Question about Tommy Bahama Aloha Aviator Sunglasses
Broken frame on right side - Tommy Bahama Aloha Aviator Sunglasses
  • 8,197 Answers
You can send your glasses to the link below to have them repaired.
http://www.sunglassreplacementlenses.com/
Posted on Apr 11, 2011
The rear right wheel on my John Deere Z225 is scrubbing the frame.
A: Scribbling the frame:
-Possibly the bolts on the wheel are lose. And it turn warble that's why it scrub the frame.
B: Uneven cut:
-Uneven cut is not the tire or wheel. Possibly the height adjust on the cutter deck is broken or lose bolt. Or may be bend cutter blade as well.
Check it out
Good luck
Mail
Jun 12, 2018 | John Deere Garden
Where is the engine number
The frame serial number is stamped on the
right side of the frame down tube.
The VIN number label is located just below
the frame number on the right side frame down tube.
The engine serial number is stamped on a pad on the left
side of the crankcase and the right side of the
crankcase. not sure if the VRods are the same.
Jul 14, 2014 | 2007 Harley Davidson VRSCAW VRod
My spring break is broken,how do i put the new on?
On what? Most drive springs hook idler bracket to right side of frame.
Mar 24, 2014 | Husqvarna Garden
I bought a second hand Quinny Buzz, and the clip for the frame lock is broken
Hi
The transport lock is available as a spare part item - who did you speak with that advised you it wasn't?
RRP for the transport clip is 10GBP and you can order via your local Quinny retailer or direct from the customer care team on 01284 413 141 Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays)
Sep 11, 2012 | Quinny Buzz Baby Gear
I have a dell vostro 1310. as far as i know the part where we screw in the hinge to the LCD frame has broken ( ONLY THE PLACE WHERE WE JOIN THE HINGE TO THE LCD FRAME( LEFT SIDE & RIGHT SIDE AS WELL...
I think you are mentioning the laptop bezel. Well, mention your model no: and size of the LCD screen to the shop guy. He'll order it for you.
Apr 17, 2010 | Computers & Internet
Have problem with door on Frigidaire Electolux dishwasher. Door "falls open" rather than eases open.
there is a spring that connects to the side of the door (both right and left) than connects to the holes on the bottom of the dishwasher frame. These springs have either fallen off or broken. To see the area where they connect you will need to remove the very bottom panels below the door. Look at the frame where the leg height adjustment screws are and you will see several holes in the frame the springs will most likely be right there and just need to be reconnected to the frame itself. If the springs are not there then the springs will more than likely be right at the bottom left and right side of the doors. These springs should be set in the 3rd hole back from the front if the door drop is still too fast set the spring further back on the frame.
Hope this helped
Dave
Feb 04, 2010 | Electrolux Frigidaire Professional Series...
I have a Kenmore dryer from 1979 and when I open the door it just falls down. Is there anything I can do to fix this?
Check the door springs. One or both may be broken. Remove bottom panel and look to the right or left sides for the springs. If broken, just replace the same. One end of the spring hooks into the door hinge assembly and the other end hooks into the base of the frame. You should be able to see a hole in the frame to hook the spring as you will also see a hole in the hinge assembly. Easy fix. Just have to know where to look.
Jan 16, 2010 | Kenmore Dryers
Driver side front seat back bends
The seat back frame is broken, in most cases it can be welded but all the trim must be removed and the seat dis-assembled down to just the frame, any upholstery shop can do this job for u, about $100-200
Dec 02, 2008 | 2000 Ford Focus
Broken screen
Most rear projection screen are only secured with a few screws along the bottom side of the screen frame behind the speaker grille . so you have to remove the speaker grille cover then remove the screen frame screws then just slide the frame assembly up to disengage the upper clips.If you dont see any screws through the rear cabinet into the frame this is how your screen frame should come off
Jun 29, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Tommy Bahama Aloha Aviator Sunglasses Logo
75 people viewed this question
Top Tommy Bahama Clothing Accessories Experts
Da Doc
ray gallant
Bill Boyd
Are you a Tommy Bahama Clothing Accessory Expert? Answer questions, earn points and help others
