Question about Bowflex Treadmill Series 7
I have a free spirit treadmill that runs for about 10 seconds and ERR L5 comes on. What do I do?
4 Suggested Answers
SOURCE: MESSAGE "ERROR SPEED STALL" KEEPS COMING UP
returned the machine and got our money back, thanks.
Posted on Jun 21, 2009
  • 5 Answers
SOURCE: I get an L5 Err message and the treadmill will not move.
Not a chance this is speed sensor related, the probability that a magnetic pickup is "fried" is near zero. This is a classic over current problem caused by lack of lubrication / old belt and deck. Something on the motor controller melted (hence the smell of burning plastic). This will need to be replaced most likely although these units contain a slow blow ceramic fuse that may have tripped first. At any rate the unit should be tested for current draw before being put into regular use again.
Posted on Mar 15, 2010
  • 33 Answers
SOURCE: when the free spirit treadmill is turned on, it
HI check speed sensor, if not solve replace the control board
sada
Posted on Jun 23, 2010
HI our Bowflex series 3 treadmill is giving us a continued Err L5 code when trying to use our machine. We bought it used so do NOT have ant trouble shooting instructions. Any advice?
Hi There, L5 error should refer to the "LS" error which looks up to a speed problem. When you start the machine up, it boots fine and then when you press start or go is says err ls ? If the walking belt doesn't move at all when you try to start it, listen for a "Click" on that lower board when start is pressed..... If the walking belt moves for a second and then stops and the console says err ls, then you may have a speed sensor problem. These control boards are repaired by Jatinah Electronics who can be found with a google search. Good Luck!
Dec 13, 2016 | Bowflex Exercise & Fitness
Incline in lowest position, will not move. Shows ERR on display panel
If you wish to get some details; check the site linked here. Pull up older posts...........
http://electro-medical.blogspot.com/
May 06, 2016 | Spirit Fitness Spirit XT685 Treadmill
Err L5
this meand 2 alternatives:
1) problem with the display board adjust the reed switch
see the diagram
2) mean the elevation motor; lube the gear and shaft ,and adjustment the potentiomenter, and check the voltage input motor .
God bless you
Jun 20, 2012 | Bowflex Treadclimber
New free spirit treadmill - L5 code what does it mean?
Yeah - the sensor is the problem... It is magnetic... You can find it next to the wheel on the belt - It is fairly small.... There is a metal disc in the wheell on the belt that is a magnet.. As it passes by the sensor - the sensor registers the magnet and can simply calculate speed based on the frequency of the passes... Sometimes the sensor slides too far back and ergo can`t register the magnet passing by - Then you get the L5 error...
Follow this link to a picture!
http://www.angelfire.com/nm/nickm/freespiritl5.html
Feb 08, 2010 | Precor C954i Commercial Treadmill
Describe your Spirit ® XT275 Folding Treadmill Problem - serial number 90488105100032rev-00 I started the treadmill as I normally do by pressing the start button. The belt does not move. I think...
Hi
Thanks for using FixYa. Please read this out:
How to Troubleshoot a Treadmill
If still the issue is not resolved then you can contact local repair center.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 05, 2010 | Spirit ® XT275 Folding Treadmill
I get a reading "Err 1" and it will not run at all.
Try recalibrating your machine. Use the owners manual for the steps. This might work. I had an L5 error and it wouldn't run either. Recalibrating fixed the problem.
Jul 09, 2009 | Bowflex Treadclimber
L5 code appears after it stops on the Z500 Treadmill
hi,
LS mean low speed error, Please check the sensor wire( if moor move). if not move please check control board.
Mar 30, 2009 | Spirit Fitness Z500 Treadmill
Bowflex Treadmill Series 7 Logo
32 people viewed this question
Top Bowflex Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Glenn Mayer
Glenn Mayer
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
