Question about Ricoh Aficio 1035 Copier
I'm getting error E-5 on - Ricoh FT 4027 which makes it malfuntion. What i should do?
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 183 Answers
Tell me full number press */. and tell me full code like example 542 544 ok
Posted on Apr 11, 2011
I need part number of spc231n printer fusing unit
G166 4026 Fusing Unit - 120V
G166 4027 Fusing Unit - 220V
Mar 24, 2013 | Ricoh Corp Aficio SP C231N Laser Printer
Error code E70 on ricoh FT 4418
Empty the waste toner tank.
1. Open the front cover
2. Lower the transport unit
3. Pinch the cleaning blade release lever and slide the cleaning unit out.
4. Remove the 4 screws in the top cover of the unit.
5. Dump out the waste toner.
Mar 14, 2011 | Ricoh FT5832 Copier
I'm getting error E-1 on this old guy - Ricoh FT 4027 which makes itimpossible to function . it just halts in E1 position . based on myinvestigations this error is related to lamp , but what should I...
The E code tyo refer the exposure lamp malfunction.Turn ON the main switch,remove the rear cover and turn the DIP switch 101 01 ON and OFF,and turn tha main switch OFF and ON.
Aug 13, 2010 | Ricoh Aficio 1035 Copier
I have a RICOH FT 4022 copier and it displays E 5 error code. It does not allow copying. I have checked the fuser unit and its ok. What could be the problem? Do I need a reset code to solve it and where do...
The E5 code is the fuser malfunction error.
E52 fusing lamp warm up error.Possible causes thermistor open,heater lamp open,thermofuse open.
E53 fusing lamp overheat.Thermistor in shortcircuit
E55 fusing thermistor open
When service call E5 conditions occur they cannot be cleared by turning OFF/ON the power switch.To reset turn ON the main switch,turn DIP switch 101-1 ON and OFF(the DIP switch is located in rear part under main supply board).,and turn the main switch OFF and ON.
Nov 11, 2009 | Office Equipment & Supplies
I have a RICOH FT 4022 Copier and when I switch it displays U 6
Ricoh 4022, 4027 Код ошибки Описание C1 Front door open C2 Exit door C3 Cassette cover C4 LCT cover C5 Sorter open or not latched to machine, or fuse 304 on DC power board C6 ADF cover C7 Right side cover E101 Exposure lamp too long E103 Frequency problem E120, 121 Scan home problem E124 Scan drive problem E140 Lens home, or fuse 303 on DC board E141-143 Lens home sensor, fuse 303 on DC board E144, 145 Mirror sensor, fuse 303 on DC board E191 Image density sensor error E302 Charge roller problem or HVT problem E346 Bias loss E351 Image density sensor problem E352 TD sensor error E353 Vsp problem. Dirty or bad image density sensor E354 Vsg problem. Same as E353 E355 Toner density sensor problem E356 Same as 355 E405 Transfer belt or charge roller drive E440 Main drive E442 Drum charge thermistor E501 Upper lift motor E502 Lower lift motor E503 1st tray motor E504 2nd tray motor E505 3rd tray motor E506 Tray main motor drive problem E507 LCTl lift motor E522-525 Jogger sensor E541 Fuser thermistor E542 Fuser temperature too low E543 Fuser temperature too high E544 Fuser temperature too high E547 Fuser lamp won't shut off E548 Fuser temperature too high or too low E620 Communication problem between main board and ARDF E621 Communication problem between main board and sorter E623 Communication problem between main board and paper trays E720 Sorter stapler timing roller sensor E721 Sorter stapler bin lift sensor E722 Sorter stapler jogger sensor E723 Sorter stapler grip sensor E724 Sorter stapler error E900, 901 Copy counter U2 Key counter U6 Fuser unit not installed properly U7 Duplex unit
Aug 24, 2009 | Office Equipment & Supplies
Ricoh FT4022 error E-1
E1 Exposure Lamp problem. (sensor, lamp, lamp stabilizer)Either the lamp is blown, the board is bad or the sensor is bad.
Feb 12, 2009 | Ricoh Aficio 1035 Copier
Ricohh 450. Error code E544 or E-5 comes up. What can I do to fix
This is a fuser error code. Sometimes it is caused by a mis-reading. Use the procedure below to reset this machine.
Press the yellow "clear modes" key then pres 1, 0, 7, then press AND HOLD the red "clear stop" key until the screen changes. After the screen changes, turn the machine off at the red switch on the front of the machine. Turn it back on.
If the code comes back you will have to call a service tech to troubleshoot and replace parts.
Nov 25, 2008 | Ricoh Aficio 450 Copier
E1 ERROR ON RICOH FT4022
Nov 11, 2008 | Ricoh Aficio 1035 Copier
ther is arest of this error code you can get it by pressing (.) key on the panel to read 2 numbers and then report again
Ricoh Aficio 1035 Copier Logo
120 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
