Question about Frigidaire FRS26R4A Side by Side Refrigerator
Compressor buzzes loud & frig does not get cold
You recommended the following for my problem. "That can also mean that the starter is broken.which will be a cheaper fix than a new compressor.Also the capacitor can be broken and that will give the same results.
Please click HERE for drawing and parts( #30 is starter #55 capacitor)"
I purchased the parts and just received today. I installed and problem continues. The buzzing goes on for about 10 seconds and then goes off for a few minutes. This continues until I pull the plug. The frig just has warm air flowing into it while plugged in.
  • 487 Answers
Ok one thing to check before you start purchasing a new compressor which at this point sounds like the problem.It might be that the hot tube has sprung a leak or the heat exchanger. Problem with on-line advice is that i can not see and put my hands on it.You have to check if you still have pressure on the system. If you do not have any pressure the compressor will run dry heat up and stop as the thermal resistance gets too big. I think there is a repair kit for the heat exchanger and or the hot tube.
1-800-374-4432.1 is the number for frigidaire service techs. They should be able to confirm this.
double check with them and than pls come back to me
Posted on Aug 07, 2008
Refrigerator makes a loud thud every 15 minutes
compressor has a broken spring inside. only way to fix it is replace compressor. call management.
May 07, 2017 | Refrigerators
Warm air in frig and freezer
have you tried cleaning the condensor coils?
Apr 25, 2011 | Refrigerators
Constant loud noise when frig turns on/comes from bottom
when the compressor is running unplug the ref. and if you hear the noise coming from the compressor then
a ballance spring may be broken inside the compressor.
The compressor will run normally with a broken spring it will just be annoying when it shuts down.
Jan 16, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Freezer has stopped
If it is a frost free side by side fridge/freezer, check evaporator fun in the freezer. While doing that, check is evaporator is full of ice.
if the evaporator is iced up and the fan can spin freely, you have a broken fan. Replace it.
If evaporator and the fan are iced up, you have a broken thermostat. Defrost ice with hot water.
Turn it on, if it starts to cool effectively, replace thermostat.
Oct 11, 2009 | Refrigerators
Here are the unit's issues: 1. freezer won't stay cold and 2, a loud buzzing sound can be heard periodically Any idea what's causing these defects Thank for any help you can offer
Sound's like the start relay overload on the compressor if you hear a humming and a click do not leave plugged in get new relay/overload at you local part store or the compressor winding will burn up and a new frig will occur message me if this is the sound and inconsistent cooling temp b4 you heard the buzzing and click take you model # to the parts store an easier repair which is good....
Aug 24, 2009 | Kenmore Freezers
Frig makes a very loud booming noise/ratteling what is the cause?
The noise is coming from the compressor and is a result of a broken support spring inside the compressor. When the unit shuts down, the inner casing rattles against the outer casing because the spring is not there to keep them apart. The only fix is to replace the compressor but otherwise it is just bothersome.
http://tclaundryrepair.com/home
Feb 19, 2009 | Kenmore Refrigerators
Compressor intermittently starts, loud humming when it doesn't
get a 3 and 1 relay that will help boost the start windings on the compresor and help it start-up. get the one for 1/2 hp and you shoiuld be good to go.
Jan 29, 2009 | Amana ACD2232HR Side by Side Refrigerator
I hear a buzz sound for 5 seconds when compressor starts.
The grommet simply holds the start relay in place.  Unless it is torn, you won't need it.  Likely the start relay.  The buzzing is possibly the relay contacts on the start relay burning if the problem occurs when the compressor starts...although it could be the compressor making noise as well.  You might try to "hear it out".  The start relay gives a boost to the compressor by adding in another winding inside to 'kick' the compressor.
If all you hear is the buzz, you might just wait a bit to see what fails!
Nov 14, 2008 | Refrigerators
Jul 28, 2008 | Frigidaire FRS26R4A Side by Side...
Loud buzzing noise from compressor area and freezer not cold enough
I have a 1.5 year old GE refrigerator and freezer. This unit had not given me any problems until 2 days ago when I constantly heard a loud buzzing sound coming from the freezer. I called GE and Best Buy (bought it there) and asked to troubleshoot this over the phone. They suggested sending a technician over for $100 just for the visit + labor + parts which could add up to hundreds of dollars. So, I researched the web and blogs like this. The answer to my problem was simple. Something that I placed inside the freezer was blocking the air circulation vent. So, I turned off the whole refridgerator and I removed everything from my freezer. For good measure I dislodged some ice and frost that had developed over the vent. I carefully put back everything into the freezer, but this time being careful not to block the vent. I turned on the power and voila! No more buzzing sound!!! I hope this works for you too.
Oct 31, 2007 | Refrigerators
Frigidaire FRS26R4A Side by Side Refrigerator Logo
121 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
