The first test you can do is to disconnect all the speakers either by switching off the speaker A and B on the front panel or disconnecting all the cables from the back terminal Make a note of which wire goes where for reconnection.
Then turn it on and see how long it stays on. Low speaker impedance can also trigger protection circuit. This will confirm if its external or internal problem. Internal will require professional help.
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
A precise make and model might yield more-specific answer.
