Are you sure you pressed the correct location on your screen???
If so, you may need to calibrate the screen.
Do this:
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
To recalibrate the touchscreen on your
nuvi 200 series follow
the steps below:
- Have the unit turned OFF and
unplugged from power.
- Slide the power switch to the
ON position and hold for about 45 seconds.
- A message will display on the
screen: Press Dot.
- Once this message displays,
release the Power button.
- Press in the center of the
Dot.
- Keep pressing in the center
of the Dot as it moves around the screen.
- Once this is complete, there
will be a message: Calibration Complete.
- Touch Ok and the unit will
restart.
The touchscreen will now be recalibrated.
*Note if unit is running software version 6.00 or newer you will want to
follow steps from below.
nuvi 205 series follow
the steps below:
- Place your finger in the top
left hand corner of the touch screen and apply pressure.
ON position.
- Hold pressure in left corner
until the Press dot message appears.
remove your finger from the screen.
Dot.
restart.
