Question about Dell XPS One All-in-One TV Desktop with Intel Core 2 Duo Processor E4500 - (PRODUCT) RED
My disc is stuck in my harddrive i have a dell xps one and everything is together
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 332 Answers
Here is a easy fix and all you need is a small paper clip. Turn your computer completely off first. Take the paper clip and open it up so its straight. Now look at the front of your DC/DVD drive. You will see a pin hole that the paper clip can fit in to. Put the paper clip in the hole and give it a push. The drawer will pop open, then with your hand pull it out the rest of the way and remove your disc. Start your computer back up and either the drawer will pull in by itself of just give it a push and it will pull back in for you.
I hope this helps you out and if it does please give me a YES on the page you received this response on. Thank you
Posted on Apr 11, 2011
Why dell xps 2710 will not boot
Did you make a RECOVERY DISC when you first operated the machine, if yes then open the drawer and insert disc then start machine and follow the instructions.
Jul 21, 2014 | Dell XPS One 2710 All-in-One Desktop
Dell XPS M1210 Stuck on blue screen due to hard drive
To determine if your hard drive is bad or good, run the Dell diagnostics.
Here is a link for the owner's manual of your model:
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_xps_laptop/xps-m1210_owner%27s%20manual_en-us.pdf
Feb 08, 2013 | Dell XPS M1210 Notebook
I have Dell XPS 420 , with windows home server running for some time. I tried to insall/upgrade RAM from 3 gb to 6 gb. So, i found the right RAM (2x2GB) and removed the two old 512 mb from the slot and...
According the the dell specification you can only install up to 4gb, so I don't understand you saying that you were upgrading from 3gb to 6gb. Make sure that all the ram that is installed is of the same brand and speed (667 / 800 MHz Dual Channel Dual DDR2 SDRAM). The fact that it is saying no boot device also would suggest that it is possibly something wrong with your harddrive, whether it was corrupted or damaged while you were changing the RAM, if you have a spare harddrive try installing and booting from it. If that doesn't work it could be a motherboard issue, which the BIOS should be update, all the jumpers on the board should be checked etc. Its rather hard to diagnose a problem such as this, and the fact that after you installed the new RAM, even the old RAM would not work, suggests that you may have damaged something while messing around in the computer.
May 19, 2011 | Dell XPS 410 PC Desktop
Is it possible to take my IDE harddrive from my old dell dimension 8100 running 'XP' and install it as a second harddrive in my dell studio 8100 studio xps with W7, then boot "XP" from harddrive...
If your motherboard in your new machine supports IDE and you set the jumper on the HDD to slave then I dont see any reason why you wouldnt be able to use it as a second drive
Feb 17, 2011 | Dell Studio Xps 8100 Desktop Computer
Dell xps 1530 will get to log on screen and go blank
try logging in safe mode first upon turning system on tap on F8 then select safe mode, once logged in safe mode to a system restore to the date before this issue happend if system restore gives an error it failes tr going back to system restore in safe mode the do a disc defragmentation click start, accessories, system tools, system restore then select restore my computer to an earlier time then select the date when everything was working fine
Jun 04, 2010 | Dell XPS M1530 Laptop
Windows won't recognize the HDD in my Dell XPS 400.
hawkdawg
In regards to installing your new harddrive if you are installed a SATA drive the issue is that not all versions of Windows has SATA drives native on the Windows install CD. So during the first part of the install you will need to press F6 to load the SATA drivers of the driver CD. If you do not have it you can download the drivers from support.dell.com
Let me know if you have any more problems or questions
Issken
Apr 13, 2010 | Dell XPS 400 PC Desktop
Enquiries on maximum supported hard disk capacity and memory
Dell Optiplex 760 Vista
Max CPU Intel Q9550
Max RAM 8GB RAM
Largest HDD Shipped 1TB (Will likely Support 2TB)
Optiplex GX260
Max Intel Northwood 2.53 GHz - 533
Max RAM 2GB
Largest HDD Shipped was 200GB (Will likely support 500GB)
Dell Dimension XPS D300
Max CPU 333 Pentium II
Max RAM 384MB
Largest HDD Shipped 16GB (Will likely Support up to 80GB)
Dell Dimension XPS M
Max CPU 166S
Max RAM 64 MB
Largest HDD Shipped 4.3 GB (Max HDD likely 20GB)
Feb 09, 2010 | Dell OptiPlex GX260 PC Desktop
Corrupted operating system dell xps m140. how to
Dell ships their system with factory installed software and recovery discs.if you formatted using a different , the pre installed recovery are gone. so CALL DELL customer service and have them ship you out a recovery disc its for free, i guess if your still under warranty.
Oct 30, 2009 | Dell XPS M140 Notebook
Dell xps m1330 dvd drive will not eject cd inside
Im a dell tech, and i hate those cdrom styles, but, that is what the consumer wants, so we make them. Try starting the machine, then press F2 to enter the BIOS. once in the bios, press the eject button. listen for any noises, (an attempt to eject). if you hear a sound, it means the drive should be capable of ejecting the disc, and perhaps the disc has not seated correctly. If the disc will not eject, you must contact Dell. This is from the DELL dcse site: " Optical Drive The XPS M1330 has a slot-loading optical drive instead of a conventional tray-loading module. There is no mechanical eject mechanism for the drive to eject stuck discs. This means you must replace the drive if a disc gets stuck in the drive. After replacing the drive, disassemble the old drive to remove the disc for the customer."
Jul 21, 2009 | Dell (0F146) Internal DVD Drive
GAME CD IS STUCK WON'T SHOW AS INSERTED SO IT WON'T EJECT
With the slot load models the whole system needs to be disassembled to retrieve a stuck disc. Are you absolutely sure there is a disc in the drive? If so, it needs serviced and may need the drive replaced.
Nov 19, 2008 | Dell XPS M1710, Intel Core 2 Duo T2600 2.0...
Dell XPS One All-in-One TV Desktop with Intel Core 2 Duo Processor E4500 - (PRODUCT) RED Logo
111 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
