I need to clear the password of the bios. For some reason is locked now. After 3 attempts I've got a Key:65409952
    Problem Solver:
  • 5 Answers
For a Desktop computer:
When inside the computer be sure you're aware of the potential damage that can be caused by ESD.
1. On the computer motherboard locate the BIOS clear / password jumper or dipswitch and change its position. This jumper is often labeled CLEAR, CLEAR CMOS, JCMOS1, CLR, CLRPWD, PASSWD, PASSWORD, PSWD or PWD as shown in the picture to the right. To change the jumper remove it from the two pins its currently on so that it covers the pin that is not covered. For example, in the picture to the right pins 1 and 2 are covered, you'd remove the jumper and put it on pins 2 and 3.
2. Once this jumper has been changed, turn on the computer and the password should be cleared. Once cleared, turn the computer off and return the jumper or dipswitch to its original position.
The location of the jumpers or dipswitches are dependent on the manufacturer of the computer and motherboard. However, below are some general ideas on where to find it. Remember that most motherboards could have dozens of different jumpers, make sure you're changing the CMOS jumper and not something else. If these general suggestions do not help refer to your motherboard / computer documentation or skip to the next step.
The above instructions are from the following page: http://www.computerhope.com/issues/ch000235.htm
Instructions for a Laptop: http://www.computerhope.com/issues/ch001302.htm
Posted on Apr 11, 2011
I have a dell 3000 dimension desk top computer. The message I get after tapping the F12 key is as follows. Key board failure. Type password and press enter to leave password security enabled next line
The motherboard BIOS is activated when you press the F12 Key and can be locked via a password that is different from your pc user account. There is only one way to reset this because the BIOS is a chip on the motherboard. You have to reset the password using a jumper on the motherboard that is marked with PSWD. This will also clear the CMOS which is Computer Memory on Startup which tells the computer the different changes from the original bios chip. so you may have to go in and set some settings in the bios to have everything back to operational.
Turn off and unplug the tower before opening it.
The password jumper's location on a Dell Dimension motherboard can be found by reviewing the Dimension User Guides.
For most Dell Dimension desktops, the steps to reset a BIOS password and clear all CMOS settings are:
  • Locate the 3-pin CMOS password reset jumper on the system board.
  • Remove the jumper plug from pins 1 and 2.
  • Place the jumper plug on pins 2 and 3 and wait approximately 5 seconds.
  • Replace the jumper plug on pins 1 and 2.
Now replace the panel and plug unit back in. You should be able to enter the bios without a password.
Oct 01, 2014 | Computers & Internet
Tip
How to Clear BIOS Password
Method 1 of 3: Using the Password Breaker
  • 1. Using another computer, load up your Internet browser. Go to this website, and write down the code shown on the locked computer.
  • 2. Pay the Small fee, and then enter the code you have written down. A few codes will be provided, so try them all until you find the one that works.
This also works for locked HDD drives, so make sure you take a look.
  • 3. You're computer is now unlocked! Keep the backup password handy, this will be invaluable if you locked out of you're pc again.
Method 2 of 3: Reset Jumpers to Clear a CMOS Password
http://www.fixya.comwrite_tip-bus3iqmg0jrasilho1abbg4j-3-0.jpg
  • 1. Unplug the computer and remove all peripheral connections like monitors and printers.
http://www.fixya.comwrite_tip-bus3iqmg0jrasilho1abbg4j-3-2.jpg
  • 2. Reduce electrostatic discharge (ESD). Wear a wrist strap to eliminate ESD, or make sure 1 hand is holding a metal piece while you are working inside the computer. Wear rubber soled shoes, and stand on an ESD mat if possible.
http://www.fixya.comwrite_tip-bus3iqmg0jrasilho1abbg4j-3-5.jpg
  • 3. Open the computer. Locate the CMOS jumper. The jumper will usually consist of 3 pins, though on the rare occasion, 2 pins (requiring you to supply the jumper itself). This often is labeled with "clear," "cmos," "password" or some abbreviation that indicates it is the password jumper. It is usually located near the CMOS battery, or processor. In laptops, it is often a dipswitch at the bottom of the laptop. Consult your motherboard documentation to find the location if you are unsure of where it is located.
http://www.fixya.comwrite_tip-bus3iqmg0jrasilho1abbg4j-3-9.jpg
  • 4. Make note of which pins the jumper covers. Remove the jumper. Reinstall it so that it covers the pin that is currently not covered. For example, if it covers pins 2 and 3, change it so that it covers pins 1 and 2.
http://www.fixya.comwrite_tip-bus3iqmg0jrasilho1abbg4j-3-14.jpg
  • 5. Reassemble the computer, and re-connect the power. Turn on the computer. Check to see that the password is cleared.
  • 6. Turn off the computer. Disconnect the power cord, and open it. Change the jumper settings back to the original position.
Method 3 of 3: Other Methods to Clear a BIOS Password
  • 1. Search online for generic CMOS passwords. Older computers sometimes have a generic password set by the manufacturer. To find one, search for the name of your manufacturer. Keep in mind that the computer password may have changed or no longer is in use.
  • 2. Download a utility to bypass the computer password. These can be found online and loaded with a CD or floppy disk.
  • 3. Take out the CMOS battery. Leave it out for longer than 5 minutes, and then reseat it. This will clear all BIOS settings, including the password. Keep in mind that you will have to reset the BIOS date, time and other settings.
  • 4. Contact the manufacturer. Find information about the motherboard, and call either the motherboard or computer manufacturer. They can tell you whether there is a CMOS default password or solder beads that must be jumped.
on Jan 15, 2015 | MSI Computers & Internet
My laptop is asking for PhoenixBIOS Setup Utility password. Can you please help me out with da password?
tRY THIS LIST AND OTHER ALTERNATIVES THAT FOLLOW...GOOD LUCK
WARNING: Some BIOS configurations will lock you out of the system completely if you type in an incorrect password more than 3 times. Read your manufacturers documentation for the BIOS setting before you begin typing in passwords.
Award BIOS backdoor passwords:ALFAROME BIOSTAR KDD ZAAADA
ALLy CONCAT Lkwpeter ZBAAACA
aLLy CONDO LKWPETER ZJAAADC
aLLY Condo PINT 01322222
ALLY d8on pint 589589
aPAf djonet SER 589721
_award HLT SKY_FOX 595595
AWARD_SW J64 SYXZ 598598
AWARD?SW J256 syxz
AWARD SW J262 shift + syxz
AWARD PW j332 TTPTHA
AWKWARD j322
awkward
AMI BIOS Backdoor Passwords:AMI BIOS PASSWORD HEWITT RAND
AMI?SW AMI_SW LKWPETER CONDO
Phoenix BIOS Backdoor Passwords:phoenix PHOENIX CMOS BIOS
Misc. Common PasswordsALFAROME BIOSTAR biostar biosstar
CMOS cmos LKWPETER lkwpeter
setup SETUP Syxz Wodj
Other BIOS Passwords by ManufacturerManufacturer Password
VOBIS & IBM merlin
Dell Dell
Biostar Biostar
Compaq Compaq
Enox xo11nE
Epox central
Freetech Posterie
IWill iwill
Jetway spooml
Packard Bell bell9
QDI QDI
Siemens SKY_FOX
TMC BIGO
Toshiba Toshiba
Toshiba BIOS
Most Toshiba laptops and some desktop systems will bypass the BIOS password if the left shift key is held down during boot
IBM Aptiva BIOS
Press both mouse buttons repeatedly during the boot
Using the Motherboard "Clear CMOS" Jumper or Dipswitch settings
Many motherboards feature a set of jumpers or dipswitches that will clear the CMOS and wipe all of the custom settings including BIOS passwords. The locations of these jumpers / dipswitches will vary depending on the motherboard manufacturer and ideally you should always refer to the motherboard or computer manufacturers documentation. If the documentation is unavailable, the jumpers/dipswitches can sometimes be found along the edge of the motherboard, next to the CMOS battery, or near the processor. Some manufacturers may label the jumper / dipswitch CLEAR - CLEAR CMOS - CLR - CLRPWD - PASSWD - PASSWORD - PWD. On laptop computers, the dipswitches are usually found under the keyboard or within a compartment at the bottom of the laptop.
Please remember to unplug your PC and use a grounding strip before reaching into your PC and touching the motherboard. Once you locate and rest the jumper switches, turn the computer on and check if the password has been cleared. If it has, turn the computer off and return the jumpers or dipswitches to its original position.
Removing the CMOS Battery
The CMOS settings on most systems are buffered by a small battery that is attached to the motherboard. (It looks like a small watch battery). If you unplug the PC and remove the battery for 10-15 minutes, the CMOS may reset itself and the password should be blank. (Along with any other machine specific settings, so be sure you are familiar with manually reconfiguring the BIOS settings before you do this.) Some manufacturers backup the power to the CMOS chipset by using a capacitor, so if your first attempt fails, leave the battery out (with the system unplugged) for at least 24 hours. Some batteries are actually soldered onto the motherboard making this task more difficult. Unsoldering the battery incorrectly may damage your motherboard and other components, so please don't attempt this if you are inexperienced. Another option may be to remove the CMOS chip from the motherboard for a period of time.
Note: Removing the battery to reset the CMOS will not work for all PC's, and almost all of the newer laptops store their BIOS passwords in a manner which does not require continuous power, so removing the CMOS battery may not work at all. IBM Thinkpad laptops lock the hard drive as well as the BIOS when the supervisor password is set. If you reset the BIOS password, but cannot reset the hard drive password, you may not be able to access the drive and it will remain locked, even if you place it in a new laptop. IBM Thinkpads have special jumper switches on the motherboard, and these should be used to reset the system.
ALSO, HIREN'S BOOT CD HAS SOME BIOS PASSWORD CRACKERS ON IT IF THIS DOESN'T WORK.
Oct 21, 2010 | Toshiba Computers & Internet
Removing bios password of toshiba portege 4010
HOPE THIS HELPS...BE SURE AND READ ALL BEFORE STARTING...GOOD LUCK
AWARD?SW J256 syxz
AWKWARD j322
awkward
VOBIS & IBM merlin
Dell Dell
Biostar Biostar
Compaq Compaq
Enox xo11nE
Epox central
Freetech Posterie
IWill iwill
Jetway spooml
Packard Bell bell9
QDI QDI
Siemens SKY_FOX
TMC BIGO
Toshiba Toshiba
Toshiba BIOS
IBM Aptiva BIOS
Oct 16, 2010 | Toshiba Computers & Internet
Compaq 6735s notebook pc goes to HP screen, but wont boot
First you need to determine how many blinks you are getting when you try to power on the laptop.
Check the blinking codes below and reason behind that for HP Compaq laptops
Blinking battery power LED Battery Insufficient charge on the battery
Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional
Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional
Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock - System board General system board failure
Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure
Plz get back so I can suggest you the steps to resolve the issue.
Dreamkam
May 24, 2010 | HP Compaq 6735s Notebook
I have an acer laptop 2920 i lost the password which has locked
There is only one way to clear cmos (BIOS) passwords and I'll show you the procedure.....
Steps for Clearing BIOS Password Check
If users set BIOS Password ( Supervisor Password and/or User Password ) for a security reason, BIOS will
ask the password during systems POST or when systems enter to BIOS Setup menu. However, once it is
necessary to bypass the password check, users need to short the HW Gap to clear the password by the
following steps:
q Power Off a system, and remove HDD, AC and Battery from the machine.
q Open the back cover of the machine, and find out the HW Gap on M/B as picture.
q Use an electric conductivity tool to short the two points of the HW Gap.
q Plug in AC, keep the short condition on the HW Gap, and press Power Button to power on the
system till BIOS POST finish. Then remove the tool from the HW Gap.
q Restart system. Press F2 key to enter BIOS Setup menu.
q If there is no Password request, BIOS Password is cleared. Otherwise, please follow the steps and
try again.
NOTE: The steps are only for clearing BIOS Password ( Supervisor Password and User Password ).
Below is the picture showing the location of the jumper next to the memory module slots. This is the jumper connections that have to be "shorted".
Jan 28, 2010 | Acer Aspire 4720 Notebook
Bios passward
 How to Bypass BIOS Passwords
BIOS passwords can add an extra layer of security for desktop and laptop computers. They are used to either prevent a user from changing the BIOS settings or to prevent the PC from booting without a password. Unfortunately, BIOS passwords can also be a liability if a user forgets their password, or changes the password to intentionally lock out the corporate IT department. Sending the unit back to the manufacturer to have the BIOS reset can be expensive and is usually not covered in the warranty. Never fear, all is not lost. There are a few known backdoors and other tricks of the trade that can be used to bypass or reset the BIOS
Before attempting to bypass the BIOS password on a computer, please take a minute to contact the hardware manufacturer support staff directly and ask for their recommended methods of bypassing the BIOS security. In the event the manufacturer cannot (or will not) help you, there are a number of methods that can be used to bypass or reset the BIOS password yourself. They include:
Using a manufacturers backdoor password to access the BIOS
Use password cracking software
Reset the CMOS using the jumpers or solder beads.
Removing the CMOS battery for at least 10 minutes
Overloading the keyboard buffer
Using a professional service
Please remember that most BIOS passwords do not protect the hard drive, so if you need to recover the data, simply remove the hard drive and install it in an identical system, or configure it as a slave drive in an existing system. The exception to this are laptops, especially IBM Thinkpads, which silently lock the hard drive if the supervisor password is enabled. If the supervisor password is reset without resetting the and hard drive as well, you will be unable to access the data on the drive.
Backdoor passwords
Many BIOS manufacturers have provided backdoor passwords that can be used to access the BIOS setup in the event you have lost your password. These passwords are case sensitive, so you may wish to try a variety of combinations. Keep in mind that the key associated to "_" in the US keyboard corresponds to "?" in some European keyboards. Laptops typically have better BIOS security than desktop systems, and we are not aware of any backdoor passwords that will work with name brand laptops.
ALFAROME ALLy aLLy aLLY ALLY aPAf _award AWARD_SW AWARD?SW AWARD SW AWARD PW AWKWARD awkward BIOSTAR CONCAT CONDO Condo d8on djonet HLT J64 J256 J262 j332 j322 KDD Lkwpeter LKWPETER PINT pint SER SKY_FOX SYXZ syxz shift + syxz TTPTHA ZAAADA ZBAAACA ZJAAADC 01322222
589589 589721 595595 598598
AMI BIOS backdoor passwords:
AMI AAAMMMIII BIOS PASSWORD HEWITT RAND AMI?SW AMI_SW LKWPETER A.M.I. CONDO
PHOENIX BIOS backdoor passwords:
phoenix, PHOENIX, CMOS, BIOS
MISC. COMMON PASSWORDS
ALFAROME BIOSTAR biostar biosstar CMOS cmos LKWPETER lkwpeter setup SETUP Syxz Wodj
OTHER BIOS PASSWORDS BY MANUFACTURER
VOBIS & IBM merlin
Dell Dell
Biostar Biostar
Compaq Compaq
Enox xo11nE
Epox central
Freetech Posterie
IWill iwill
Jetway spooml
Packard Bell bell9
QDI QDI
Siemens SKY_FOX
TMC BIGO
Toshiba Toshiba
TOSHIBA BIOS
IBM APTIVA BIOS
Password cracking software
The following software can be used to either crack or reset the BIOS on many chipsets. If your PC is locked with a BIOS administrator password that will not allow access to the floppy drive, these utilities may not work. Also, since these utilities do not come from the manufacturer, use them cautiously and at your own risk.
Cmos password recovery tools 3.1
!BIOS (get the how-to article)
RemPass
KILLCMOS
Rate this Solution.
Jan 05, 2010 | Acer Aspire 4315 Notebook
I cant reset the bios password on a fujitsu lifebook n6410
You can find bios clear jumper on motherbord most of it is near cmos cell.
Put it to 2-3 position then power up then again put it in original position 1-2
then check.
Also you can reset all settings with pull out cmos cell for 15 minutes then it not need password.
Try again.
If you need more assistanse let me know.
Thanks.
Aug 24, 2009 | Computers & Internet
Hard drive locked
First check in bios that your harddisk is detected or not?
You can ente rin bios with following method:
When u powerup press F2 or "del" F1 key to enter in bios.
but if u have problem of bios password followbelow procedure
here are 2 password type first 1 is bios password if tell me about your bios password it prompt when u powerup follow procedure below
For that you need to reset factory defaults settings for bios.
For reset bios u have to open back side of your laptop then u find motherbord circuit there.
pull cmos cell on motherbord for 15 minute then it reset to defaults.
Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear"
It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset.
then again set it in 1-2 its original position.
Then it not want password.
And if u tell about windows password
Then when you power up the computer press F8 key then enter in safe mode then wait until it prompt for user passsword
then enter in administrator then if u able to enter then reset your password.
But if u set and forgot default administrator password then u should need winxp recovery disk.
Jun 15, 2009 | ASUS M5N PC Notebook
Acer Aspire Bios Password Problem
CmosPwd is a cmos/bios password recovery application.
Follow the instruction on this site.
Copy and paste this link into your browser.
http://www.cgsecurity.org/wiki/CmosPwd
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 16, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
