Question about Sharp AQUOS LC-26DV22U 26" LCD TV
I need to access the menu with no remote on a lc 26dv22u sharp TV
5 Suggested Answers
SOURCE: remote control tv codes for sharp lc-32sb24u tv
I need the remote codes for sharp LC-32SB24U tv. Thank you!
Posted on Nov 23, 2008
dsacco86
  • 1077 Answers
SOURCE: need help programing a directv remote to a sharp tv, model # lc46sb54u
I know what you mean. :(
I couldn't get mine to work with my Emerson TV. No codes worked.
You may have a chance with yours. Try this link here to get and program the codes:
http://www.directv.com/DTVAPP/global/contentPage.jsp?assetId=P4350020#
Then if does control the TV, hopefully the input button on the remote will work.
Posted on May 12, 2009
dsacco86
  • 1077 Answers
SOURCE: My Sharp TV will only hear sound. No picture or images even from the tv menu setup option. Model# LC-19SB25U. About 1.5 yrs old. Converter box ok.
In most cases, you can reset the TV by leaving it unplugged for 30mins.
If this doesn't work, I believe the circuit board that supplies power to the screen maybe bad. They call this board a backlight inverter board. It would most likely cost more to repair than replace the TV .
Posted on May 27, 2009
SOURCE: i need sky remote code for sharp tv model no lc-32sh7e
Hi there. I hope you will see this reply. I bought one of these TV's yesterday and I've got the code from my dad's website www.satcure.net
If your remote is Version 6 then you will be able to follow the help on the sky box under
Interactive
Customer service
Program Remote
Then follow the steps using code 1221
If you have a Revolution 8 remote then you will have an easier job but with a 3 digit code.
3 digit code is 253
TO PROGRAM THE remote USING THE 3 DIGIT CODE:
1. Turn on the TV receiver
2. Press TV on the Sky Remote Control
3. Hold down SELECT and the RED buttons together for approximately two seconds, until the RED LED on the Sky remote blinks twice.
4. Enter three digit code from list for the receiver (early versions now flash twice).
5. Press select to enter code structure (the LED will flash twice if a valid code has been entered).
6. Now press the STDBY button and test other functions.
Hope this helps/works!
Posted on Jun 12, 2010
How to get in main menu on sharp lc-37p55e with no remote
Unfortunately, you can't access the menu system without a remote on the LC-37P55E. You'll need to find a universal remote with a Menu button and then you may need to try multiple codes to find one that lets the Menu button work correctly. Since the TV became available at Amazon UK in March 2006, you should look for a remote that was programmed in September 2006 or later to find one that is most likely to work with your TV. Manualslib has a copy of the manual here: https://www.manualslib.com/products/Sharp-Lc-37p55e-3204952.html .
I wish that I had better news for you.
Oct 11, 2016 | Sharp Televison & Video
I have a Sharp TV model LC-32SB24U. I cannot access the menu screen because I lost the remote control. Is there another way I can change channels without a remote?
The Sharp LC-32SB24U has menu, input, volume up/down and channel up/down buttons on the top of the TV. When you access the Menu using the buttons on the TV, the Input button is the same as the Enter key. The volume up/down buttons map to the left and right arrows. The channel up/down buttons remain up and down. The Menu button is the closest to the power button (on the right). The volume buttons are the ones on the left.
Make sure that the input is set to TV to change channels. Then you need to program the available channels, access the Menu and navigate to Setup (left/right arrows). Press Input to enter this sub-menu. Then use the Up/Down arrows to select CH Setup. Press Input again to enter. Now you can set the channel source and let the TV scan for channels that have a strong enough OTA signal or are unencrypted cable channels. These are the top two options in the Channel Setup menu. The details are available in the manual which is available here: http://static.highspeedbackbone.net/pdf/Sharp_LC37SB24U_LC32SB24U_Manual.pdf . For OTA channels, you may need to check the signal strength under the Antenna Setup - Digital option in this Setup menu. OTA Digital signals will not be tuned in if the signal strength is low. It's an all-or-none tuning; amplifiers and external antennas may help. See tvfool.com for details of transmitters and the recommended antenna for your area. (Warning: damaged amplifiers can become filters and block the signal on some channels. Replace the amplifier if it is damaged.)
If you look to replace your original remote with a universal remote, you'll need one that was programmed more than 6 months after the TV was released. That may be 12/2005 based on the manual copyright date. Look for a remote that has a Menu and Input or Source button and check all of the codes to find one that matches all of the features on your original remote. Amazon has an OEM remote for the LC-32SB24U; remotes.com also has a replacement remote available that has been programmed for the TV. (On remotes.com, search for the LC32SB24U.)
I hope this helps.
Oct 26, 2015 | Sharp LC-32SB24U 32 in. LCD TV
How to restore factory setting without remote
You will need access to the main user setup menu. With most model TV sets the original remote is required. Some of the high end universal remotes have the functions to allow access. It is best to always have the original remote for the TV set.
Jul 15, 2014 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
When u turn the TV off it keeps coming back on by itself
Ours does the same thing except that it will turn on spontaneously at any hour of the day or night randomly. I called Sharp tech support and they rebooted the tv and the remote but this did no good. I sprayed compressed air into the power switch on the top of the tv, but this did not help either. Sorry I have no answer. Since it is in the bedroom this was driving us crazy, so I junked the tv and replaced it with a Sceptre 32 LCD HD TV/DV combo from Walmart.com for less than $200. Probably taking the tv to a repair center would cost almost as much.
Apr 06, 2014 | Sharp AQUOS LC-26DV22U 26" LCD TV
Sharp tv lc 32sh12u menu
Just open the menu by using the universal remote control, and do the rest by using Up/Dn & Left/Right buttons at the the TV front panel.
Jan 29, 2013 | Sharp LC-32SH12U TV
Need a manual for sharp tv model lc-26dv20u
HI
I can provide you with the user manual of the LC-26DV22U and LC-26DV27UT, I think any one of these manual will be compatible with your tv. If you need this manual sent me your email address to which i will sent the manual. Its not possible to upload that manual through this site as it is a pdf file. Or you can contact me on my mail address. My mail address is ajingopakumar@yahoo.co.in.
OK
Dec 15, 2011 | Sharp Televison & Video
Cannot access menu with remote, can i access menu manually ?
If there is a menu button on the TV then you can, but if it isnt working on your remote then there must be a problem with the remote. You can look at the manual that came with the TV for more information on that and if you dont have one heres a link to one: http://www.scribd.com/doc/34310286/Sharp-LC-32AD5E-BK
Aug 05, 2011 | Sharp LC32AD5EBK 32 in. LCD TV
Sharp AQUOS LC-26DV22U 26" LCD TV Logo
112 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
