Question about Acer eMachines 520-2890 Notebook
My acer emachine laptop wont charge. i think charging unit has a problem.
  • 59 Answers
The best way to figure out if it is the charger or the port is to plug it into your laptop and giggle it. If it moves alot the port probably needs to be re-attached to the motherboard with a soldering iron. If it doesn't move very much then you probably need to replace the charger. Hope this helps.
Posted on Apr 11, 2011
I used it the night before it was fine i plugged in the charge and it wont turn on at all
laptop charger for acer aspire 3600 3680 series 3650 3610
www.amazon.com/LAPTOP-CHARGER-ACER-ASPI...
Amazon.com, Inc.Amazon.com: LAPTOP CHARGER FOR ACER ASPIRE 3600 3680 SERIES 3650 ...When I was looking for a charger cable for my laptop, i was not sure whether I ... it was really good and worked, it heats up a little bit but for now its working ...
When your acer aspire 5738 z laptop adapter is not working ...
docslide.us > Business
Aug 18, 2015 - When Your Acer Aspire 5738Z Laptop Adapter is Not WorkingA ...Quicker Charging of Laptop Battery with an Acer Aspire 3600 AC Adapter ...
batteries-store.pblogs.gr/.../when-your-acer-aspire-5738z-laptop-adapter-...
Jan 14, 2016 | Acer Aspire 3600 Laptop Charger...
Acer laptop 5551 wont charge
The solution to your problem lies in one of the following three areas:
1.) Your charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think possibility 2 is the most likely, although you will have to test possibility 3 by removing the battery and plugging in your charger and seeing if the laptop powers on.If it does power on then that rules out possibility 1 and 2 leaving a faulty battery.
Replacement Acer Aspire 5551 AC Adapter 65Watt 19V 3.42A
Feb 17, 2013 | Acer Aspire Computers & Internet
E-machines e442 wont charge when switched on, only charges when off
There is a possibility there is a problem in the DC jack to the laptop, but it would mean dismantling the computer down to the motherboard level to make the repair.
May 19, 2012 | eMachines Computers & Internet
Emachines e625 wont turn on, light is on for adapter, still wont work
Your battery is not being charge you will need a new adapter it is not supplying a charge for the battery or the battery is not holding a charge. There may be a compatible charger for small fee located on Ebay for your model . 2. Contact the manufacturer for a replacement. There will be a charge.
Here is their support site address:
http://support.emachines.com/em/driver/nb/e625.html
3. they will require to know what you unit has that is ram, hard drive, video card, model no.
Oct 22, 2011 | Acer eMachines 520-2890 Notebook
My emachine wont charge past 86% why?
Take to a laptop service center and check for battery leakage. Or any damage in the laptop. This is the only reason why your laptop might not charge properly.
Aug 26, 2010 | eMachines eM250-1915 Netbook
Acer aspire 5520 wont power up.. no charging light when connected to mains
Try another charger. If it turns on and chargers the unit you are currently using needs to be replaced. Do not leave your charger plugged in after charging your battery as this will shorten its life.
Oct 31, 2009 | Acer Aspire 5500 5570-2609 Laptop
I have an Acer Aspire 3610 notebook. It wont charge
How old is your battery? When you use your laptop, do you run it on just the battery or do you use your a/c adapter and battery? If you're going to use your laptop for an extended period of time, it's recommended to remove the battery and run off of a/c power alone. This helps to extend the life of your battery. Over time, using both a/c and battery will cause your battery to charge/discharge, which dramatically shortens the life of the battery.
You may simply have a dead battery.
Another alternative is that you have a bad power unit, which is what the a/c adapter plugs into on your laptop. My guess is that you most likely have a dead battery.
Oct 07, 2009 | Acer Aspire 3610 Notebook
E machine 510 wont charge!
Yes, remove the battery from the laptop.
Plug-in power adapter and turn ON laptop (without battery).
After the laptop starts up and Windows has settled, put battery back in the laptop.
Allow to charge for a few hours.
Oct 07, 2009 | E-Machines eMachines Desktop PC
Emachine battery won't take a charge
how long do you charge a battery for an emachine e525?
Mar 25, 2009 | Computers & Internet
Batter Not Charging
if your unit can charging battery from 0% to 28%, it's mean your battery is bad.
But if your unit can't charging battery at all, it's mean your motherboard is bad,
Jan 25, 2008 | Acer TravelMate 2300 Notebook
Acer eMachines 520-2890 Notebook Logo
203 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
