Question about Radio Communications
Cant find pulse wire for nissan sentra 1993 - Radio Communications
    Genius:
  • 1,274 Answers
This needs to be in the auto section..........
Posted on May 05, 2011
What is the problem on 1993 nissan sentra carburator with no idling
probly age--needs boiling out or jet ajust-------try fixin idle speed with screwdrivr---------cud be engine issue-like tuneup---inspect inside distributer cap for corrosion or worn plug wires---also egr valve mite be bad--------get vehicle scanned
Jul 27, 2012 | 1993 Nissan Sentra 4 Door
I cant find starter in my car nissan 1993 can you please tell me where to find it
try behind the motor on the passenger side. I think you'll have to get under the car to find it
Mar 09, 2010 | 1993 Nissan Sentra 4 Door
Fitting a stereo in a 1993 Nissan Sentra
if you are putting an after marker stereo the wiring is different from a stock radio some audio stores sell adapters for after market stereos that you jus clip on to stock wiring
Nov 14, 2009 | 1993 Nissan Sentra 4 Door
I have a 1993 Nissan Sentra that won't start.
have you tried changing your rotor and distributor cap? and checked the wires for breakage or leakage?
Sep 01, 2009 | 1993 Nissan Sentra 4 Door
Stereo wire diagram
1995 Nissan Sentra Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Black
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Violet
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Pink
Mar 25, 2009 | 1995 Nissan Sentra
2002 nissan sentra it wont start i got fire on the spark plugs bu
Injector pulse comes from Cam sensor, If you have a BAd CAMSHAFT sensor you will not get injector pulse, replace sensor and that should solve your problem. Good Luck and thanks for using FIX YA
Jan 20, 2009 | 2002 Nissan Sentra
Nissan sentra 1993 1.6 l won't start
try puting shifter in nuetral , common nissan problem
Dec 24, 2008 | 1993 Nissan Sentra 4 Door
Nissan rough idel
Sounds like the injector in #1 cylinder is not working. Unplug injector and check for OHM reading. The spec for your injector is I believe at around 10-14.5 OHMS. If out of spec, replace it. If that's OK, than check for 12V on one side of the connector going to the injector. If 12V is there, than you are getting power. The other wire goes to the ECM/computer. You will have to trace it to the computer and check for continuity from the injector connector to the ECM/ Continuity should be present. If no continuity is found, than you have a broken wire. If continuity is OK, than the ECM may be the cause. There could be other causes also, like engine mechanical issues, such as burned valve, bad piston, plugged EGR passages on your model Sentra or headgasket. Start with checking the injector and post results. I think that you will find, that its not any good.
Oct 29, 2008 | 1993 Nissan Sentra 4 Door
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
