Question about Passport 9500i Radar/Laser Detector
I plug it in and it blows a fuse - Passport 9500i Radar/Laser Detector
Why does my cigarette lighter keep blowing fuses every time I plug something into it
First make sure you have the right size fuse in it look at your owners manual it should tell you what size to put in there sometimes people blow a fuse and replace it with a weaker fuse it will work for a while till they plug something in that overloads the fuse then blows and if they sell the car the new owners don't know this they just keep replacing it with same type fuse that's in it. Second make sure whatever it is you are plugging in doesn't have a short itself try plugging in something different and see if it blows then if it doesn't then you know where your problem lies.
May 26, 2014 | Cars & Trucks
Glow plug fues blowes
the glow plugs have a rail/wire that joins /links all of them that rail receives 12volts across it ,check that it is not touching against any metal earth surface ,if it seems to be fine disconnect the power wire to the rail and insulate wire .Then refit fuse and turn on key ,if the fuse blows you know that there is a short in the wiring going to the glow plugs ,if the fuse does not blow it is highly likely that one of the glow plugs has shorted and needs replacing
Jan 15, 2014 | Cars & Trucks
Fuse blows when I plug in the tv
Check the circuitry that leads the the fuse. Usually when a fuse blows something else is wrong. Something else has failed and is sending too much voltage to the fuse.
Oct 06, 2012 | Televison & Video
Fuse blows when plugged in
I assume it's the fuse in the TV that blows. You more than likely have a bad or shorted low voltage power supply. Probably not worth fixing with the cost of parts & labor.
Fuse blows when I turn on the right turn signal.
whichi fuse? only when right turn signal. not left. ?
Aug 27, 2011 | Honda VT 1100 C Shadow Motorcycles
My tail lights are not working, it keeps blowing my fuse.
1.Unplug your taillights at the sockets and the front running lights from sockets.
2. put in new fuse after unplugging taillights.
3 turn on taillights if fuse blows then the wiring is grounding out somewhere between the switch, fuse panel, and rear and or front parking lights.
4.If fuse does not blow then plug in one socket at a time keep rechecking fuse. when the fuse blows after plugging in a certain socket suspect that one to be bad and replace.
Sep 15, 2010 | 2005 Infiniti G35
My fuse blows everytime i plug in my sirius radio to cigarette lighter...why?
is that the only device that is blowing a fuse? if it is the only thing blowing your fuse you may need to replace the charger. check the fuse to make sure it is the correct size ( usually 10 amp). check the power adapter to make sure there are no loose connections or anything in the plug that doesn't belong there. unplug the radio from the adapter and plug the adapter in without the radio see if the fuse blows . if it blows replace the adapter. if it doesn't blow the fuse check the adapter to make sure it is the right one make sure the polarity is correct
May 12, 2010 | Sirius Satellite Radio Receiver
My charge port in my 2006 cadillac cts repeatedly blows the fuse. How can I fix this?
Does the fuse blow every time you plug something into it? I guess what I'm getting at is it possibly your phone charger only, or does the fuse blow when someone else plugs thier charger in (different charger)? I guess if the fuse blows, no matter what you plug into it, I would suspect the charge port itself. Does it seem like it's loose in it's mounting bracket? You may have to replace the port.
Jan 03, 2010 | 1995 Cadillac DeVille
Brake lights blows fuses
Please check the brake light wiring there must be somewhere where the live wire is touching the body (earth -) and thus the blowing of the fuses.
Since the plug in had melted so must have the wires insulation top melted somewhere and its now shorting.
Hope this helps.
May 22, 2009 | 1996 Lincoln Continental
Unpluged the crt circuit boards. was getting 2-2 code and burning fuses
Okay. now what you have to do is plug one crt back in and try it if the fuse doesnt blow then plug in the second CRT and try it again. then if it still doesnt blow with the two CRts plugged in then plug in the last crt if it blows thats the bad crt, and it will need to be replaced. But when you plug in the bad CRT the fuse will blow. Then let me know which tube as I have a good source for mitsubishi CRTs at real cheap prices.
Jun 24, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Passport 9500i Radar/Laser Detector Logo
26 people viewed this question
Top Escort Vehicle Parts & Accessories Experts
Jason
Steve
Are you an Escort Vehicle Part and Accessory Expert? Answer questions, earn points and help others
