I believe my PC on/off switch needs replacing since it operates rather unreliably. Where could I buy one?. Nando
  • 59 Answers
Most companies, such as newegg, have these type of parts. I would suggest going to www.newegg.com and looking up a power switch for your desktop. Hope this helps.
Posted on Apr 11, 2011
Staying in Limp Mpde with check engine light on.
first thing is to find the reason for the limp mode as it has been activated to protect the engine and transmission
do this by having the fault codes read ASAP then fixing the fault
Dec 06, 2015 | Cars & Trucks
Is it worth buying WinCleaner to optimize PC performance
No free products tend to be much better. Malwarebytes is good
Mar 26, 2014 | Logical Business Logic Ultra WinCleaner...
Mackie srm 350v2 speaker packed up
I believe there is an internal fuse in these which, according to a friend who has these, seems to blow occasionally for no apparent reason. He has also had to send two back for replacement and would not buy again, they seem to be inherently unreliable although they sound great.
Jan 02, 2013 | Mackie SRM350V2 POWERED SPEAKER
How to hook up tv for watching movies from my dell all in one 2320
Best Buy ? Bournemouth Best Buy ? if so bring it over and I will fix it for you, if not it is probably a case that you need a TV CARD, TV Cards are unreliable,
Oct 04, 2012 | Dell Inspirion One 2320 IO2320-5555BK...
Have a portable air conditioner Danby model DPAC 8399-3. Could you tell me how can I open the remote control to replace the bateries, since i lost the literature. My name : NANDO
Slide the rear cover of the remote in the directions of the way the arrows are pointing.Continue pulling gently until the cover separates completely from the unit. Insert 2 - AAA Batteries in the direction indicated inside the holder. Reinstall the cover and you're ready to go.
I hope this helped you, Nando. Thanks for choosing FixYa.
Jul 25, 2011 | Danby Heating & Cooling
I have over 150 da40 plantronics headsets in our call center we have issues with qualty and the headsets drop calls and oneway audio. The big issue that I need help with is they seem to drop conection to...
The DA40 cable (and headset) is a plug-and-play device which requires no special drivers to operate properly. I believe that the DA40 is acting like a switch between the software applications loaded onto your PC's (i.e. operating system, cosmo com call center client, etc.). Much like a light switch in an electrical circuit, where the DA40 enters the PC's circuit it is interfering (turning off) with the operation of the other systems. I would recommend getting a computer technician to check one of your stations, or the server, to see where and how the break is happening. You'll probably find that the DA40 was just an innocent by-stander that was in the wrong place at the wrong time. It's worth a shot and better than replacing 150 headsets and cables.
Good luck from Headsets Direct!
May 27, 2011 | Plantronics (33707-41) Headset
I purchased a second hand vehicle equipped with what i believe is an audiovox alarm system. The alarm likes to go off at random times and i cannot figure out what is causing it. The car is a 97 vw gti vr6....
It probably needs to replaced. Audio Vox has several models that have window breakage sensors. These sensors are notoriously unreliable and do this quite often. I would replace the alarm itself.
May 14, 2011 | Audiovox Car Audio & Video
F1 code sears Kenmore and Whirl Pool ( who make Kenmore) are very unreliable and you should never buy any thing from the above stated company's. I am 1500.00 in to this machine Oasis Elite and cant believe...
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question!!!!
Sep 17, 2010 | Kenmore Oasis HE 27082 Top Load Washer
I believe I need a operation installation disk - I never got one - when I purchased this from Best Buy in Everett Wa.
Depending on when you purchased it - please call the store or take the unit back they do free checks on the pc - - if you don't have an operating disk they will tell you free where to get one.
Mar 31, 2010 | E-Machines T5082 PC Desktop
Replacement tips for Kensington 120W AC/DC adapter model 33197
I have the same model adapter for my dell, I believe there is a number on the tip that you need, have you tried ebay for the part they are called 'smart tips'. I think it's a different adapter direct from kensington now, but you can buy them from 3rd parties.
http://us.kensington.com/html/10442.html
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=270522811796
Feb 12, 2010 | ACCO Brands Kensington Thin and Light 70w...
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
