Question about Canon Office Equipment & Supplies
Hi we have a Canon Colour Imagerunner LBP5975 with a 16 PREP.M TNR error. I have replaced the Magenta toner but nothing happened? Any ideas?
  • Canon Master
  • 32,281 Answers
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Posted on Apr 11, 2011
How to clean the magenta toner out of the drum unit
Change the magenta image unit,your image unit life end,
Feb 28, 2013 | Canon Color ImageRunner LBP5970 Laser...
LBP 5970 --16 PREP.Y TNR
Hi!
Y toner is your yellow toner that needs to be replaced!!C is cyan,M is magenta and BK is black!!
Enjoy!!
Jan 29, 2011 | Canon Color ImageRunner LBP5970 Laser...
Error code E000013-0001
getfile.asp?rid=1258 February 2, 2005 getfile.asp?rid=3215 Product : imageRUNNER C5800 / C6800 Title : E013 code and Waste Toner Full message Question :
The copier shows an E013-0001 and "Waste Toner Full" message. The Waste Toner Bottle has been emptied and SW1 is operating properly but the code and the message are still appearing on the display.
Answer :
The counter for the Waste Toner Bottle needs to be reset back to zero in Service Mode.
Enter Service Mode level 1 by pressing * 2 8 *, select Copier > Counters > MISC, then highlight WST-TNR, press Clear - the counter will zero out.
Power off the copier, turn the copier back on, the Waste Toner Full message on the display should clear out.
Canon USA, Inc. Systems & Technical Support Division 1-800-528-2830
Dec 22, 2010 | Canon imageRUNNER C6800 Copier
What does the error code E000005-0000 mean?
This is a cleaning web end of life code. Replace the web and reset the counter in service mode. Press the additional function key, then the 2 & 8 at the same time, then the additional function key again. Press copier, counter, MISC, FIX-WEB, then OK. You might as well reset the WST-TNR setting as well. Check to make the waste toner bottle is empty - right side ,lower right of copier behind panel.
Nov 10, 2010 | Canon imageRUNNER 5570 Copier
ImageRUNNER 7200 Copier: hi I'm Akar I have a canon ir6000 copier my...
The problem is with toner section. The copier cant get toner to toner unit or the toner motor is faulty.
In one case eaven the main pcb caused the problem.
I would try to replace toner hopper assy.
call service.
May 16, 2010 | Canon imageRUNNER 7200 Copier
Error code e000020-0021
getfile.asp?rid=1258 November 12, 2007 getfile.asp?rid=3215 Product : imageRUNNER C2880 / C3380 / C2880i / C3380i Title : E020-0021 Error :
E020-0021will not reset after the machine is powered off and on. Replacing the Drum and the ATR Sensor did not clear the error.
Workaround :
In this case cleaning the Dust Proof Glass fixed the error.Check the Dust Proof Glass for soiling.The glass is located under each unit and may have toner spilled on it. Clean the glass with the tool provided on the front door. Instruction's are also included there.
getfile.asp?rid=22945getfile.asp?rid=22948 Canon USA, Inc. Systems & Technical Support Division
Mar 18, 2009 | Canon Office Equipment & Supplies
Canon lbp5960 error 16 prep mc toner
That's a low toner message for the Magenta & Cyan cartridges.
-Jim
Oct 22, 2008 | Canon Office Equipment & Supplies
Canon Imagerunner c3200 copier problem
Sound to me like a drum problem, try replacing it and it should work after u do..
Nov 28, 2007 | Canon imageRUNNER C3200 Color Printer
Toner Replacement
The cyan and magenta go into the machine through the same aperture as the yellow toner cartridge. The machine will automaticaly rotate the toner turret to the correct position when toner replacement is necessary for that particular cartridge.
Nov 14, 2006 | Canon imageRUNNER C6800 Copier
210 people viewed this question
old marine
old marine
