Question about Bushnell SkyTour 78-9960 (700 x 60mm) Telescope
Clock won't keep time - Bushnell SkyTour 78-9960 (700 x 60mm) Telescope
  • 3,186 Answers
It will NEVER keep time. You must re-enter the time, date each time you use it.
Posted on Apr 11, 2011
Set the clock
go to the screen where you would set the clock. touch the area for hours then below press the number which dictates what hour it is. do the same process for minutes.then you hold the check mark button for a couple of seconds. actually it wouldn't hurt to do that after setting the hour and minute..Also make sure you have all your wiring connected right. Cause the wire that operates the clock has voltage all the time this is what keeps the clock running you may want to check to make sure yours does not shut off with the key, Thank You Hope this helps
Oct 20, 2014 | Crown Ouku 7 Touch Screen 2 Din Car Stereo...
Wall Clock Won't Keep Time
Disconnect it. Plug it back in. Go to the office and tell the master clock to reset all the clocks. It sounds like it is searching for guidance from the master unit.
these people may be able to help specifically if you don't have instructions for the master unit.
http://stevenengineering.com/tech_support/PDFs/57MAIN_CLOCKS-TIME-SYSTEMS.pdf
This is the way I did it when we have all the clocks in a hundred room hotel to change when the clocks change in the UK. I went back to the same hotel 35 years later and asked if I could see when the cupboard where the clock was reset, and the unit was still there, albeit not working. It was replaced for a more modern system, of putting clock radios in rooms.
Aug 19, 2017 | Dukane Audio Players & Recorders
Hp pavilion clock won't keep time
try finding the time zone you are in and use that to set the time, changing the numbers individual will end up with the time going back to the time zone time. So change the time based on the time zone
Aug 04, 2012 | HP Computers & Internet
Clock won't go from am to pm
Your clock is set for military time; check the instructions. I believe you have a dual alarm clock that can tell conventional and military time.
Apr 03, 2012 | Audio Players & Recorders
My Keurig B70 won't keep time
Timer is not their best suite and the 2014 systems are far better.
Jan 22, 2012 | Keurig Platinum B70 Coffee Maker
Manuel for 88900
Are you getting a signal? The disp Ay should show that it is picking up radio time signal on the display. If not, reposition to a totally different location. If still no signal, receiver must be off. May be warranty issue.
Nov 11, 2011 | SkyScan 86709 Atomic Wall Clock
My clock is constantly blinking and won't go on the right time. I unplugged it and plugged it again, it just keeps blinking.
Hello
Check the bckup batteries in the clock first. If they are weak, backup function will not work properly, and the display will blink after a mains power failure.
Auto Clock Set
You do not have to set the clock time as a
built-in automatic time set system is
equipped in this clock powered by 3V (2
X AA batteries, included). All you have to
do is to plug this clock for power and
current time will be shown automatically.
However, the batteries can also be
exhausted and we recommend that you
replace the batteries every 2-3 years
Before You Plug for Power
1. Setting Time Zone
You may slide the TIME ZONE selector at
the back of the unit to Eastern (EST),
Central (CST), Mountain (MST) or Pacific
(PST) (refer to the maps on the right).
2. Daylight Saving
You can slide the DST switch at the back
of the unit to turn on/ off in areas
observing/ not observing such time
change.
WARNING: Please avoid playing with
these buttons after entering the
Clock/Alarm set mode.
Setting Clock
1. Slide the switch /WAKE1/WAKE2/
on the top of the unit to clock position.
2. Press REV or FWD to set the clock
time. The time decrements or increments
will follow by a faster rate when you press
and hold the buttons. The ":" between
hour and minute time flashes when you
are setting the time. AM or PM icon will
also beside the time.
3. Slide the switch /WAKE1/WAKE2/
on the top of the unit to position
when finished.
OK.
Aug 12, 2011 | RCA RP5430 Clock Radio
The colon between the numbers on the clock, example 8:00 won't stop blinking even after I set the clock and hit the clock button again.
Sometimes the correct procedure for setting the clock is to press the CLOCK or TIME OF DAY button, then enter the time on the keyboard, then press the START button instead.
Otherwise, as long as you can enter a cooking time and your oven operates normally, then don't worry about it. On some models it is normal for the colon on the clock display to blink all the time.
Good luck.
May 11, 2011 | Microwave Ovens
Help daylight savings time is not here yet
I am going to try changing to time zone 7 (Hawaiian Time). Hawaii does not observe DST so this should turn the clock into a regular clock that ignores DST and you need to set yourself twice a year.
Oct 30, 2007 | Emerson SmartSet CKS1850 Clock Radio
RCA alarm clock - RP3721 - crystal or AC for time?
They used to use crystals to help the timer ics to keep time but since the development of Micropros. all this is built in to one chip. Now they will use a resonator or a small crystal for the timing clock of the micro but nowdays the manufacture uses that clock to keep all in check. If your gaining time you probably are having problems with your ac duty cycle as this also keeps clocks in check.. This would not affect most devices but could be a problem. But of course a defective Micro could also cause this gain in time And probably is?? Now a battery backup is nothing more then a battery in line with the Microproccesors B+ terminal through of course a diode as well as a voltage limiter resistor to take over the B+ when the units ac supply is absent..
Mar 03, 2006 | RCA RP3721 Clock Radio
Bushnell SkyTour 78-9960 (700 x 60mm) Telescope Logo
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
