Should there be (3) red wires feeding the rooftop condensor? Is there a pdf of the wiring diagram I can get?
  • 413 Answers
If you're talking about the high voltage wiring, the answer could be yes if it is a 3 phase unit. That means you have 3 separate legs of "hot". Many rooftop units are 230v 3 phase in the US. Single phase would have two hot wires and a ground. Look in the disconnect box. If there are 3 fuses you have a 3 phase unit. If you have 2 fuses, you have a single phase unit. Be careful, you are dealing with very high voltage and very dangerous.
Posted on Apr 11, 2011
Thermostat wiring diagram for Domestic RV rooftop AC
go on internet look up troubleshooting dometic rv a/c's
Feb 13, 2015 | Dometic Rooftop RV Air Conditioner
Need wire diagram from T-stat to Air-Handler then cond unit
green goes to g on air-handler,white goes to w on air-handler yellow goes to outside condensor, red from air-handler goes to rh-rc on thermostat, whire off c on air-handler goes to outside condensor.
May 13, 2014 | Ruud Heating & Cooling
I have no voltage to my thermostat
Possible transformer problem or a broken wire between the thermostat and the a/c
You will need an electric meter to check for voltage at the transformer One side should be the power feed and the opposite side should feed the 24 volts, or 12 volts depending on type of unit.
I suspect that there is a break in the thermostat wire to the unit. You can test this by getting enough wire for the thermostat and go to the board on the roof top unit where the thermostat wire connect and connect the wires that you have to the existing board i.e. red to red green to green and so on. once you have connected these wires to the proper screws then take a new thermostat and connect the wires to the new thermostat and activate this should tell you if there is a break in the wiring or possible transformer problem but as I said I think its a break in the wiring
Dave
Mar 19, 2010 | Dometic Rooftop RV Air Conditioner
Where does the thermostat wires connect
red to r on thermostat this is your low voltage feed from transformer. Green to g on thermostat this is fan, white to w on thermostat this is heat yellow to y on thermostat this is cooling. On the outer unit there will be two wires wich will connect to the two blank wires above your service valves in the area of the electrical box. Shold be two 18 gauge wires red and white. That is the outer unit connection (condensor) The Furnace inside the house that contains the blower motor and heating there is a terminal block in the unit with r,g,w,y,w1,w2,c, Follow the wiring as described in the first paragraph Good Luck
Dave
Aug 28, 2009 | Heating & Cooling
Wiring Question York Diamond 90 Condensor Unit - New Capacitor
the wire diagram should tell you how. it all depends where wires lead to. be very carefull, capacitors can be dangerous. brown usaully go to fan black usaully goes to common red usaully goes to herm or compressor. it all depends where wires come from
Aug 27, 2009 | Heating & Cooling
Wires not connected on mod# 6759c707
If you google Coleman rooftop air conditioners on your computer, it will give you some dealers that sell that air conditioner and they should be able to help you or tell you where you can get the help.
Apr 03, 2009 | Dometic Rooftop RV Air Conditioner
Wiring diagram needed RV rooftop coleman
Motor1258,
Thanks for the response, to be more specific, the nine pin connector was damaged, but I was able to connect the wires back to main unit panel. I am ready to hook to the hunter thermostat and do not know which wires to connect to. This is my problem and I do not want to short something out. Hope this helps, I want to get it installed again. Thanks again for caring....Jerry
Jun 17, 2008 | Coleman Mach III Air Conditioner
Wiring Diagram
here is a basic wiring diagram for all air cond systems your thermostat consist of treminal r w y and c run a four conductor wire fromm thermostat to ai handler the air handler should allso have eather have red blue white wires or a teminal block marked r w c r stands for red w for white c for comon allso blue run color for color from the thermostat to ai handler with exeption of yellow yellow runs straigth to condenserand retuns in white wire to air handler wich gets conected to comon hope this help[s you
Sep 02, 2007 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
149 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
