I have a GE model 7401GHE washer that seems to have locked up. It just finished a load and the control lights to turn on the washer will not turn on. The door locked light is on, but the door isnt locked. I have cleaned out the lint trap and I have unplugged the machine to try to reset it, but nothing is working. Is their a way to reset the controls?
SOURCE: control lock light
Try holding in the "End of Cycle"tone button
Posted on Dec 16, 2006
the dr
  • 447 Answers
someone has enable the child lock feature. One of the buttons should say hold 3 secs for control lock under its normal function description. Hope this helps
Posted on Jan 01, 2008
Coldcut
  • 1554 Answers
SOURCE: GE WHDVH626fWW Door Locked, but not
As most these washers use the same control board.
try some of the troubleshooting you see here :
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
The main relay (black one on the right of board ) may be at fault in your issue.
these boards have bad solder joints in most all cases.
If its still in warranty it time to call them.
If you open it please post pics.
Posted on Feb 03, 2008
SOURCE: GE Front Load Washer Model WBVH5100HWW - door lock light is on
I queryed another site; justanswer.com with technician Larry, who provided the solution. Replace the door latch assenbly part # WH10X1006 $146.99 from GE. A local parts house had the identical under a Whirlpool # WP8182634 for 59.46. Install the new assemble and all is well.
Posted on May 07, 2009
  • 26 Answers
SOURCE: Duet HT GHW9300PW4 - The control lock is on
Hold down "end of cycle" button for 3 seconds.
chrisxx
Posted on Jun 03, 2009
My GE Front loading washer has a red lock light
On the GE GFWN1100LWW the Lock light indicates that the Child Lock (Panel Lock) is enabled. Press and hold the Lock touch pad for 3+ seconds. The light will go out. (Note: if you hold that button for too long, the lock will disengage and then reengage.)
The lock is useful to avoid having someone change the settings or start the washer when they shouldn't. (For example, you don't want to start or change the cycle settings on the washer while cleaning the control panel's surface.)
I hope this helps.
Nov 25, 2013 | GE GFWN1100LWW Washer
Ge top load washer lights up but wont turn on
check the bottom right coner take the panel off and cheack the pumps not blocked , or its the door lock ,or pc board
Jan 18, 2013 | GE WHRE5550K Top Load Washer
Lock light turns on then blinks and wont start
Possible that the lock switch contact has some issues, try a cleaning spray on the switch and open and close the door several times with the spray. This might clear the switch contacts.
Also make sure that the contacts to the connectors from the control panel are in order, remove and tighten or repeat few times.
Otherwise the control panel can be a suspect.
Jul 03, 2012 | Maytag Bravos MTW6600T Top Load Washer
Our washer finished it's load but now I can't get
if it is full of water it will stay locked .place outlet hose in bowl to drain
Dec 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control Lock is on my front loader.
ok, you are in the model selection part of the service mode. for 6240 I believe the model code is 3 select this and press start. normally to release control lock press and hold small I button by start button.
if model selection in incorrect it can still be corrected. only difference in models is cycles matching the labels. you can tell by the time indication for each cycle if it doesnt look right then check book inside top cover
Mar 29, 2009 | GE WBVH6240F Front Load Washer
Nov 12, 2008 | GE WBVH6240F Front Load Washer
GE WDSR2080D5WW Top Load Washer
sounds like the agitator is bad not hard to replace look up on internet agitator replacement for that model
Sep 10, 2008 | GE WDSR2080D Top Load Washer
WBVH6240HWW
It is under Warrty call GE to come out dont mess with it as long as it is under Warrty
Jan 26, 2008 | GE WBVH6240F Front Load Washer
Help with Model #GHW9400SU0 Whirlpool Duet Front Load Washer
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED status light turns off.
Nov 19, 2007 | Whirlpool GHW9200L Front Load Washer
Washing Machines Logo
60 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
