Question about Car Audio & Video
Hi. i have a 15inch xponent subwoofer and the voice coil by the magnet has come un wrapped do i have to buy a new sub or can i take it some place and have it fixed?
5 Suggested Answers
trintek
  • 111 Answers
SOURCE: subwoofer wiring diagram
parallel wiring. hook all 4 positives together and run to the positive output from the amp, hook all 4 negatives together and run to the negative output from the amp.
hope this helps,
trin
Posted on Nov 19, 2007
pjstanley
  • 185 Answers
SOURCE: subwoofers
u have to pay the 100 dollars
Posted on Apr 10, 2008
Doorguy27
  • 30 Answers
SOURCE: wiring a sub with duel voice coil
In short yes. And is very common even has its own term called bridged. Taking two channels and making them one. I would hope that you are running a cap. that's going to put out a lot of power and stress on your battery
Posted on Feb 10, 2009
  • 13 Answers
SOURCE: What size is the voice coil in my 1100w 10" sony xplod sub?
go to the sony website or any dealer website and look at the model number of your sub, punch that in and get the measurement.. mostly gonna be inches.. but then go to google and convert it to mm
Posted on Apr 08, 2009
I have 1 audio bahn eternal series awes15p 15inch subwoofer.I'm having problems hooking it in my vehicle,I don't have the wiring manual.I would appreciate if you can tell me or give me a...
There are some things to think about when you install this.
1. Is the sub a dual or single voice coil?
2. What ohms are the voice coils?
3. Is your amp 2 channel or mono?
4. What are the ohms loads allowed by your amp?
I am going to assume your sub is dual 4 ohm and you want to get as much power out of your amp as you can. I am also assuming the amp is a mono channel amp. (if it's a two channel amp, you can bridge the channels)
Go from the positive of your amp and wire to both positives of the voice coils. Then go from the negative of the amp to the negative of both voice coils. You will have 2 sets of wires to your sub. This is called a parallel set up. This drops the load of one dual 4ohm sub to a 2 ohm load. The lower the resisitance, the more power is able to flow from your amp, giving your more sound. Make sure your amp is 2 ohm stable.
Hope this helps
Aug 25, 2011 | AudioBahn AW1500 Car Subwoofer
I have a Kicker Solo-Baric, L7, 12 inch subwoofer making a scratching noise. The cone is fine but the inside is not. Can i get this repaired? Kicker said no. This is a $250-300 sub. I hate to just throw it...
The bad news is that your voice coils could be fried up, basically mechanical failure. Might as well buy a new sub because replacing a voice coil means you got to rip the whole sub apart, very complicating.
Oct 15, 2010 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
Subwoofers don't work
the voice coils are probably fried. you may want to check your amps to see if they are putting out dc voltage. you may be abel to find a place that can fix the subs. otherwise you will need to replace them.
May 06, 2010 | Sony 12" Single-Voice-Coil 4-Ohm Subwoofer
Blown voice coils
Well the voice coil is a basic electromagnet. Electromagnet is a coil of wire, usually wrapped around a piece of magnetic metal, such as iron. there are many things need to keep in mind while replacing the voice coil like - wire size, length, type...... usually the speakers not works good after replacing the voice coils and replacing the speakers is the better option regarding money..... anyway you can please tell us the type or model of your speakers if you need more help or information........
Good Luck!!
Thanks
Jan 29, 2010 | PowerBase Car Audio & Video
I have the 15inch eclipse subwoofer and the
no unfortunatly that sub is a gonner
Dec 04, 2009 | Car Audio & Video
Phoenix gold ti 12d sub gets hot shuts off amp
Depending on your location most places will replace certain things. You may try and see if your sub has any type of warranty. But yes I do believe it would be consistent with a voice coile being bad.
Oct 27, 2009 | Phoenix Gold Ti12D Car Subwoofer
Blown voice coil
you will need to buy a recone motor kit for your sub
Jul 04, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
My magnet cracked on my jbl sub woofer can it be fixed
You might be able to get the manufacturer to replace it. Sub woofer repair is possible and some manufactures do offer that service, you'll have to check with them though. There is one other thing to consider- does it still work? If so you might be in luck. The magnet is there for its magnetic feild not how it looks. So if the magnetic field is un-affected and the voice coil is in one piece and un-obstructed it should be just fine. If the field is slighty out of place or not as strong it will probably affect its performance though. Good luck.
-Dynami
Mar 24, 2009 | JBL PB12 Subwoofer
How should I wire my 3 subs to the 500/1 amp???????
First of all how many ohm's are each subwoofer rated at . Are the subwoofers dual voice coil or single voice coil. Once I know that I can help you. I think the JL amp is not recommended below a 2ohm load.
Mar 16, 2008 | Jl Audio 500/1 Car Audio Amplifier
Blown voice coil (punch)
No. You would have to find a vendor of the wire used in voice coils and wind them yourself, which also means you have to pull the cone out without damaging the surround or spider , and be able to put is all back together too . Your best bet with an older sub is to find a good deal on ebay.
Dec 05, 2007 | Orion Cobalt 73CX Car Speaker
Car Audio & Video Logo
59 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
