contacting fixya.com
    Hi
Tip
Garmin Nuvi 1490 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Does your Garmin Nuvi 1490 Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 1490 series GPS unit.
I hope that helps.
__________________________________________
Garmin Nuvi 1490 Manual Download
Garmin Nuvi 1490 QuickStart Download
Garmin Nuvi 1490 Webupdate
Garmin Nuvi 1490 Favorites Backup
on May 27, 2010 | GPS
Update garmin nuvi 1490
Connect it to computer with Garmin Express installed.
Garmin: n?vi® 1490T Software Update Collection
www8.garmin.com > n?vi® 1490T
n?vi® 1490T Updates & Downloads. ... Updates & Downloads. n?vi® 1490T. Update Unit Software with Garmin Express. Use Garmin Express to keep your ...
Garmin: nuvi 1490TV (GCD File) Updates & Downloads
www8.garmin.com > On The Road > nuvi 1490TV (GCD File) nuvi 1490TV (GCD File) software version 6.20 ... Fixed an error that caused traffic provider information to update, whether or not it had previously updated to the ...
Maps & Map Updates ' Garmin ' Canada
www.garmin.com/en-CA/maps/updates/?/golf Update your maps to ensure you have the most accurate data available for your Garmin device.
Garmin Nuvi 1490 LMT (Lifetime Maps and Traffic Edition) - Review ...
? 13:05
https://www.youtube.com/watch?v=Yew6dtXelNk Jan 13, 2012 - Uploaded by elchino
Unboxing the Garmin Nuvi 1490 LMT. Purchased at FutureShop Canada for $199.99. Original price was $239 ...
Garmin nuvi 1490 - how to go past the computer update icon - YouTube
? 1:46
https://www.youtube.com/watch?v=r8ZQ2z2yZUU
Jul 12, 2015 - Uploaded by syalamarti
1. Connect the Garmin nuvi 1490 GPS device to charger - in the automobile or to a USB port on a computer. 2 ...
update garmin nuvi 1490 Google Search
Oct 01, 2017 | Garmin GPS
My Garmin Nuvi 1490 LMT returning to normal functionality after doing a map update.
Common problem caused by a failed map or firmware update...or both.
Corrupted map or firmware files prevents the unit from booting normally. More info on boot-up problems here:
http://www.sharc.net/gps_bootup_repair.htm
Apr 07, 2013 | Garmin Nuvi 1490LMT Nuvi 1490 w/ Lifetime...
Tip
Garmin Nuvi 1490 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Does your Garmin Nuvi 1490 GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
Tip
Download Garmin Nuvi 1490 Manual
Have you lost your Owner's Manual for your Garmin Nuvi 1490 GPS?
Would you like a digital copy of the Garmin Nuvi 1490 Users Guide for easy searching of terms and quick reference?
The Nuvi 1490 manual is available free in pdf format, just follow the photo link below:
I hope that helps.
________________________________________________
My Garmin 1490 LMT goes to white screen with "press dot" only its not to calibrate it bc no matter how many times you push it it wont go, it wont get out of that screen so I can't do...
The white screen indicates are internal error. It keeps telling the unit to go into calibration mode. The item will need to be sent to garmin for repair. 1-800-800-1020. If your unit was purchased recently (less than a year) it is covered under Garmins limited Warranty.
Sep 25, 2011 | Garmin Nuvi 660 GPS Receiver
Tip
Garmin Nuvi 1490 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
I hope that helps.
on May 27, 2010 | Garmin nuvi 1490T GPS Receiver
Tip
Garmin Nuvi 1490 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
I hope that helps.
Tip
Download Garmin Nuvi 1490 Quickstart Manual
Have you lost your Owner's Quickstart Manual for your Garmin Nuvi 1490 GPS?
Would you like a digital copy of the Garmin Nuvi 1490 Quickstart Users Guide for easy searching of terms and quick reference?
The Nuvi 1490 Quickstart manual is available free in pdf format, just follow the photo link below:
I hope that helps.
Tip
I hope that helps.
GPS Logo
1,100 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
