Question about Lasko 3300 Wind Machine Fan
How do i clean a lasko 3 speend wind machine. The blades inside of it are dirty and need cleaned
SOURCE: lasko tower fan with ionizer
Try a can of compressed air. It's impossible to get inside.
Posted on Jul 22, 2008
  • 3 Answers
SOURCE: how do I clean my Lasko fan with Ion?
Yes unscrew the screws and thre will be more screw to undo insode to take it apart. I had to do mine an it was filthy! Good luck!
Posted on May 18, 2009
jennerina
  • 86 Answers
SOURCE: How does the
I'm not exactly sure, but I think that an IONIZER has nothing more than metal blades inside that 'capture' dust/debris and contaminants from the air on the blades. There should be a handle to lift up on and remove the long blades.
You rinse the blades with warm soapy water, dry them and put them back in. Maybe I'm thinking of something else, but to me, that is what an ionizer is. Hope this helps at least some.
Best, Jennifer
Posted on Jul 08, 2010
SOURCE: Cleaning
Model E20739: The entire back comes off to expose the fan blades after removing two screws. Just unplug the unit. On the back of the unit near the top is a recess that acts as a carrying handle. In that area you will see two large silver-colored screws. Remove these, grasp the back of the unit and push down on it as you pull it away from the body of the fan. You may have to wiggle it around a little to free it.
Posted on Sep 03, 2010
SOURCE: Is there a means for
The fan and motor are both easily disassembled with a Phillips screwdriver and some gentle force to remove the blades. Try to use even pressure when removing both the blades and opening the motor housing. The only questions are whether to flush the existing lubricant out of the bearings and what to replace it with. If you know what to use it shouldn't be a problem. If anyone could suggest an oil or grease, please do.
Posted on Jul 13, 2011
How do i remove the actual blade unit from the backing on my lasko wind tunnel remote?
the blades are held on with a left handed thread for the center
undo tat by turning it clockwise and then the blades will slide off the shaft
Nov 04, 2017 | Lasko 20" Stylish Wind Tunnel High...
How do I clean the blades on my lasko E20739 fan
Do you have the still have the e20739 lasko fan, i need the plastic blade on the unit
Jul 19, 2010 | Lasko 48" Xtra Air Tower Fan with Air...
How does the "Ionizer" work on the Lasko 48" Wind Curve Tower Fan ? Shouldn't there be a HEPA filter to change or something to clean once in a while ??
Best, Jennifer
Jul 08, 2010 | Lasko 48" Xtra Air Tower Fan with Air...
Filter
If this one is like mine (and it looks just like it except my Lasko doesn't have the wood grain on the front) there is no filter inside. It is just a fan inside a plastic case.
If you want to clean it, you can try blowing it out with compressed air if you have a powerful enough compressor. If you really want to clean it, you will have to take it apart and that isn't as simple as it sounds if your unit is just like mine.
There are a bunch of screws on the back, which isn't too bad except one of them is a triangle headed "security screw" that is probably there to keep you from taking it apart. I looked at several stores and couldn't find a screwdriver to fit the stupid thing. So what I did was that I took out the rest of the screws, pried the case open as far as I could with my hands and cut the support that the last screw was attached to from inside with a strong pair of wire cutters.
I figured that when I put it back together, I wouldn't miss that one screw and I wouldn't want to deal with a triangle head screw every time I took it apart in the future anyway.
Once the case is apart, I found the best way to clean the blades is to remove the whole blade assembly and just wash the thing out in the tub and let it dry thoroughly before putting it back in. There's a metal brace (Held on by two screws) at the top the top spindle goes into and there's a single screw on the shaft of the motor that hold the bottom spindle in. It probably sounds more complicated than it is. It's pretty simple when you see it.
If you put it back together right, you almost can't do anything wrong. You might want to take a damp cloth and wipe down the interior of the case and the shrouds that surround the blades as well. If you've had it a while, they'll be dirty. You'll see/feel the dirt wherever it is. This thing is a pretty simple machine and is easy to clean once you figure it out. I put a few drops of oil on the top spindle when I put mine back together.
May 21, 2010 | Lasko 2554 WIND CURVE Fan
I have a Model #3510 Lasko Cyclone Fan and the blades are dirty
Steam works great, otherwise you can use a degreaser and hose it off. Make sure you let it dry completey and then some before plugging back in.
Aug 26, 2009 | Dryers
Are there any points to be oiled on the Wind Curve fan; how much; how often?
you need to dismantle the fan.
there are 4 screws under the base
and 16 to the back
top and bottom of the blade is to be oiled
as often as it get dirty.
Aug 01, 2009 | Lasko 2554 WIND CURVE Fan
Cleaning my 2554
there are 20 screws to take apart the fan.
but try this
something to wedge the blade and blow out the fan. it will work jus the same
Jun 28, 2009 | Lasko 2554 WIND CURVE Fan
Lasko 3520 20-Inch Cyclone fan - disassemble fan for cleaning?
How do I clean my Cyclone or Air Companion™?
Lay the fan face up on a flat surface. The front grill should be facing you. Remove the screws from the rear grill. Place a flat-head screwdriver into the gap between the front and rear grills. Pull the front grill towards you, exposing the fan blade. Do not remove the knobs on either side. Then, wipe the blade with a soft, damp cloth. Use a mild detergent if necessary. Be sure not to touch the motor. Click here to download product instruction sheet.
Jun 08, 2009 | Dryers
Lasko 3300 Wind Machine Fan Logo
168 people viewed this question
Top Lasko Dryers Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
