Question about LG LDS4821WW 24 in. Built-in Dishwasher
Our dish washer stop and the e1 light come on, what should we do
    Guru:
  • 500 Answers
The E1 you are seeing means the following: Water Level in Drum lowering, this means there is a leak on one of the pipes.
But from previous experiences it is more than likely that it is the Circulation pump. It will have to be replaced, as it is a common spare that has to be replaced on L.G Dishwashers (lifetime expectancy: 12 - 18 Months) - Not very expensive.
Usually is about 20%-25% the price of a new Dishwasher. The Circulation pump is fitted to the sump. Part Number: 5859DD9001A or 5859ED1001A (Depending which one is in stock)
Good Luck :-) - J.Q
* If you found this solution helpful, please vote positively. A 4 four thumbs up will do nicely too :-)
Posted on Apr 11, 2011
I have a whirlpool duet model wfw70hebw. The washer stopped and I can't unlock the door. Have error code E1 F9
Try unplugging for 30 seconds and plug back in. See if you are able to reset the controls after that.
Jan 24, 2015 | Whirlpool Washing Machines
We keep getting an error message E1. We have an LG 2120 model
The E1 or 1E error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Dec 13, 2014 | LG Dishwashers
What does the Code E1 mean for a Whirlpool Duet washer?
There is a small access panel on the bottom of these newer Maytag and Whirlpool washers. Three small quarter inch screws hold the panel in place.
Once the screws are removed the panel will come off. The pump filter is directly in front of you at this point. The handle can be twisted counter clock wise and then pulled out. Most likely you will find some sort of debris inside. It can be an article of clothing, lint, backing from a rug, or change
Sep 13, 2014 | Whirlpool Duet GHW9150P Front Load Washer
LG 2131SH Dish Washer giving error code E1
That is a leakage error, pull the access panel and check for water underneath the unit that might be cuasing it to fault out
Jan 31, 2014 | Washing Machines
HOBART AM15 DISH WASHER ERROR(E1)
After checking the service manual, I find no code for E1. There is a P1, or other E codes. Please list ML number.
Jun 14, 2009 | Hobart 29 in. AM15-1 Free-Standing...
GE PDW9700 - The dishes do not get cleaned
Same as above problem: I have had this dishwasher for less than 4 years and the dishes as of about 2 years ago stopped getting cleaned. I use the recommended dish liquid and rinse and lightly clean the dishes before I put them in.
What a piece of junk!! gs
Feb 26, 2009 | GE Profile PDW8400J Built-in Dishwasher
LG LDS4821WW 24 in. Built-in Dishwasher Logo
329 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
