Question about Graco Passage Travel System Stroller
I can't figure out how to install the rear wheels on to the axel of the graco passage full size stroller
  • 17 Answers
SOURCE: graco quatro wheel removal
There are several different styles of the Graco Quattro Tour stroller, but it seems that all styles have similar instructions for the wheels. For the front wheels, you might need a flat head screwdriver. The front wheels snap into place, so there should be some form of clip that is holding them in place. You will need to locate this clip (which may be inside the piece connecting the two wheels together. Use the screwdriver to reach this piece, and push it in, then slide the wheel off while the clip is still compressed.
The rear wheels will also require the use of a flathead screwdriver. There is a Graco logo on each back wheel. It is an oval piece that should be pried off with the screwdriver. You will then see a locking pin under it. You will need to use the screwdriver to spread the open end more so that the pin will be wide enough to slide out of the axle hole. Remove the wheel and the washer (be careful to move the pin and the washer somewhere where you child cannot find it, as they can be choking hazards).
The following is the link to one of the Graco Quattro stroller instruction manuals. http://www.gracobaby.com/assets/pdfs/instructions/ISPA173AB.pdf
You should be able to look at this for detailed pictures for the stroller assembly, but then follow those directions in reverse to remove it.
I hope this has helped.
Posted on Jan 01, 2008
SOURCE: GRACO STROLLER FRONT WHEEL BROKEN
I have the same problem, the airline broke ours the last time we flew. I just found on Graco's website that you can order replacement parts. Here is the link, http://www.gracobaby.com/store/order/default.asp?N=10418+10413+10421&Ne=11
You'll need the model number and serial number. I found ours on a sticker under the footrest. For our stroller it's $19 plus shipping for the front wheel assembly.
Hope this helps.
Posted on Feb 11, 2008
  • 51 Answers
SOURCE: replacement wheels for graco stroller
You can order replacement parts by calling Graco at 1-800-345-4109 have your model number ready so they can look up the correct replacement patrs for you.
Posted on Aug 11, 2008
  • 32 Answers
SOURCE: My Graco stroller model -
You can order parts here:
Posted on Nov 18, 2008
  • 5 Answers
SOURCE: Replacement Parts
Try here, they have any part that you need. http://www.gracobaby.com/ReplacementParts/Pages/ReplacementParts.aspx
Posted on Dec 29, 2008
I forgot to install the washer on the rear wheel of my ready2grow stroller. I need to remove the hubcap so I can access the axle. The hubcap snapped in and I cannot figure out how to remove it without...
Not sure if you figured this problem out yet? I ended up doing the same thing. I just inserted a small screwdriver into the back to pop the pins of the hub cap out.
Nov 09, 2012 | Graco Forecaster Ready2Grow Infant Travel...
Fron right wheel broke need to replace graco wheel model 7537tabu
Go to:
You will need to enter the model number and manufacture date. The manufacter date on graco strollers can be found on the rear leg of the stroller or under the footrest. If it is an umbrella stroller it can be found On the x shaped tubing under the seat. Feel free to ask me any follow up questions. Also please leave me positive feedback if this helped you. Thanks.
Jul 09, 2011 | Graco Baby Gear
My Graco stroller keeps pulling to one side makes it difficult to push
jeanis, how old is your stroller?
If not yet a year, you can contact graco nearest your place to help you.
One simple thing to check why your stroller keep pulling to one side is because of the WHEEL.. that is hard to spin. Where side its keep pulling? If in the left side, try to take up the left side of the stroller a little, just the wheel not touching the floor and rotate or spin the wheel one at a time in rear and front. Check that the wheel rotate smoothly. If not then there something wrong with that wheel.
If in the right side, try to do the same.
Jan 30, 2010 | Graco Quattro Tour Travel System
Broken rear wheel on graco duo stroller
You can order replacement parts from the Graco website.
Go to the Help Center, then Order Replacement parts. You'll need the model number and serial number or manufacture date. Site helps you locate the information on your product.
Jun 09, 2009 | Graco DuoGlider 7444 Twin Seat Stroller
Replacement wheels for graco stroller
Yes you can get replacements on amazon, here: Amazon com graco stroller wheels replacement. I hope this helped you. Cheers
Aug 08, 2008 | Baby Gear
Graco quatro wheel removal
i have the graco quattro tour sport, i put it together & noticed the swivel lock was missing! I have to take the wheel back tonight but i had already put it on the pram! after reading 'Adorough's' comment i had good look at the wheel to figure out how to get it off. 1) fold the pram up and stand it so the front wheels are up. 2) if you look round the back of the front wheel you should see a round 'pin' which is set back, you well need a pen or something pointy to press the pin in & pull the wheel! That worked for me.
Sarah
Dec 31, 2007 | Graco Quattro Tour Travel System
Graco Passage Travel System Stroller Logo
163 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Dennis Crouse
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
