OUR COMPUTER IS WINDOW 2000 AND WE WOULD LIKE TO INSTALL OUR EPSON PRINTER LX800
    President:
  • 2,340 Answers
Download the Dot Matrix Printer Drivers @ "Generic 9-Pin Printer Driver v1.0bEs"
OS: Windows 98, Windows 95, Windows NT 4.0, Windows NT 3.51
File: epson10753.exe - 559KB
This self-extracting file contains the Generic 9-Pin Printer Driver for Windows 95, 98, NT 3.51 and NT 4.0 (Printer Driver v1.0bEs, Core Driver Disk v1.0). This file is for use with all Epson 9-Pin Dot Matrix Printers.
Note: Please have your Microsoft Windows CD-ROM available as the printer driver may require some OS files from the CD-ROM to complete the installation.
Hope it helps.
Posted on Apr 11, 2011
Install epson stylus TX110
This is the download link for the driver (Windows 2000, Windows 7, Window Vista, Windows XP):
http://tech.epson.com.au/downloads/RedirectLink.asp?ProductID=StylusTX110&Email=&DownloadID=6052
If I could be of further assistance, let meknow. If this helps or solves the issue, please rate it and give a testimonialfor my response.
Jul 10, 2011 | Office Equipment & Supplies
I have an Epson CX4800 printer. It won't print because there is low ink. My laptop indicates that the ink is low, but won't tell me which color it is. How can I connect the two so that I know which ink is...
What OS are you running? Did you install the full Epson software before you connected the printer to the computer? Is the Epson Status Monitor running on the computer?
If you didn't install the full software or installed a generic Windows driver, uninstall the printer. Then disconnect the data cable. Reboot the computer and go to http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_SessionID=@@@@1326618163.1304563464@@@@&BV_EngineID=ccfkadfdhhmeimgcfngcfkmdhjidfmh.0&cookies=no&oid=58606&prodoid=56291067&infoType=Downloads&platform=All . Download and install the appropriate file from the section marked Drivers and Utilities Combo Package.
If you have a Windows OS, if the Epson Status Monitor is running, the icon for it should be present in the lower right hand corner of the screen (status/Notification area). In Windows 7, it may not be immediately visible, click on the double arrow symbol. Then double-click on the Epson Status Monitor icon and the status window should appear with the ink level indicators in the bottom half of the window.
For a Mac OS, open the Applications folder, then select Epson Printer Utility. Select your printer and click OK. Then select the Epson Status Monitor to get the ink level window.
I hope this helps.
(this is generally faster than using the No Ink spot inside the printer. However the ink levels are approximate.)
May 05, 2011 | Epson Stylus CX4800 All-In-One InkJet...
WE WANT WINDOWS 7 EPSON PRINTER R230X
Epson Stylus Photo R230 6 Colour Inkjet Printer files Driver Printer Driver 6.52E
Windows 2000, Windows 7, Window Vista, Windows XP Posted: 24/11/2009
Click here Utilities Epson Easy Photo Print 2.23.01
Windows 2000, Windows 7, Windows 7 64-bit Edition, Window Vista, Windows Vista 64-bit Edition, Windows XP, Windows XP 64-bit Edition EPP_22301_EHKT.exe
Posted: 19/1/2011 Download
Feb 05, 2011 | Epson STYLUS R230 InkJet Photo Printer
I WANT TO DOWNLOAD EPSON LX800 DRIVER SUITABLE FOR WINDOWS7ULTIMATE
go to control panel/system security/device manager device mager/ scan device if you see a driver yellow icon like this(?) click it printer and update driver online. step by step. automatic run online...
Feb 01, 2011 | Epson Office Equipment & Supplies
Epson printer and windows vista wont talk to each other
Windows Vista should automatically detect and install devices attached to the computer. Simply connect the printer to your computer and power it on.
If the driver does not automatically install, you can follow the steps below to install a resident driver which is part of Windows Vista. The resident driver installation should only be used if the printer is not detected and installed.
1. Click on START, CONTROL PANEL and PRINTERS.
2. Click the ADD PRINTER button. If you do not see ADD PRINTER, right-click in the PRINTERS window and select ADD PRINTER from the menu.
3. The ADD PRINTER wizard window will appear select Add a Local Printer.
4. Select the port the printer is connected to from the drop down window beside Use an Existing Port, click NEXT.
5. In the next window select EPSON under Manufacturers and your printer model under Printers.
6. In the Type a Printer Name window, Set as Default is automatically selected. If you, have another printer that will be the default simply remove the check and click NEXT to install the driver.
7. Ensure the printer is directly connected to the computer and that the printer is ready to print. Click PRINT TEST PAGE to test the printer.
8. Once the test page has printed, click FINISH to exit the wizard.
*NOTE:
-Depending on your system the computer may ask for your Windows disk, if so insert your Windows CD into your CD-ROM drive and click OK.
-As the driver is part of Windows Vista, there is no Status Monitor available for your printer. Some printers may have an INK LEVELS options included as part of the resident driver. Otherwise, the printer does have its own indicators. The RED error light will flash when the printer is low on ink and go solid when it is out.
-If the ink levels do not appear, click GET INK LEVELS from the MAIN tab of the printer driver. Ensure the printer is directly connected to the computer as the Ink Levels does rely on full bidirectional communication.
Jun 11, 2008 | Epson Stylus Photo R300 InkJet Printer
Not install for windows vista
In any Windows environment, the printer itself becomes a dummy terminal and all changes to the printer will be over-ridden by the application or the operating system.
*NOTE: Depending on your system the computer may ask for your Windows disk, if so insert your Windows CD into your CD-ROM drive and click OK.
To make adjustments to the output quality and speed in Windows Vista, please do the following:
1. Click on START, CONTROL PANEL, and PRINTERS.
2. Right click on the printer icon, and choose PRINTER PREFERENCES.
3. Click on the ADVANCED button in the bottom right corner.
4. Click on the GRAPHICS option and click the down arrow.
5. Choose the lowest number to drop your resolution and pick up your speed.
6. Click on PRINT FEATURES and choose the option HIGH SPEED ON.
7. Click OK to apply the changes.
8. Once again right click on the icon for your printer, and choose the PROPERTIES tab.
9. Click on the ADVANCED tab and click on the button called PRINT DIRECTLY TO THE PRINTER.
10. Click APPLY (if applicable) and/or click OK to apply the changes.
The driver you are using is a graphics driver and may not have the adequate speed for your purposes. In Windows VISTA there are more basic drivers which respond better to custom page sizes and speed adjustments. Windows also has a driver called GENERIC TEXT ONLY which is made as a universal driver for all printers just for speed. To add in either of these drivers please do the following:
2. In the left hand column choose the option ADD PRINTER. The ADD PRINTER WIZARD comes up, click on NEXT.
3. Select Add a Local Printer.
4. Click on NEXT.
5. Select the port the printer is connected to from the drop down window beside Use an Existing Port, click NEXT.
6. In the next window select EPSON under Manufacturer. Please use the guide below to select an appropriate Emulation driver. If you wanted to install the Windows universal driver, choose GENERIC under Manufacturer and choose TEXT ONLY, click NEXT.
EPSON LQ SERIES (136): Used for LQ wide carriage printers
EPSON LQ SERIES (80): Used for LQ narrow carriage printers
EPSON LX SERIES (136): Used for LX wide carriage printers
EPSON LX SERIES (80): Used for LX narrow carriage printers
EPSON FX SERIES (136): Used for FX wide carriage printers
EPSON FX SERIES (80): Used for FX narrow carriage printers
7. In the Type a Printer Name window, Set as Default is automatically selected. If you, have another printer that will be the default simply remove the check and click NEXT to install the driver.
8. Ensure the printer is directly connected to the computer and that the printer is ready to print. Click PRINT TEST PAGE to test the printer.
9. Once the test page has printed, click FINISH to exit the wizard.
Jan 22, 2008 | Epson LX-300 Matrix Printer
Epson
Epson says use the built in driver
Follow these steps to set up your Epson product and install the built-in Windows Vista drivers:
  1. Set up your computer.
  2. Connect your Epson product to your computer.
  3. Follow the on-screen instructions that Windows Vista displays to guide you through product driver installation.
Dec 18, 2007 | Epson Stylus C86 InkJet Printer
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
