Question about Kenmore Sewing Machines
I have a kenmore mini ultra model no. 11206. The tension wheel suddenly will not adjust tension and my thread is getting stuck in there. If the thread does feed, I mostly see bobbin thread. (this I s a clue thread tension is too tight) However, it seems the tension disc(s) is not actually moving when I turn the wheel. What do I do?
bargainbox
  • 1388 Answers
SOURCE: Adjusting bobbin tension.
This generic tension setting guide will walk you through attaining the correct balance of tension for any machine.
Ensure that all is clean and free of lint jams....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Jun 09, 2008
geemarie
  • 876 Answers
SOURCE: I'm trying to do shirring?
My machines has a shirring foot, so I don;t have the same machine. However, I do not think that elastic thread will work in the bobbin. Have you tried it the other way around? Do you have your manual?
Posted on Aug 07, 2008
bargainbox
  • 1388 Answers
SOURCE: janome 9500 bobbin tension too tight can I adjust it
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
TOP LOADER:
FRONT LOADER:
back properly.
OTHER ISSUES:
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
Posted on May 01, 2009
Mongo32
  • 111 Answers
SOURCE: Bobbin wont feed
a. needle in backwards
or
b. needle threaded wrong
Posted on May 04, 2009
Mongo32
  • 111 Answers
SOURCE: Can't get thread tension right on my Euro-Pro 7130
the top seam is actually the bobbin thread. dots on the underside means that the top tension is too tight. you may have a piece of thread or something gummy caught between the upper tension disks.
Posted on Jun 11, 2009
My kenmore mini ultra is bunhching the tread by the bobbin
try changing the needle--normally flat side goes to the back of the machine
make sure the thread & needle are correct for the fabric being sewed
rethread machine top & bobbin
make sure top tension is adjusted according to fabric & thread
Apr 06, 2012 | PfaFF Quilt & Craft Pro 7530
I need a manuel for 11206609 I am trouble with the bobbin catching and the thread is bunching. I also need to a manuel to see how to properly thread the machine.
I can't find a manual for that exact model, but I found a service manual and instruction manual for a 11206630. They will, hopefully, be close to your machine. Normanlly, when the model numbers are that close, the manuals are very close as well.
The links are http://www.managemylife.com/mmh/owner_manuals/133369/KENMORE-Mechanical-Sewing-1008846L?brand_name_search=Kenmore+11206+Sewing+Machine and
http://www.managemylife.com/mmh/owner_manuals/20676/KENMORE-Mechanical-Sewing-L0305018?brand_name_search=Kenmore+11206+Sewing+Machine
I hope these are helpful!
May 30, 2011 | Kenmore 11206 / 11306 / 11506 / 11606
How do i thread a kenmore ultra mini?
o to Sears.com. They have manuals to download for FREE. Your model is 385 11206 Ultra Mini Kenmore. I had the same problem, misplaced my manual and found it online yesterday 01-20-11. It's upsetting to me that so many people are on here trying to get everyone to pay $10 for something they are getting for FREE. I've tried several times to copy it to this posting without luck. Hopefully the money makers will not delete my posting and everyone can get the free manuals. I think they have manuals available for most things they sell available free like this.Good Luck!
The manual will tell you how to thread it. :)
Jan 18, 2011 | Kenmore 11206 / 11306 / 11506 / 11606
My kenmore mini ultra sewing machine is stuck won't go forward or backwards. how to fix it.?
Take out the bobbin and bobbin case and make sure there is no thread stuck round the raceway
Apr 24, 2010 | Kenmore 11206 / 11306 / 11506 / 11606
Where to buy the pedal for kenmore 11206
Janome, New Home and Kenmore are made by the same factories, so depending on your location, I would recommend you contact Janome in your country and ask for your nearest dealer.......if you have a repair shop near you, it is always worth a phone call to see if they can assist, many carry replacement or second hand parts for a variety of brands.
They can be quite expensive, so have a thorough search first !
Feb 22, 2008 | Kenmore 11206 / 11306 / 11506 / 11606
Handwheel is stuck
NEVER force a newer model machine. Everything inside is plastic and WILL break. Remove the needle, bobbin, bobbin case, and unthread the machine. See if the handwheel turns. If it doesn't, several things could be wrong. The lower end machines won't have belts to come off, they will be fully gear driven. If it is a better machine, it might be a belt problem. Small pieces of thread could be stuck in a gear mesh somewhere. A gear could be broken. It is possible for a gear to break on the first use.
Dec 01, 2007 | Kenmore 11206 / 11306 / 11506 / 11606
Locking up and knotting!!
my machine keep knotting up while im trying to hem my pants.
Jan 16, 2007 | Kenmore 11206 / 11306 / 11506 / 11606
Sewing Machines Logo
279 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
