Question about Panasonic Palmcorder PV-GS12 Mini DV Digital Camcorder
I am looking for a direct power cord (there is an insert/recpticle behind the battery. I need to download video and do not want to have to keep recharging the battery to do so. What is the proper name of this attachment. It goes from the wall directly into the camera for power play and /or recording for long periods of time The specs are 7.2 45Win the camera
    Master:
  • 346 Answers
Hello Cyn - What you're looking for is called an AC adapter.
The particular one you need is a Panasonic PV-DAC11A. You can find it online (try Amazon.com) for about $60.00 and you might be able to find a used one on Ebay for less.
Good Luck Shopping and Thanks for using Fix Ya
Mikeywaf
Posted on Apr 11, 2011
What do I do when while plugged in it keeps saying low battery and the shuts down.
Hello, John -
1. Make sure your power cord is firmly inserted into the computer.
2. If after double checking the power cord connection you still have a low battery indication, you will probably need to replace the computer battery. Either the manufacturer of the computer sells replacement batteries for your model or you can find one through an office supply store (may have to order one.)
Dec 21, 2017 | The Computers & Internet
I cant find the power cord or where to plug it in at
Behind white label , remove label , insert the power adaptor to proper hole .
Dec 08, 2014 | Duracell Powerpack 300 - Portable Power...
My HP 210-3070NR won't start. A blue light at the
Hello.The most common reasons for power issues are the battery, power jack and power adapter/cord.Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.If no change, the power adapter is probably faulty and needs replacement.Hope this helps.
Mar 03, 2013 | Computers & Internet
601 error message
Hello.
I am sorry that you are experiencing this error message. It generally indicates that your measured storage capacity in your primary battery is less than 25%. What this means is that your primary battery (601 indicates that it's primary) can only keep a 25% charge. To keep this quite simple for you, please attempt the following.
* Unplug your power cord.
1.) Start up your Laptop and hit the ESC key immediately.
2.) Press F2 to get into Systems Diagnostics.
3.) Select Battery Test. * Now, plug in the power cord.
4.) Start Battery Test.
The battery test will give you a STATUS. If you see the following;
- Calibrate: This means that your battery is functioning correctly but it is in need of calibration. Select the automatic calibration option.
- Weak: From here, please get a new battery to ensure that your getting adequate power supply to your laptop for use.
- Replace: Replace the battery.
- No Battery: If there is, indeed, a battery inserted. Remove it, check for dust/dirt and wipe it clear. Insert the battery and see if it works now.
- Unknown: Try to download all available updates from HP Support Assistant.
Feb 09, 2013 | HP Pavilion ze2000 Notebook
New house has three prong recpticle dryer cord has four prongs. Can I use a three prong cord and strap a wire to the fourth wire on back of dryer? If not got a solution?
If the new house has an existing three-wire outlet, the simplest solution is to install a 3-prong power cord on your dryer. The following link explains the differences between a 3-wire and 4-wire configuraiton:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
So...if you need to install a 3 prong power cord, it should be wired as follows:
RED (HOT) 120VAC to RED
BLACK (HOT) 120VAC to BLACK
WHITE (NEUTRAL) 0 VAC to WHITE - a Ground wire needs to be connected to the Neutral lead at the terminal block and grounded to the dryer cabinet.
The other alternative would require you to install a 4-wire receptacle so you could still use your current power cord. A certified electrician is recommended for this job and may cost you some money. A replacement power cord, on the other hand, usually costs less than $20 and can be found ay any hardware store.
If you have any questions, please post back and let me know. I hope you find this information helpful.
Jun 10, 2010 | Dryers
Dell inspiron 1526 has problem (plugged in ,not
Hello there:
First you will want to ensure that the power cord is fully inserted at both the laptop and all the connections for the cord and that it is getting proper power. and check tosee that the connector thatthe power cord goes into is not loose if so this will have to be repaired
next remove the battery from the computer and unplug the power cord and then press in the power button for 1 minute than if this has a reset button on the back use a toothpick or a small item and pressin on the reset button for 30 seconds
now insert the power cord (NOT THE BATTERY YET)
and turn on the computer and it should now start up if so insert the battery and leave charge for 1 hour than you should be ok from here ok
Please keep me posted on this so i can assist you if needed.
Best regards michael
Dec 16, 2009 | Dell Inspiron 1526 Laptop
V smile learning systems keeps restarting
Unplug the system from the power supply for about 15 seconds and try one more time. If that fails:
Make sure the power cord is plugged in and that the red/white/yellow cables are plugged properly into the TV. Also, as you plug the red/white/yellow cables into the TV, make sure you turn the TV to the right channel - it is different for every TV. For instance, the red/white/yellow on the front of my Sony is labelled Video 2 - yours might be labelled FRONT, AUX, or something else.
Things you can try to get the V.Smile TV Learning System to work:
1) Press the Reset – Press and hold the ON button for about 10 seconds
2) Make sure the game is inserted far enough into the system, and that it is pointing in the right direction. You may occasionally need to clean the contacts.
3) Also, make sure you are using the supplied power cord/adapter, not batteries. Batteries cause more problems than they’re worth.
-Tha Mp3 Doctor
Nov 23, 2008 | Vtech V.Smile TV Learning System
Cannot get power with batteries or adapter.
-Tha Mp3 Doctor
Oct 10, 2008 | Vtech V.Smile TV Learning System
My psp wont turn on!
  • Hi! TRY THESE TO SEE IF WE CAN GET YOU POWERED UP! :)
    Confirm the system is not in HOLD mode
    Make sure the PSP system is not in Hold Mode (in the down position). Slide the Power/Hold switch up to clear Hold Mode. Or try sliding the Power/Hold switch up and holding it there until the power indicator light turns off and the PSP system is completely turned off. Then try turning the PSP on again.
    • Confirm the backlight is ON
      Make sure the LCD screen's backlight is not turned off. If it is, press any button to turn ON the backlight.
    • Confirm use of only licensed products (AC Adaptor, battery pack and charger)
      The AC Adaptor, battery pack and battery charger must be licensed for use with the PSP system. All licensed products for use with the PSP will have the following logos displayed directly on the product and/or the packaging:
      pslogor.gif global_logos_psplogo_168x35.jpg global_logos_scealogowhite_60x73.gif
      If any of the products you are using does not have these logos on them, we recommend that you immediately discontinue the use of these products, as they void the PSP system's warranty, and can cause damage to the system. See compatible peripherals for the PSP system for a full list of supported products.
      There are some products that can be used with the PSP system that may not display our logos. Products such as San Disk 1GB Memory Sticks, or various USB cables, needs only to be genuinely certified. Look for the genuine certified logos on these products or contact the company which manufactures these products for more information.
    • Confirm the battery pack is correctly inserted
      Make sure the battery pack is in its proper position (see inserting the battery pack for details).
    • Try the battery pack only
      Unplug the AC adaptor from the PSP system. Make sure a charged PSP battery pack is inserted inside the PSP system. Turn on the unit. If you get power, then the problem may be with the AC adaptor and power cord.
    • Try the battery pack in a different PSP system
      If possible, try your PSP battery pack in a different PSP system. If your battery works on a different PSP system, it may indicate an issue with your PSP system.
    • Try a different PSP battery pack
      If possible, try a different battery in your PSP system. If a different battery pack does work on your PSP system, it may indicate an issue with the original battery pack.
    • Try the AC adaptor and the PSP battery pack
      Insert the battery pack and plug in the AC adaptor. If you still do not get any power, your PSP system may need to be sent in for service (see PSP Service for details).
    • Try the AC adaptor / power cord only
      Turn off the PSP system, unplug the AC adaptor, and remove the battery. Now plug in the AC adaptor to the PSP system with the battery removed. Confirm the AC adaptor and power cord are firmly connected to each other. Now make sure they are also firmly connected to the PSP system and the electrical outlet.
      If the PSP system powers on, the battery may need to be replaced.
    • Check AC adaptor and power cord for damage
      Visually inspect the AC adaptor and the power cord for damage. Do not use if frayed, cut, or damaged in any way.
    • Check the electrical outlet
      Confirm the electrical outlet that you are using is active (receiving power). Try using a different electrical outlet.
    • Try a different AC adaptor and power cord
      If possible, try a different AC adaptor and power cord. If a different AC adaptor and power cord does not work, the PSP system may need to be sent in for service (see PSP Service for details).
    • Confirm no unauthorized system software or downloads were used
      Confirm that you have not used any unauthorized system software updates or downloads on the PSP system. Use of such unauthorized firmware updates voids the warranty and can damage the PSP system.
    • WLAN turned off
      Make sure the wireless (WLAN) network function is not in use while charging. The battery pack cannot be recharged when the WLAN function is being used.
    • Power surge
      If you experienced a power surge, shortage, or a lightning storm in your geographical area recently, this may have affected the PSP system's power supply. Please contact Consumer Services below for information.
    Sep 03, 2008 | Sony PlayStation Portable (PSP) Console
    Panasonic Palmcorder PV-GS12 Mini DV Digital Camcorder Logo
    53 people viewed this question
    Top Panasonic Video Cameras Experts
    Kenneth Walker
    Pieter Vleeshouwers
    Pieter Vleeshouwers
    Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
