Question about SanDisk 2GB microSD Memory Card
Hi my memory card is saying it is not formatted how to solve this problem in a computer through reader when i format it it shows window is unable to format
  • 59 Answers
The card may have become corrupted or unreadable. Windows should be able to format this card without a problem. As long as the card is inserted properly there should be no reason Windows cannot format it; I know someone else out there may tell you something different, but without testing the card and being able to do more thorough troubleshooting this would be my best guess at what's wrong.
Posted on Apr 11, 2011
I can not formate my SD memory card it shows windows was unable to formate
You will need special formatting software from the disk maker. Windows XP will not normally format a sd memory card.
Dec 21, 2013 | Electronics - Others
Greetings! I have a SanDisk M2 memory card for my
-u- can always contact geek patrol tell them what -u- -r- going through they may have the answer -u- -r- looking for//
Oct 29, 2013 | Electronics - Others
Memory card
Are your phone and/or computer's card reader compatible with microSDHC cards or only with microSD cards?
May 02, 2013 | SanDisk 4GB microSD High Capacity Memory...
I can't format my memory card.it shows cannot format.please help me
Most likely, if you're getting a message that says unable to format, your memory card is already corrupted. But if you want to make sure, try to use another card reader or another PC to format it.
Jun 28, 2011 | SanDisk 2GB microSD Memory Card
I have a sandisk 2gb micro sd card. I put it into my computer's card reader and it keeps saying it needs to be formatted. When I try to format it it says windows was unable to complete the format. I am...
The FORMAT process is trying to write data to the card, but that writing is NOT successful,
i.e., the memory on the card is damaged/defective, and so it "fails".
Responsibly recycle the card, and purchase a replacement memory-card.
Jan 30, 2011 | SanDisk 2GB microSD Memory Card
When iam opening memory card in nokia 3110c it is saying memory card not formatted operation failed.please guide me what to do
Hi, problem can solved.When a memory card says formatted operation failed,it means the memory has been affected with VIRUSin it,thats why it's not given you access to get into it.
What you will need to do is to format it.
You can use your phone to format the memory card by going to the option of the memory card and click on format memory card.
Also you can use a PC to format the memory card by using a memory card reader. insert the memory card inside the card reader and connect to your PC, click on my computer, you will seethe memory card icon displayed, right click on the mouse for options to come up, and click on format memory card and you done.
Note: When trying to format and it does not format the memory card, that means the VIRUS that affected the memory has damaged it totally, that means you will have to get a replacement memory card.
Thanks for using fixya....
Jan 11, 2011 | Nokia 3110 Cellular Phone
Unable to format 2GB sand disk memory card
Hi Sir ^^
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Jun 14, 2010 | SanDisk 2GB microSD Memory Card
    Unable to format the mirco sd card when using it in my computer
    LLFTOOL is a utility for low-level disk drive formatting,
    also supports formatting of FLASH cards using a card-reader.
    1. Download this tool:
    http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
    2. Format memory caard
    (WARNING: After running this low level format tool,
    the whole USB flash disk surface will be fully erased.
    Therefore, data restoration will be impossible after using this utility!)
    Feb 17, 2010 | SanDisk 2GB microSD Memory Card
    Error 8022008B.....
    If it is having trouble formatting in a PSP try taking it out and formatting it on your PC in Windows. Hope this solves your problem!
    Please rate!
    Cheers
    Oct 04, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
    Help with memory card saying unable to format
    Hi Eric :)
    Please try formatting the Memory card using your computer first in the following manner:
    >> Insert the memory card into memory card slot / memory card reader
    >> Check the drive letter that it has been assigned by the computer
    >> Right click on the drive and select Format option
    >> Now this is very important.. Select FAT file system from the drop down options (DO NOT select FAT32).
    >> Now Format the card and then try formatting the same card in Camera.
    Let me know if that works for you.
    Regards,
    Srinivas
    Apr 03, 2009 | HP Hewlett Packard Photosmart 425 Photo...
    SanDisk 2GB microSD Memory Card Logo
    77 people viewed this question
    Top SanDisk Electronics - Others Experts
    k24674
    Carlos Calvo
    Level 1 Expert
    Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
