Question about Vizio VW46LFHDTV10A 46 in. LCD TV
We have problems with our screen darkinging in sections. It flashes in and out. Can still see the images, but is shaded and hard to see.
  • 1,548 Answers
The fluorescent tubes behind the LCD panel are going out. These are not ordinary fluorescent tubes, they are very skinny and have a single pin at each end (cold cathode fluorescent tubes, or CCFL for short). Replacing the tubes requires considerable soldering expertise because the ends cannot be heated for more than 3 seconds or so, and the finished connection must be small enough to slide the insulating cap back on over it.
The tubes are $24.99 each at LCDParts. You can learn more about replacing them at their Tech Support page. Probably the more difficult task is getting at the tubes; you may need to almost completely disassemble the TV to reach the LCD panel assembly. You can find the tubes by following the paired pink and white wires from the inverter board; each pair goes to one or two tubes. Do not remove the driver circuit board from the panel; you should be able to slide the tubes out the side of the set once you have the right pieces removed.
Note: LCDParts has some tubes pre-wired with new connectors for an extra $8 apiece. If you are not comfortable with the delicate soldering required, you may wish to inquire about this option - perhaps if you send them the old tubes with the wires attached they will salvage the wiring from them and put it on new tubes.
Posted on Apr 11, 2011
    Top Expert:
  • Vizio Master
  • 74,251 Answers
Hello
It is due its backlight problem. Check it. Check its inverter board. it is best to replace it with an other board of same type and number. Check the baclights also. OK.
  • 37 Answers
I had similar problems on my LCD TV, then finally it would'nt power,
i had to replace two boards, for a cost of 6000 Indian rupees roughly 110 us $ ? now its fine and kicking, I faced it all double images, the greening of colours, the blanking out, but now its fine, all latest and LCD TVs come with boards starting with the mother-board or main board which is quite expensive. Tv's are repairable at minimum cost but here there are gimmicks to sell new TV's which they say exchange for new ones (trade in ) they even buy a dead TV for Rs 1000 if you are willing to buy a new one for 25000+ a working LCD TV fetches Rs 2000 in exchange. BUT why..if you can repair and use. unless you have a complete LCD display gone. the boards for the LCD TVs and LED Tv's are the same. all Tv's sold in the market now are LED's
Posted on Nov 27, 2014
Vizio 55" Inconsistant Dark Screen
you have to open the back cover to check weather the screen back light need replacement. usually if the lamp is almost black in color it needs replacement. the backlight is covered with metal shield installed at the upper portion and lower portion of the panel of the tv.
Nov 01, 2012 | Vizio VF Televison & Video
Our Phillips flat screen TV picture is split down the middle vertically. One side shows a mirror image of the other side, and then sometimes one side is a lighter shade than the other, when it is full...
This may be due to a faulty Timing Control board (TCON board). I had a similar problem with my Samsung LCD TV picture being split vertically down the middle. The image on both halves appeared fuzzy and in reverse (mirror) including the menus. I replaced the TCON board and the problem was resolved.
Aug 18, 2011 | Televison & Video
Video problem. Lower 3/4 of screen flickers off and on with a "blacker than normal" screen. Works well for a few minutes, then black shading occurs off and on. Within black shaded area, screen...
Your screen is defective. Screens are very expensive to replace but you might be able to find a used one on line. You will need the part number of teh screen it is located on the back of the LCD panel on a white sticker. Do a google search and see if anyone is selling it. You can try www.interliquidparts.com
Jun 04, 2011 | JVC LT37XM48 LCD TV
If i click for photo in day its too brightness because of that i we cant see images properlly please ressolve my problem !!
Turn off your flash light manually and avoid to capture with strong light in front of your lens (sun or lamp)
When you take picture outdoors with much light, try to shade your lens with something, use umbrella or even your own hand shadow to make a shade.
If useful, RATE please !
Jan 18, 2011 | Canon Powershot SX110 IS Digital Camera...
MAIN POWER OFF/ON A3200 flash on screen
Thats an exposure lamp error. Either your lamp is blown, a thermal fuse is blown, the shading plate and optics are very dirty, or you have a bad circuit board. Make sure you unlug it if you plan to poke around in the optics section.
Oct 13, 2009 | Kyocera Copystar CS-1620 Black and White...
Pink shading on panasonic PT44lcx65 tv
DLP image problems are usually related to the digital video board, will probably not be cheap. might even need a new light engine. good luck Julio milleniumtvsvc@gmail.com
Jul 22, 2009 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Uneven flash
Look carefully at your images taken with flash... on the horizontal image is the lower part of the image slighty darker and have a rounded fall off at the edges? Is the vertical image dark side a straight hard line or is there a rounding to the top and bottom?
What we are looking at is if you have a very wide angle lens with the lens shade attached to the lens, then the built-in flash catches part of the lens shade and make a shadow on your subject... take the lens shade off and try the same shot and see if that makes a difference...
Have a great day...
Ed
Apr 03, 2008 | Nikon D40X Digital SLR Camera Digital...
Blue shading problem
2 months old? I'd call the dealer..it's under warentee. You have a problem that will not get better.
Jul 14, 2007 | Samsung PS42P4AX 42 in. HD-Ready Plasma...
MRM 700 won't start; screen flashes white . . . help.
stonelinton, It's not your LCD, otherwise you would have heard the sound of buttons being pushed. If your units first screen is white and there is no logo screen or any legible images, then it's your NAND flash on your main board. The first image produced upon boot is the blue magellan screen. This is produced from the NAND flash and will show it no matter if a hard drive is present or not. After the Magellan screen it pulls images from the hard drive. So, it is the mainboard and the only way to fix it is to send it to Magellan repair and they will have to put in a new mainboard then reprogram your serial number, etc.
Jun 07, 2007 | Magellan RoadMate 700 GPS Receiver
Vizio VW46LFHDTV10A 46 in. LCD TV Logo
1,635 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
