Question about Iomega 1TB Desktop USB 2.0 Hard Drive
My iomega external hard drive just beeps when ever i turn it on. How can I fix this?
Ummm, i fixed my problem i had with a iomega 500gb external hard drive, it was beeping at me also, so what i did was i knocked it on its side, switched it off, by its own panel, then switched it back on, it came back into life and was recognised again!!
so try it with yours!
I think what what happens is, when you accidentally drop it, or knock it from time time(accidentally), the needle inside the hard drive goes out of place, and the hard drive will beep, or something to that effect. knocking the case itself again, might fix the problem, or maybe not, thats if the hard drive itself is more severely/inherentally faulty.
Posted on Jun 20, 2011
  • 1,591 Answers
Either the power supply is failing, or the drive has gone defective.
Check with IOmega, it's probably under warranty. If so, get it replaced.
If it isn't, open up the casing and see whose drive (ie, Seagate, Samsung, Maxtor) they used, because the drive itself may be under warranty by the manufacturer.
Before doing that though, connect the drive inside your PC and see if it works.
If it does, just permanently mount it in there because the external boxs' power supply is shot.
If it works in the PC and you really need it to be external, just buy an external hard disk enclosure.
They are about $30 in most places, and that'll FixYa right up!
Posted on Apr 11, 2011
Crankstart
  • 696 Answers
SOURCE: What does it mean when my 1TB Iomega external
This generally means you have a hardware failure in the drive or enclosure. The simplest way to test which is to have a hardware tech move the drive into a new enclosure and see if it works.
This will void your warranty if you do it, so, if the drive is under warranty and there are no files you consider valuable on the drive, call the manufacturer for warranty support.
If you value the data more than the drive is worth then take it to your local hardware vendor and ask them to test the hard drive in a new enclosure. Good odds it will work this way but if not you may need the help of a data recovery specialist. In North America I use Armor-IT, if you are in a different region and the new enclosure fails to garner results, comment back with your region(Country, State, City) and I will supply you with the closest reputable facility.
Chris
Posted on Jul 08, 2009
Crankstart
  • 696 Answers
SOURCE: Is it possible to open my Iomega Prestige 1 TB USB
Yes it is possible but the Iomegas are difficult to open and you often snap the plastic retainers in the process. Given you can buy a !TB comlete for only about $20 more than buying the raw drive I suspect you would be better advised to simply replace the unit all together,
Chris
Posted on Aug 30, 2009
  • 29 Answers
SOURCE: Iomega large external hard drive doesn't show up
Well this is a tough one. I am assumeing that you have done all the normal things.
Most external hard drives are just a standard internal hard drive with a case and a IDE/SATA to USB adapter built in. When you plug in the drive and it powers up listen to the drive if you hear a clunk. Not a the happy ticking of a normal drive but a bad clunk. This can mean that the controller on the hard drive itself is bad.
If everything sounds happy then I would try replacing your power adapter. I know that the blue light goes on but most of that runs off the 5 volt leg of the power supply (I have has some hardware manufacturers actually pull the power light voltage from the USB port Grrr) most of the Large sized external hard drives use a 12 volt adapter and it can have no problem with the step down to 5 volt it may have a problem with the 12v.The 12v is what it uses to spin the drive. Unless you have one of those little drives. They use a laptop hard drive that works of a lower voltage. Most of the time you can get an adapter from Radio Shack. Be sure to bring the old one so they can get the Volts, amps, poleartity and the type of connector. It is worth a try and keep the reciept. If it is just bad I am sorry but the only way to get the data off is to break into the unit and pull the hard drive out. Then use another USB to IDE/SATA adapter to pull the data off.
Hope this helps a little.
Posted on Sep 13, 2009
  • 739 Answers
SOURCE: cannot copy files to Iomega 500 GB external hard drive.
It depends on how you formatted the the drive.
If it was formatted FAT it will work on both Mac and PC.
If you formatted to HFS+ (the native mac format) then it will only work on a mac.
Posted on Sep 17, 2009
SOURCE: my iomega external hard drive beeps when connected computer
I just bought an Iomega external Hard Drive model number SPDHDU and I couldn't get it to stop beeping when I connected it to my Mac... Then I changed the usb connection from one I had laying around for other devices, to the one it came with and now it works fine!
Posted on Apr 26, 2010
My pc doesn't recognize my iomega external drive. when i turn the drive on it beeps.
Does it work on any other computer?
Beeping normally means a post code error
Nov 28, 2010 | Iomega 1.5TB Desktop USB Hard Drive
My Iomega external hard drive was working this morning but now will not open. Thgere is power and seemingly activity but my desktop either does not see it or does not recognise it. it also sounds as though...
My Iomega external hard drive was working this morning but now will not open. Thgere is power and seemingly activity but my desktop either does not see it or does not recognise it. it also sounds as though the drive is beeping
Aug 09, 2010 | Iomega Silver Series 320GB 3.5 External -...
My iomega external hard drive beeps when connected computer
Jan 11, 2010 | Iomega (33600) 160 GB USB 2.0 Hard Drive
Disk spins ...then I hear a beep...icon does not show up
The hard disk or the adapter case maybe faulty.
To test the hard disk, remove it form the Iomega case and connect it to an USB hard disk adapter and plug it into a computer's USB port.
If this computer see it as an external hard drive and you can open the folders and files then the hard disk is OK, then the Iomega adapter case is faulty.
Then you need a new hard drive adapter case, it doesn't need to be an Iomega brand.
Nov 26, 2009 | Iomega (33654) Limited Edition 500 GB USB...
I can't access my fiels on my iomega drive, it
Is is getting detected . If not the solution is to try for a new one. the internal chips may be damaged.
Sep 03, 2009 | Iomega HDD External Desktop (32660) 80 GB...
Iomega external not visible
Unfortunately, Windows isn't the most efficient operating system when it comes to it's "Plug 'n Play" abilities. In my experience, external hard drives can be particularly sensitive when it comes to unplugging the data cable while navigating the drive. I've had two external drives lose all data because of that flaw in the NTFS file system. The MFT exists on every drive with NTFS storage method. If that becomes corrupt, it can render the drive useless.
The drive may have power, but that quiet beeping you hear is an indication that the reader head is stuck to the platter and may be grinding into it. There is a myth (may or may not be true) that says if you put the drive in your freezer for a few minutes, take it out, drop it from 6 inches onto a hard surface, it may knock the head loose and make the drive work again.
I tried that method, and it made the situation worse for me, but it may work for you. I would resort to that option only if nothing else fixes it.
Aug 08, 2009 | Iomega CORP EGO PRTBL HD 160GB-HS USB 2.0...
Beeping noise
Check the drivers for the hardware.
Jun 12, 2009 | Iomega Silver Series 320GB 3.5 External -...
Iomega Prestige 1.5TB external hard drive won't start-up properly
Try replacing the power supply. Especially if all you get is a beep and no drive motor noise. The power supply is 12 V, 1.5 A, center positive polarity. Iomega may even replace it for free if the drive is still under warranty. But don't use the phone. Use their free chat-live service. Again, assuming the drive is still under warranty, which is a year, I think.
May 15, 2009 | Iomega 1.5TB Desktop USB Hard Drive
Iomega lphd160-u beeping
Your USB port does not have enough power to support the drive. You will need to use an external power source of try a firewire cable if the drive has that option.
Travis Cable
Mar 29, 2008 | Iomega (33600) 160 GB USB 2.0 Hard Drive
Iomega 1TB Desktop USB 2.0 Hard Drive Logo
2,232 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
