Question about Pool & Spa
When the spa and the waterfall running, the waterfall will **** out the water from the spa to the pool. what is wrong with this?
    President:
  • 1,378 Answers
The valve(s) controlling water flow to all the features are not set correctly. You will need to increase the amount going back to the spa to keep it from draining. Depending on the valves in use they are not overly difficult to change the diverter settings. If you need help with that please comment to this post and include the valve brand and model number.
John
Posted on Apr 11, 2011
The waterfall is not working. How can I fix it?
To give you some advice about how to fix your waterfall probably you should specify your equipmente.
Now, without knowing a word about your system I guess the problme is the motor of your pump. If you have no experience repainng the electric board of a pump you should call an authorized repairmen
Jul 08, 2015 | Pool & Spa
One touch controller
go into one touch function remove what you dont want to come on
Apr 22, 2014 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
DREAM MAKER SPA WATERFALL VALVE
The threaded cap the holds the waterfall valve in place is most likely cracked so you will just need a new valve. Send me a picture of it and I can see if I can locate one for you.
Jul 30, 2013 | Pool & Spa
Spa waterfall isn't flowing
If you turn the valve to operate the waterfall feature on your spa and no water is coming out of it, my best guess would be the valve is broken and not turning to allow the water to go to the waterfall.
Pull the top of the valve off and look inside for a broken part.
Rod
US Parts Center
888-521-6183
Feb 11, 2013 | Pentair IntelliFlo VS-3050 & VS+SVRS...
I have an inground pool and elevated spa that overflows into the pool by waterfall. I have freeze protection which causes the pump to run in colder temps. I did not know that and thought I turned the pump...
sounds like without a key u need to jimmy the door open
going to have to cut the power to the pool pump motor
if running dry and wont shut off . it may burn out
then need to call a pool repair guy
one of those valves you mention is faulty
and to show you how the pool valves work
Mar 06, 2017 | Pool & Spa
Why does the spa empty when the pump shuts off? just got a pool with an aqualink RS4 and no manual to look at. thanks
This problem can be caused by a couple things. the two most likely culprtits are either the absence of check valves and or incorrect actuator settings when the pump shuts down.
Your spa is most likely higher than the pool. You most likely have a spill over (waterfall) feature from the spa into the pool. This is so the spa water can be recirculated in pool mode. One of your actuator valves may be slightly off closed position in order to allow spill over in the spa, or you may have a dedicated overfill pipe in the circuit to feed water to spa in pool mode.
Whichever spill over piping you have set up, when the pump shuts down, water from the spa ( higher level than the pool) will backfeed through the overflow spa circuit, back through the pump and into the pool through either drain or return. Effectively rendering your spa level the same level as your pool.
To fix this problem, simply install check valves into the spa runs and as a secondary measure put one into the pool return run ( the run that feeds water to pool).
This will insure that when the pump shuts down, no matter which position the valve actuators may be set, water can not back feed through the pump circuit from spa to pool.
Jul 15, 2009 | Water Pik Aqualink Rs4 Package - Pool and...
Pool & Spa Logo
744 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
