I have a LG 47LH40-ua LCD tv. Today after watching TV for a while the picture started to fade to white. Turned to a different input and it was still faded. Turned the tv off for a while and the picture returned to normal. Any ideas what this could be?
  • 1,238 Answers
Good day
that problem is many causes its either power supply loose connectors or the worst is the main got partially defects..I give you some tips to fix that any of 3 causes that mention above..
first causes,,the power supply,,its gives the supply of all the system of the unit..when it is not functioning well or the output supply is two low or high.. Also your TV is not function well..
step to troubleshoot;
1) remove the cover by unscrewing of all screw at the back side of your TV
2) check the output voltage such as 5v,24vdc..By power on again and use a multimeter tester range it to DC..if there's a voltage drop..
3) check if there's a leak or bulging top capacitor..if any leak capacitor replace it
like this
Next causes,the loose connectors..
1)reset the all connectors that you see inside your TV by disconnecting it and connecting it again
Next causes is the main board,,there's no easy remedy of that instead of resetting the power such as off/on
thank you and good luck
Posted on Apr 11, 2011
Lcd tv picture
Replace backlight lamps
Jun 03, 2017 | LG Televison & Video
LED TV pulsing
How many have 'blinking' issue with Samsung led tv - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJan 26, 2011 - I am trying to get the number of people affected by this nagging blinkingissue with the latest Samsung led tv's. If possible it would be useful to ... Samsung LCD TV Screen flickering (LN55C630K1F)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung LED with flashing standby light on front
Apr 17, 2014
More results from www.cnet.com
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical ...
Jan 18, 2016 | LG Televison & Video
42LK520-UA LG television horizontal black lines that fill up the entire tv. Video included. Need info on part replacement.
Check and replace the damaged CCFL lamps at the back-light section. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 03, 2015 | LG Televison & Video
We have an lg 55 LH 40-UA.ACCVLJR that has sound but doesn't show the picture but says it is receiving no signal
basically it is input issue Brent, you may want to turn off and on your tv after 4-5 minutes, if same thing press on your tv remote INPUT, SOURCE or TV/VIDEO and you should have input lists on your tv screen. Choose one by one until you got a picture.
You can also check this out.
May 13, 2014 | Spectroniq PLTV-42HW68 42 in. LCD TV
No picture
This is a common problem with this TV caused by a failed buffer board, usually the top one.
Here's two links that explain it, tell you how to test it and provide solutions:
http://www.coppelltvrepair.com/p/1173/lg-50pa5500-ua-top-buffer-board-replacement-for-tv-starting-with-no-image-problem-50-credit-for-old-dud
https://www.youtube.com/watch?v=z3dxCJ3CaTs
Hope this helps!
Apr 18, 2014 | LG 50PA5500
Our brand new LG TV loses brightness whilst you are watching a programme.
Check to make sure that eco mode is turned off. It will sense the ambient lighting and if it is bright, the TV will be bright so if you are seeing the brightness change...check that setting first.
Jul 31, 2011 | LG 47LH40 47 in. LCD HDTV
I have an LG 42LH30-UA LCD. Using the HDMI there is a delay between picture and audio. Doesnt make a difference what HDMI cable I use or what source(PS3, Cable, or Surround). Any ideas?
If you are in Canada, call LG and they will send a service tech to apply a firmware update to your tv and input some codes. Apparently they used to send you a usb flash drive to do the update, but some degree of technical skill is involved so they now send a local tv tech.
Sep 12, 2010 | Televison & Video
Lg lcd tv picture goes in and out with "boxes" on the screen
This sounds like the power supply that feeds your back-light is going out. This repair should be done by a qualified technician
Mar 13, 2009 | LG RZ32LZ50 32 in. LCD Television
42LG50 HDMI error message
pull the plug on your tv and cable box for 1 minute and start fresh. glitches like this happen all the time with hdmi. if this does not cure, the error message you get needs to be posted.
Feb 27, 2009 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
204 people viewed this question
Top Televison & Video Experts
