Need wiring instructions to installa model 81-2010-12 inverter
    Genius:
  • 1,157 Answers
Hi l_beck,
Please try to visit this link. They all have the complete information about your machine. Just look for the file that matches the type and model of your device.
Hope it helps.
Thank you for using FixYa.
Posted on Apr 11, 2011
Ge monogram model#Zeiss420nrjss inverter board part# wr49x10283
The Monogram series have most operational parts in the top area above the doors. I'm pretty sure the mother board is up there also on the left side if I remember right. Its basically unplugging the many connectors---remounting the new board----any plugging the wire plugs back in. If you have enough extra wire in the harness, you can un-mount the old board with the wires still plugged in and then mount the new board properly. Then just unplug each wiring plug one at a time and transfer to the new board in the proper place. Another way is to draw yourself a picture or use a cell phone and take a picture of the old board so you have something to look at for reference.
May 15, 2015 | GE Refrigerators
How to installa float on dehumidifier modesC675-25044 as the float fell out AND i NEED TO INSTALL TO HAVE THE DEHUMIDIFIER WORK
The model number you supplied is not listed on the Sears parts direct web site. There are 3 models with C675 ahead of 25xxx but none with 25044.
Jun 08, 2014 | Kenmore 54501 Dehumidifier
No pic but good sound
The Inverter will need to be replaced. You can get the replacement inverter board from www.tvrepairworld.com and they will also assist with installation instructions if needed.
Nov 07, 2012 | Sanyo Televison & Video
I have no instructions on how to installa baumatic bwr 1206 wasing machine
Hope this helps :)
http://talkappliance.co.uk/downloads/?sa=view;down=103
Apr 23, 2012 | Baumatic BTWM4 Front Load Washer
Where can i find the process to change a D410 inverter
If the screen on your laptop is dimming or not working at all, the fault may lie in the Dell Latitude D410 Inverter --the device that powers the screen's backlight. Replacing an Dell Latitude D410 LCD inverter will require some finesse, but you do not need a technical background. If you are comfortable with opening up your laptop, then this is a do-it-yourself project.
1. Unplug your laptop and remove the battery pack.
2. Locate the rubber screw covers around your laptop screen. There are typically four, but some models may have more.
3. Remove the screw covers. Take care not to lose any. They pop off and, if you are not careful, could go flying.
4. Place your fingers between the front bezel (the plastic piece around the LCD screen) and the screen. Gently work your way around the screen to remove the front bezel and expose the screen assembly.
5. Remove the inverter from the screen assembly. It is held on by tape in most models. In some models the Dell Latitude D410 Inverter may be right at the bottom of the screen assembly, below the actual LCD. Other models have the Dell Latitude D410 LCD inverter behind the screen. To disassemble the screen, you will need to either unscrew the screen from its metal holder, or just lift the screen out to expose the inverter.
6. Disconnect the wires leading from the Dell Latitude D410 Inverter. One wire goes to the backlight, while the other goes to the video card.
7. Look on the back of the Dell Latitude D410 LCD inverter for a model number or serial number. Having this exact number will make it easier to order a replacement.
8. Connect the video wire and the backlight wire into the new inverter and affix it using the tape that held the original in place. If you do not have that tape anymore, or it has lost its adhesiveness, you can buy more from computer parts retailers.
9. Put the screen back in place if you need to, and snap the front bezel back on.
10. Screw the front bezel screws back in, and place the screw covers back in place.
Apr 07, 2011 | Dell Latitude D410 Notebook
I have a 1750w power inverter for my van. The problem is I have absolutely no installation instructions, product manual or line drawingon how to install this product. can you help
Without seeing it its a little tuff.
Ok,look at the back side of the inverter,there should be two inputs.One negative- and one postive+.Run the biggest wire you can get to fit in the holes and still lock it down tight,probaly about six gauge wire.
On the hot side +,run the red wire to the battery,but before you connect to the battery,attach a line fuse,Thirty amp should do.Leave fuse out till last step.Run a black six gauge wire to the battery.(You should be able to run the wires through one of the factory rubber grommets on your van,use a stiff wire, or something like a car or cb antenna to attach your wire to the antenna with electrical tape.you may need to cut a **** in the grommet ,so you can push the antenna threw.Be careful not to damage any factory harness wires.)
Secure the inverter to floor of van,make sure the fan can vent well.
Go to battery put in your thirty amp fuse,Then the unit is ready to turn on.Make sure you run your engine while it is powered on,otherwise it wont take long to drain your battery.
Nov 19, 2009 | Eliminator MotoMaster Mobile Power...
I have a dell inspiron 6400 and would like to no
Unplug your laptop and remove the battery. To replace the inverter, you will need to remove the rubber tabs along the sides of your lcd to expose the screws. Once you have unscrewed the screws you will then need to pop the front of the lcd cover off. This is usually very easy to do but sometimes you have to take a small screwdriver and wedge it loose. the inverter is a long thin pcb that can be found underneath the lcd or to the right of it. It usually has to wires leading into it from the motherboard and two wires leading out of it to the lcd. unplug both ends and if it is screwed in, remove the screw. Then simply put the new inverter in and reverse instructions for reassembly.
Aug 20, 2009 | Dell Computers & Internet
Oven shuts off on cook after about 2 seconds
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do
not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Your actual model number is located on a tag around the control panel frame, door or below the cooking cavity.
Jan 12, 2009 | Panasonic NN-T654SF Microwave Oven
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
