Question about Toshiba MK8025GAS 80 GB Hard Drive
I am trying to insert my toshiba 80 gig mk8025 gas hard drive into a rocket fish 2.5 hard drive enclosure kit but it is like the pins do not match??
  • 1,591 Answers
You may just have the drive upside-down.
flip it over and it should fit...
Unless of course you got the SATA rocketfish, because your drive is PATA (ATA-6)
this is actually more likely the case!
Posted on Apr 11, 2011
Testimonial: "Thanks I will try that. I have the Pata rocket fish but I was afraid maybe the hard drive was 1.8 instead of 2.5. Thank you for your speedy response "
I have a Toshiba MK 8825AS taken from a HP NX5000 laptop. Is there a cable that will allow this to be connected to an desktop, either IDE or SATA? I need to access the data on the drive. Thanks
Yes, go to Tirgerdirect.com, and look for a hard drive enclosure. Your Hard drive fits inside and it will then plug into a USB port. You need to order one that fits the drive you have, so you need to know size and type of hook up. I use one for my old laptop HD's.
Aug 28, 2011 | Toshiba (HDD2188) 80 GB Hard Drive
Install internal hdd into external enclosure
yes you can... needs to be the right type i.e. SATA or EIDE that matches your enclosure and (USB) interface board...
Feb 25, 2010 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
Seagate 120 gig HD in Dynex enclosure not recognized by XP system
Ok, you didn't say if the drive had data or not? Anyway, if it is a drive with no data etc, you will first need to Initialize, & Format the drive before use. Is there any way you can connect it up to an "Internal" or "External" SATA port, & "See" if the drive is recognized, then at least you know the drive is OK.. Also try another USB port if available. If you know it is OK, then go to device manager and Uninstall the entire USB layer, reboot, it will re-install the USB again, with default settings, it NOW may be "Seen".
Feb 22, 2010 | Dynex USB 2.0 Hard Drive Enclosure Kit...
Get the message 'hard drive failure imminent
Have you tried turning off/on again your laptop?
If you did but still getting the same message am afraid you will have to replace the hard disk
Jan 04, 2010 | Toshiba MK8025GAS 80 GB Hard Drive
I have a motherboard that has only has one ide conncetions
what you should do is make the 300 gig as second drive and your primary drive is the 80 gig so that you can view and back-up the contents inside it. If you going to install a new copy of Operating system that would be in the 80 gig so that you don't need to format your 300 gig and make it as second drive. Hope this could help you..Thanks..
Oct 24, 2009 | Computers & Internet
HARD DRIVE ENCLOSURE RECOGNITION BY MY PC PROBLEM
Had the same problem today. I finally noticed that the pin bay on the enclosure was large enough to allow the pins to be offset by one pin set. The open pins were hidden by wires. Once I carefully aligned the pins, everything worked fine.
Robert
Jun 01, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
External hard drive enclosure
I too purchased a Nexxtech Hard Disk Enclosure and my Vista-based computer keeps telling me to try a USB 2.0 setup...the USB's ARE 2.0...did you try the setup disk that came with your unit?...I tried on mine but still a no go...I may have to return it to Best Buy & try somrthing different.
May 19, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Difference between ata and sata hard disks
ATA, or (PATA) hard drives use the older "seatbelt" 40 or 80 pin ribbon interface cable, whereas SATA is fairly new using the small, thin interface cable found in most computers manafactured in the last 12-18 months, hope it helps
Feb 18, 2008 | Highpoint Technologies 1 Bay e.SATA...
WD Portable Hard Drive Not Coming On
open it it up take out the hard drive, purchase a USB hard drive enclosure and install the drive. hopefully the drive is still good and spin up
hope this helps
Jan 07, 2008 | Western Digital External USB 2.0 80 GB...
Simpletech pininfarina problem
It appears that this is happening a lot with external drives. Inside most of them is just a regular internal drive. In my case I simply removed the drive from the external enclosure (a SimpleTech 160 Gig) and installed it in my PC, where it works like a charm. Most people who have this problem go out and buy a replacement generic external drive enclosure for about $30.00.
Jp
Dec 05, 2007 | SimpleTech Pininfarina 80GB External USB...
Toshiba MK8025GAS 80 GB Hard Drive Logo
240 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
