Question about Sharp LC46SB54U 46 in. LCD TV
The tv will not come on but the power light blinks sharp lc-46SB54U
  • 1,591 Answers
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably come on and maybe stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Apr 11, 2011
Can I use the USB service port to power a Bluetooth transmitter
Hi Frank,
If you are referring to using your TV as the USB port... you cannot. It's strictly for service. I have tried as well and it won't recognize it. It's strictly for servicing.
Mar 01, 2016 | Sharp LC-46SB54U LCD TV 46 inch Class,...
The tv goes off but there is audio.
If you have sound the inverter board has failed,or one of the ccl lamps has died .when you switch on the powersupply sends power but on receiving a fault condition from either of the two faults above will shut down power to the inverter board.
Len..
Apr 11, 2014 | Sharp LC-46SB54U LCD TV 46 inch Class,...
Power and OPC blinks, TV will not change Input modes
Try removing set and or a box if used from power for several minutes.
Dec 23, 2012 | Sharp LC-46SB54U LCD TV 46 inch Class,...
Sharp LC -46SB54U will not turn on. The green power light flashes twice, then the green power light and green OPC light flash once together. This pattern then repeats itself over an over again. The tv is...
Power supply board just die.It can be dead at anytimes.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Do take care.....
Jun 16, 2011 | Sharp LC46SB54U 46 in. LCD TV
I have a 46 inch Sharp model #LC-46SB54U. The
no_picture.jpg Part Number NOTE Description Product Note Substitute Part n/a Total Availability 0 Estimated Ship Date no longer available
Apr 27, 2010 | Sharp Televison & Video
Need owners manual for Sharp 46'lCD TV Mod.#LC-46SB54U
Owners manuel can be found at www.managemyhome.com right hand side--enter man and model #, to avoid having to sign up, right click and open in a new window when the pdf file pulls up. Its their I just checked.
Feb 24, 2010 | Sharp LC46SB54U 46 in. LCD TV
My sharp lc46sb54u 46 in.hdtv power light keeps blinking
Any indicator light on at all, if you see the light, then only the 5v standby power supply is working but not the main section of the power supply, it can also be the main control board hat is not sending signal to turn on the main power supply section.
Sep 01, 2009 | Sharp LC46SB54U 46 in. LCD TV
Sharp LC46SB54U 46 in. LCD TV Logo
114 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
