Polaroid 40 inch television. i need a powerboard for it. the set comes on for a few minutes then the color blends and goes out but the sound is still working. if you leave it on like that it starts to screech real loud.
  • 1,591 Answers
You didn't say what model you had, but I believe this to be a fairly generic issue anyway that's affecting a wide variety of manufacturers at this time.
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Apr 11, 2011
Polaroid tv screen goes black after 30 40 minutes, sound is good. No picture. Turn set off and wait a few minutes and the picture returns for a few minutes then goes black again.
Ur tv now power on only have picture few mins,than dead,have sound only?Yes,than the 1 or 2 the long board call the LCD inverter boards are dead.The LCD inverter long boards help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy 1 or 2 long LCD inverter boards for the replacement.
Jul 05, 2010 | Polaroid FLM-3232 Television
Polaroid tv goes immediately off after turning on
Ur tv power supply board is defective.That the board where the a/c power cord go into it.Replaced the power supply board,ur tv will have stable power and work again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 27, 2010 | Polaroid TLA-04011C 40 in. LCD TV
Fixes for a Polaroid TV thats not turning on
Hello:
37 inchs have a television of the problem is that it works like 10 minutes and turns off the image, has sound but no image, turn off and on again returns to normal work and 5 minutes the picture goes but still sound, can you help?
Oct 20, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Screen goes black after being on a few minutes, Turn it off and back on picture comes back but only for a few minutes
something overheats inside your set, causing it to turn off before causing more damage. please have your set inspected by a certified technician.
Aug 31, 2009 | Polaroid FLM-4201 42 in. LCD Television
37 inch Polaroid monitor Stopeed working
This sounds like the power supply board has gone bad. Someone knowledgeable in electronics can check the fuse(s) on the board. If necesary, the board can be replaced.
Dec 21, 2008 | Polaroid FLM-3701 Television
Black and White
on a low signal input to the set the first thing you loose is the color, then it goes snowy and then just snowwhite in a snow storm or all blue with no sound.
check your cables for no shorts and loose connections,
sometimes the color killer control inside the set in the color circuit has to be tweaked alittle.
Jan 18, 2008 | Toshiba TW40X81 40" Rear Projection...
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
