Question about Denon AVR-2311 Receiver
I have connected to my 2311: HDMI 1: Oppo BDP 83 HDMI 2: Denon DVD 1740 HDMI 3: Apple Mac Mini Issue: The Mac Mini works fine and I have audio and video through the receiver, but for the BD and DVD only the video works and I have no audio. Any idea why?
  • Cezar Rodrigues Apr 11, 2011
    Thanks for your answer, but unfortunately, it didn't solve my answer, I checked my setup and the HDMI ! was already with only the HDMI configured and the coaxial & optical are already set to None, I did the same for the HDMI 2, but the issue still remais for both inputs.
    What I noticed in my tests is that if set the audio output (I'm not in home now, so I cannot check the exactly name of this setup option, but is something related to where it will be the sound output) to TV instead the default AMP, the audio works, but this is not what I want, since the sound of the speakers are better (I'm not sure if it helps, but currently I have configured a two channel system with a pair of KEF iQ10 speakers).
    Regards,
  • Denon Master
  • 6,694 Answers
You have to check the digital audio assignment of you AVR for HDMI 1 and HDMI 2. There is three options for the digital audio for HDMI 1 and HDMI 2. You can set it as optical ,coaxil, or the HDMI itself. In you receiver the assignment may be in optical input or in coaxial input for the two HDMI inputs.
1. Go to the system setup
2. Select input setup
3.Select input assignment.
4. Select all the three input ,you are using as HDMI
ok
Posted on Apr 11, 2011
  • 2 more comments
    Thanks for your answer, but unfortunately, it did not solve my problem, I checked this setup and for the HDMI 1 is already configured with only the HDMI enabled (the optical and coaxial are both set to None), I did the same configuration for HDMI 2, but the issue persists for both outputs.
    During my tests, I noticed that if I configured the audio output (I am not in home right now, so I cannot check the correct name of this option, but is the one used to indicate where the sound output will be) to TV instead AMP, the audio works, but this is not what I want, since the sound through the speakers is better (I don't know if it helps, but currently I have a pair of KEF iQ10 speakers configured as two channel in the receiver).
    Regards,
  • Electro Med Services
    Electro Med Services Apr 11, 2011
    hi,
    I have readed the information that you have sent to me. You owne one of the latest AV receiver which provides many facilities. as you mensioned, you AVR is not outputing the audio output through the speakers connected to it because, in the AVR the HDMI audio output is seted as TV. For lisening the audio through the AVR you have to set it as AMP.
    For that you have to goto the MENU and select MANUAL SETUP and then select HDMI setup. In the HDMI setup select HDMI AUDIO OUT and then select it to the AMP.
    Also you have to check one more thning, if the HDMI control function is activated the the fist priority will go to the TV to output the audio . You can see the HDMI control in the same menu page. The HDMI control only works when the equipment connected to AVR compitable with HDMI control. If not, you have to set it in OFF positon. If teh HDMI cotrol is in ON position make it to OFF. For getting HDMI control you have to buy a tv ,dvd,etc that have HDMI control facility , also you have to make connections with HDMI cable with a version of 1.3 or above . If you have to get audio through the AMP just do check these two things. if you need any more assistance from me then you can contact me through fixya.
    ok
    hi,
    Have to tell you one more thing . If you are using only two speakers then you have to select all the surround speakers as NONE in the speaker setup of your amp. Also one more thing if you are not using a SUB WOOFER then select the subwoofer to NO inthe speaker setup, then only you will get the base level through your frond speakers. Press MENU button goto maual setup then select speaker setup in the speaker setup select speaker configuration. And set all the parameters. Or connect the configartion mic and go through auto calibaration.ok
    ok
  • Cezar Rodrigues Apr 12, 2011
    Thank you again, I check my settings and they're already with the values that you suggested. Testing a little more I discovered that my problem is different from my initial thought, I discovered that some BD have no audio, but not all, only the BD with stereo audio options only, when a BD have a multichannel option (like Avatar), I have the audio working.
    According with what I read in the web, the problem is my AMP ASSIGN configuratiion, it is set to 2CH currently and that is not the correct value (even that I have only a pair of speakers connected), the correct should be NORMAL or ZONE2. I will test this information later when I return home.
    Regards,
  • 84 Answers
You may need to go into the menus for the BD and DVD players and make sure that the output for audio is set for HDMI as it may default to something else such as fiber optic or fgb connections.
    Thanks for your answer, but it did not solve my issue, I used the DVD and BD, before bought the receiver, directly connected to the TV only using the HDMI cable and it worked fine, I never used a optical or coaxial audio cable. I also changed (to test only) the audio ouput in receiver to use TV instead AMP and it worked too. But, through the speakers, it is not working.
    Regards,
Apple tv doesn't work when hooked up to denon 2311 receiver. Apple tv is turned on but tv screen displays the word
http://usa.denon.com/documentmaster/us/avr-2311ci_lit527.pdf
This is the link to the probable box in question. The Apple TV needs to be connected to HDMI input port (pick on of the six available). Follow setup instructions.
Jun 08, 2012 | Audio Players & Recorders
Bought blu ray The Road it plays previews but the play menu wont come up on its own and then you cant push play and move the arrows over
I'm having exactly the same issue with the OPPO BDP-83 player. I'm going to try the firmware upgrade. I'm having a similar problem with Minority Report. I cannot see a play option at all!
May 30, 2010 | Sony BDP-S300 Blu-Ray Disc Player
HDMI output from AVR-4806
You say your connected from the DVD to the Denon with an HDMI cord and the Denon to the TV with an HDMI cord and you get no DVD video? can you get the Denon setup menu? if so change the res. output on the DVD to 480p, 720p or 1080i but not 1080p
Feb 15, 2009 | Denon AVR-4806 Receiver
Denon DVD-1740 component video to RGB cable
YOU HAVE THE RIGHT CABLES FOR THIS INSTALL, GREEN, RED, BLUE FOR COMPENENT VIDEO AND RED AND WHITE FOR AUDIO UNLESS USING THE OPTIACL OR COAXIAL, FROM THE DVD PLAYER TO THE AMP OR TV.
ON THE FRONT OF THE DVD PLAYER IS A HDMI BUTTON PRESS THIS BUTTON UNTILL OFF IS DISPLAYED AND YOU SHOULD HAVE PICTURE
Jun 02, 2008 | Denon DVD-1740 DVD Player
Denon Avr-588 setup
dojran,
nice gear. Without further information, i am going to describe the best setup possible with your equipment.
1. make sure the speakers are connected to the receiver and you can hear sound out of it
2. connect cable box to receiver via hdmi to receiver.Choose cable on the receiver or video1 etc. (if you are not using hdmi cables post annd i will walk uthruogh a non hdmi process)
3. connect a hdmi cable from thee receiver monitor output area to the tv hdmi input
4. connect the dvd player hdmi to the input of the receiver
to watch select the tv av mode to line up with the receiver and choose video1 for tv and dvd to watch dvds on the receiver.
good luck
smeags
Jan 03, 2008 | Denon AVR588 Receiver
Denon AVR-2311 Receiver Logo
571 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
