When i try to use the menu options on the TV it keeps flashing a box saying panel locked. need to find out how this can be deactivated
  • 1,591 Answers
You didn't specify the model so here's the generic trial and error method that works for most TV s
Press and hold the menu button for 10 seconds or until it says the panel is unlocked.
If that doesn't work, start trying the same method with each of the buttons on the TV.
Posted on Apr 11, 2011
Update firmware lcd tv toshiba 32pb10e
How to Update Toshiba TV Firmware
  1. Plug a USB flash drive in to an available USB port on your computer and copy any files from the drive that you want to keep into a separate folder on your computer.
  2. Format the drive as a FAT32 file system. This erases all of the files currently on the USB flash drive.
  3. Click here to open the Toshiba Support home page.
  4. Click "Product Support" in the menu along the top of the home page. The Product Support drop-down menu opens.
  5. Select "Televisions" beneath Choose Category.
  6. Select your type of Toshiba TV beneath Choose Family. For example, options include 3D TV, LCD TV and LED TV.
  7. Select your Toshiba TV model beneath Choose Model.
  8. Click the red "Go" button to the right of the Choose Model section after selecting your Toshiba TV model. The product support page for that specific TV model will be displayed.
  9. Select the "Downloads" tab. If there are no downloads available for your TV model, either your won't be able to click the tab or there will be a message within the tab that says there are no downloads at this time. If this is the case, no firmware updates are available for your Toshiba TV. Check back periodically, as firmware updates are released as needed and aren't scheduled.
  10. If there is content in the Downloads section, look in the Category section for an item titled TV Firmware. If this option doesn't appear, no firmware update is available. However, if this option does appear, click the clickable link associated with the firmware. The TV Firmware Update and Release Notes dialog box appears. In this dialog box you can see the size of the firmware update file, when it was released, exactly what it addresses and more.
  11. Click the red "Download Now" button and save the file to your connected USB flash drive.
  12. Extract the contents of the ZIP file on the USB flash drive.
  13. Disconnect the USB flash drive from the computer after the firmware update file saves successfully to the device.
  14. Power on the Toshiba TV and then connect the USB flash drive to the USB port on the Toshiba TV.
  15. Wait a few moments for the "Firmware file is detected in USB" dialog box to appear on the screen. Select "Yes" to update the firmware. A progress bar displays on the screen. Be careful not to turn your TV off while the firmware is updating. The progress bar changes to a "Success!" message after the update successfully installs.
  16. Disconnect the USB flash drive from the TV and then restart the TV. After the TV restarts you can resume using the TV as you normally would.
May 22, 2014 | Televison & Video
Menu option automatically appears
Reset the TV to its factory settings. You might have to enter its service mode to do this. A skilled work indeed. Anyway visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy. Some times, the ads attached with each posts might help you to find the availability of spare parts. There are more than 640 posts to different brand TVs.
Aug 19, 2012 | Sony Televison & Video
How to deactivate parental control
Hi Ida,
If you don't have the password to deactivate partental control you can do the following:
Power on TV, Press MENU and select "Parental Controls". Simultaneously press the CH+ and VOL+ buttons on the front panel of the TV for 8 seconds.
An on screen box should appear, select a new password if desired or leave blank for no parental control lock.
Hope this helps, Gary
Oct 15, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Connected the cables to the TV and cable box, but when trying to set up the TV for the first time, I selected cable/satellite box and it keeps wanting me to run a channel scan, when I go into the menu to...
okay lets do a cable check... cable from wall /outside connected to cable box in, from the cable box out to (please note any DVD recorder or VCR should be connected here if you have and then on to TV) TV in ..... TV on , turn to channel 3 (this should be the only ch locked on the TV no scan is needed) you are using coaxial cables... if this was/is a hi def connection (your set should be on component)
Dec 19, 2010 | Dynex DX-LCD37 TV
My sis gave me an old samsung tv. It is just for my son and his x-box. Unfortunately there is no remote control. When switched on it is saying PANEL LOCK. Is there any way i can fix this. Model No TI-14N3....
hello you could try this The front panel of the COMBI VISION can be locked to prevent it
from being used by young children for example.
1 To lock the front panel, display the television menu by pressing MENU
2 Select the SETUP option by pressing the P ▲ or ▼ buttons the required
number of times.
3 Press the + button.
4 Select the PANEL LOCK option by pressing the P ▲ or ▼ buttons the
required number of times.
5 Select ON by pressing the + button.
Result: The buttons on the front panel no longer have any effect.
6 To unlock the front panel, set the PANEL LOCK option to OFF.Another option would be to buy a universal remote from say - Argos carefully open it and use your own batteries and use that remote to unlock the TV then return the remote to Argos or if keep the remote if the original is lost. i hope it helps
regards
shaun
Jan 12, 2010 | Samsung Televison & Video
Sony DAV DZ230 Child Lock
hello You can deactivate the buttons on the unit
(except for "/1) for preventing misoperation,
such as child mischief (child lock function).
When the child lock function is activated, the
buttons on the unit are locked and “ ” lights
up in the front panel display. (You can operate
the system by using the remote.)
Note
•When you operate the buttons on the unit while the
child lock function is on, “CHILD LOCK” appears in
1 Press SYSTEM MENU.
2 Press
X/x repeatedly until “CHILD
LOCK” appears in the front panel
display, then press or
c.
3 Press
X/x to select a setting.
The default setting is underlined.
• “OFF”: Child lock function off.
• “ON”: Child lock function on.
4 Press .
The setting is made.
5 Press SYSTEM MENU.
The system menu turns off.
Tip
• You can activate the child lock function by pressing
x for more than 5 seconds (“ ” lights up in the
front panel display).
To cancel, press x for more than 5 seconds so that
“ ” disappears from the front panel display.
Deactivating the Buttons
on the Unit good luck
shaun
Sep 12, 2009 | Audio Players & Recorders
Lg hotel tv. t.v. button are locked out, only hotel remote works
Hold down the MENU button on the remote for approx 5 seconds. Then enter 1105 this will access the hidden hotel option on the LG tv so you can change whatever you like..
Cheers LITTLE DISH FITTER
Jun 08, 2009 | Televison & Video
Deactivate parental lock ESA 27" TV HELP!!!
You may have solved the problem by now, but if you go into the menu and choose V Chip rating, then TV Rating. All the choices should say [VIEW]
Jan 05, 2009 | ESA ET427E 27" TV
Hitachi 46w 500 screen says locked
reset the tv by pressing the reset button.
Aug 21, 2008 | Televison & Video
V chip password
Parental Guide On (Activate V-Chip)
Selecting this option lets you activate and deactivate parental control settings.
1. Press MENU on the remote control (the Main menu appears).
2. Press the button until the Parental Control icon is highlighted.
3. Press the button until the bottom PASSWORD is highlighted.
4. Enter your password using the numbers buttons on the remote (the PARENTAL GUIDE menu appears).
5. Press the button to highlight PARENTAL GUIDE OFF, then press the button to turn it on. It must be
on for rating limits to take effect.
If you do not activate V-Chip, none of the settings for V-Chip will take effect.
If you forget your password, you can reset it. Enter 5898 as the password and then change it to a new one.
Child Lock
Selecting this option lets you lock (disable) or unlock (enable) the TV’s front panel. The remote still tunes to
any channel. When using this as a Parental Control method, remove access to any remote that is capable of
operating the television.
5. Press the button to highlight CHILD LOCK, then press the button to turn it on.
Change Password
Selecting this option lets you simply create a new password at any time. Once you enter a new password
from CHANGE PASSWORD in the PARENTAL CONTROL menu, it is the password you use until you change it
again.
5. Press the button to highlight CHANGE PASSWORD, then press the button to select it.
6. Press the button to highlight NEW PASSWORD, and use the number buttons on the remote to enter
the new password. Enter it again in the confirm field to confirm the new password.
Mar 20, 2008 | RCA 20F510TD 20 in. TV/DVD Combo
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
Electro Med Services...
