Question about SVP HDDV-3001 Camcorder
Can not get CD music to SD card so HDDV-3001 plays them. They are stored on 3001 and play on Windows Media player. When i try to play on 3001 i get the ! of a formated blank SD card.
My GeneralPlus MSDC MP3 player shows to have music on the sd card but the player won't play
MP3 players can only play music files in mp3 file format. You can download mp3 music files from the Internet to your computer and then copy them to your MP3 player using the USB cable. For your CD collection, you need to convert your CDs to mp3 music files onto your computer or download them from the Internet and then copy them to your MP3 player after you have connected the USB cable to the MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player will create a MP3 music file for each music track. Click on this link for instruction on converting music files to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Jan 12, 2013 | Creative Labs Zen Digital Media Player
Is it possible to play the songs stored in the SD card when inserted in Sansa e260
Yes. However, all your music must be in a folder called "MUSIC".
BTW it's a microSD card, not an SD card.
May 28, 2010 | SanDisk Sansa e260 MP3 Player
I sync with my mp3 player on computer it loads then i press play on mp3 player no music but vol is on i save my music from cd straight to windows media player then sync with mp3 player
if its right you just copy the shortcut of the music from your cd to your windows media player, meaning you cannot play that song in the media player if the cd is not inserted, you have to rip first the cd to your pc then put it in your mp3. Also make sure that you rip it in the right format that your mp3 can play, media player automatically rip the music as wma not mp3, make sure your mp3 player can play wma.
Sep 28, 2009 | Audio Players & Recorders
Micro Sd keeps saying it does not contain supported music files
May be mp3 u are playing on your cell is not supported i.e. bit rate is greater than your mobile supports.
May 30, 2009 | Motorola Mobility MOTORAZR VE20 Cell Phone
Sansa 250, and media converter won't recognize new mini sd card
The Sansa will only play videos stored in its internal memory, not on a microSD card. You can put music on the card, but not videos or photos.
Dec 23, 2008 | SanDisk Sansa e250 MP3 Player
Aigo F529
I'm confused. Are you saying that you can't play files on the SD card from the computer itself? Or, the songs won't play on the mp3 player once the SD card is loaded into the mp3 player?
First, make sure the songs are in the right format - each mp3 player will only play files of a certain type. Your best bet is to only use Mp3 format files -everything else is going to give you one problem or another.
Second, there is a size limit to what type of SD card the mp3 player can read. 2GB SD cards are the absolute maximum that this player will handle, and probably only 1GB even.
Hope this helps a little.
Jul 06, 2008 | AIGO F008 MP3 Player
Sansa e250 using micro sd card
Go to the knowledge base on the Sansa site and find this (chances are you have an SDHC card in an incompatible unit):
Sansa e200
 - verify the version of the player.  To check, go to SETTINGS > INFO
For 01.xx.xx firmware (e200 version 1) - up to 2GB microSD cards
For 03.xx.xx firmware (e200 version 2) - up to 16GB microSDHC cards
NOTE: Firmware is not interchangeable.
Sansa e200R - up to 2GB microSD cards
Sansa e100 - supports SD cards up to 2GB
Nov 12, 2007 | SanDisk Sansa e250 MP3 Player
Adding SD card to my ILO
What, you actually hotwired a flash card into the Ilo? Impressive. Or are you trying to get the Ilo to play music from an SD card, when you have both plugged into the computer? If you're talking about the first, then I'd say you did a good job at NOT destroying your Ilo. If its the second, then unplug your Ilo, put your headphones into the headphones jack in the computer, and play the music from your computer.
Aug 22, 2007 | iLO (2 GB) MP3 Player
Windows media players doesnt recognize music files
Use Media Player on your computer to SYNC you music files to your phone. After files a synced, go to Media Player on phone and click right soft key MENU and select UPDATE Music/Audio Files, then select SEARCH.
Dec 05, 2006 | Audiovox SMT5600
SVP HDDV-3001 Camcorder Logo
22 people viewed this question
Top SVP Video Cameras Experts
Coss
Andrew Taylor
Andrew Taylor
Are you a SVP Video Camera Expert? Answer questions, earn points and help others
