Question about Echo Gas Blower 135 MPH390 CFM Blower PB250
I did a tune up on my pb-250 echo blower changed the plug changed the fuel filter and air filter primed it cold started it switched it to run while holding down the throttle and it runs for about a minute, then it wants to stall out. I repated the procedure and this time i loosened the bleeder screw till a little bit of fuel came out and it started to rev faster but once i tighten it it wanted to stall?
  • 398 Answers
SOURCE: runs for a little while the blower it is echo pb 620
these do this all the time just let it sit for 10 minutes and it should fire back up.
Posted on Feb 27, 2009
  • 641 Answers
SOURCE: Echo backpack blower stops after 20 minutes
Make sure the fuel tank cap inlet valve is working properly, this will allow a vapor lock if it is not. Then check the fuel line in tank to make sure the pickup filter is not hung up in tank thereby allowing the fuel to get below the pickup. Also check the fuel line for holes. You can also try toro.com customer care, manuals and parts, type in model no. then get owners manual and see if in troubleshooting section it list this problem.
Posted on Apr 06, 2009
SOURCE: echo gas leaf blower bog down
Likely dirt in high speed needle valve(H); could be leaky fuel line(air leaking in), plugged fuel filter, pinched fuel line, etc - anything restricting flow of fuel. Likely, you aggravated an existing problem by cleaning the air filter which would have been providing some choke effect if it were partially plugged.
Posted on Sep 24, 2009
backwoodsctr
  • 169 Answers
SOURCE: brand new echo pb-251 blower, used it 3 times for
you can thank the EPA for your blower problem the EPA makes all brands of lawn equipent "tamper proof" with plugs and limit caps. not just echo......when we service an echo piece of equipment we let it "break" in and adj the carb as needed BEFORE it leaves my shop. dont hesitate to bring it back to the dealer, if they are reputable, they will do the adj while you wait......hope this helps. good luck
Posted on Nov 21, 2009
  • 14 Answers
SOURCE: We just bought an echo pb 250 leaf blower and
sounds like its not getting gas in the carberator yet. even though its new i would take off the air breather and pour a small amount of gas in airtake. this might get it started enough to prime the carberator and draw the gas on its own.
Posted on Jul 05, 2010
A 250n Echo lawn blower.
Lyndon - Did you try changing the fuel filter? You will find it at the end of the fuel line in the gas tank. Give it a try.....
Jul 15, 2016 | Echo PB-250, Handheld Blower,
Echo PB 251 won't run. replaced plug, gas, fuel filter, air filter. took carb a part, and cleaned with carb cleaner, used the compressed cleaner to clean out venturis/ports.
Wow! with all you have done it should run. Be sure the switch is on but if you are getting spark, it should be on. I would take it to the echo place for service.
May 14, 2015 | Echo Garden
Echo PB 200- finally got it running right, sounded great. Pulling fuel and priming pretty easy. Let it run and then shut it off to put air filter back on it. Now it won't start. I was getting inconsistent...
Do u have the kill switch on or the choke closed did you foul the plug take it out and clean it do u have the right fuel mix in it 50 to 1
Jan 22, 2015 | Echo Garden
Echo PB-251. Wont run full speed,changed ,plug,filters
I'm 99.9% sure it's the fuel line. The ethnoll in gas really shrinks the oem fuel lines
Jan 13, 2015 | Echo Pb-251 Leaf Blowers
Need a tune up kit
on a 2 cycle engine change the spark plug and air filter fresh fuel
Jul 03, 2012 | Echo Garden
My Echo PB-251 will not start.
I know you checked the plug, but it can fire outside the cylinder and then not fire under compression.
If you have compression, fuel, and spark at the right time you should get combustion.
Jun 28, 2012 | ECHO, Inc. PB-251C Handheld Blower
My Echo Leaf Blower (PB-251) will not run at high speed. It is running to rich. Help please. Charlie
I've been fighting with an Echo PB-251 blower and an Echo SRM-225 string trimmer since near the end of last lawn season (this is the forth season I've had them). Along comes a thread on a firearms forum and lo and behold the answer to the problem is spelled out in terms even I can understand.
After reading that thread (which attributes the problem of the engine bogging down when throttle is activated to collapsing fuel lines) I was going to just replace the fuel lines, but I discovered that there are kits that include new fuel lines, rubber grommets, filters, clips and cap seals for about $13.00 each. Hell, the kit for the SRM-225 even provided a new primer bulb. Ten minutes after the UPS truck delivered them to my door I had both machines running like new again. If you've tried other things and it still hasn't worked I highly suggest you try this.
Jan 05, 2011 | ECHO, Inc. PB-251C Handheld Blower
Echo pb-260l won't spin up. replaced carb, plug, fuel filter and
i have aecho pb 260l backpack style leaf blower and it will not start. it turns over well and has spark and reasonably new fuel. any thoughts
Jul 17, 2009 | RTO Echo 25.4 Cc Backpack Leaf Blower -...
Echo Gas Blower 135 MPH390 CFM Blower PB250 Logo
193 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
