Question about JVC Televison & Video
Hi..pls..help..my jvc television, im watching then turn off have a power but sadly it has a line at the middle of monitor and turn off.
  • 635 Answers
You have a vertical amplifier failure or dry solder on the vertical IC. When cold if the TV works for some time and then you are getting a thin white line in the middle of the screen after some time -- its a dry solder problem. The vertical IC runs very hot in the TV and develops dry solder after a few years.Will run when cold and switch off when hot.
Are you well versed with electronics to do the repair yourself ?. If so, revert back and I will guide you if you mention the TV model #.
Posted on Apr 11, 2011
HI I have 60" Sharp
Im sorry to imform you but there probably isn't a solution for this. you see with an lcd if one of the pixals goes out more of them start to go out. I know someone who bought an lcd monitor for there pc and when they took it home one pixal was out for the pressure it was under when they shipped it. she turned the monitor off and later back on and there was a line on here screen. then she turned it off and back on and it was a bit larger till she had a line all the way down the screen. she was able to take it back to the store for a new monitor but the next one did the same thing. it wasnt till her 3rd or 4th one that she finally had a good working one. anyway theres no way to get those pixals back if that is what it is.
im sorry about your television.
i hope this has helped if you need anymore help just reply.
Apr 29, 2011 | Sharp LC60LE810UN 60 in. LCD TV
I was watching the super bowl and my JVC projection screen shut off, when I turned it back on the blue power light and the red light above it flashed continually... I pulled out the lamp and its blown.. if...
Hi.
Yes, if you pulled the projection lamp and it is burnt-out, then yes. This should indeed fix your problem.
I'm sorry that it had to happen to you in the middle of the Super Bowl, it's turning into quite a good game.
Right now as I post this..it is GB 28...PITT 25 3:00 to go 3rd quarter...GB is 1st and goal from 8 uard line.
I hope you can get it to work again, but unless you have an electronics store that is A within a couple of blocks of you, and B OPEN...then you won't have it going again before the end of the game.
Feb 07, 2011 | JVC Televison & Video
The monitor is a Dell? UltaSharp 2007WFP 20.1 Inch Flat Panel Monitor. I Tried everything. different power cables, DVI cables, VGA cables, disconnecting everything and reconnecting. NOTHING WORKS. I even...
Not sure if this is your problem, but I have seen this with another Dell monitor on three separate occasions. The solution I found was to turn off at the wall power socket, unplug at the wall socket, plug back in, turn on at socket etc and everything was fine. Guess something hangs up somewhere.
Dec 08, 2010 | Dell Computers & Internet
Hi sir iam surendra, present im using benq lcd moniter & since few days im facng display prblem, when i turn on my system, some lines are comming & causing visual problem.so iam nt able to see my...
The picture board on your monitor is bad, since the lines are causing visual display, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself. in other not to complicate issues.
Nov 26, 2010 | BenQ FP71G 17" LCD Monitor
Our 42" JVC plasma now has a black line right in the middle of the screen with some colored bard similar to performing a "defrag" on a PC. Is our set "shot?" it's only around 6-years old. Model # VM-42WV74...
I had the same problem with a JVC VM-42X795. The repair man said a wire in the monitor is probably borken that provides power for that enire row. I stared with one bad row, but ow I have two.
Sep 26, 2009 | JVC Televison & Video
My JVC TV Problem
hi.. sir
if universal remote does not work properly.. i am not sure
just open the tv and see if any cmos battery is inserted .. in circuit board.. if any present.. answer me sir..
Sep 01, 2008 | JVC AV-27D302 27" TV
What chanel do I put a jvc tv on to watch videos?
Depends on how the video is connected to the JVC TV. It could either be:
  • Channel 3 or 4; or
  • not a channel but Video 1 or 2
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 11, 2008 | Televison & Video
Havea lot of lines on monitor
theres a adjustment on flyback they have two adjustment screen.if you made an anjustment turn off the monitor the adjustment anti clockwise little bit.
by the way my name is robert im technician all branded name of sony, jvc,philips etc....
Jul 25, 2008 | Star Logic 17" LCD Monitor
TV Screen
im pretty sure you cant fix that you probably need to buy a new one.. i know that because my somputer has a white line that runs right down that middle, not all the time but sometimes. my father looked into fixing it and he found out that you have to buy a brand new screen or tower or something like that.
Dec 31, 2007 | JVC AV-32020 32" TV
Televison & Video Logo
60 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
