Question about Dryers
Stackable washer and dryer. The dryer squeaks very loudly when in use.
  • Dryers Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots they will make a thumping type of noise or if there is too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3inOne oil. Reassemble the dryer, plug back in. This should solve your noise problem.
This is a FREE answer, Please rate me
Posted on Apr 11, 2011
Kenmore stackable dryer squeaks So loud. How can I fix this.
A model number would greatly help, the dryer is most likely made by Frigidaire for Kenmore, your squeal is probably from a dried our drum support bearing at the rear center of the drum. If this is the case, an experienced repairman is advised to make this repair. Pleazer Appliance...
May 18, 2014 | Dryers
Kenmore stackable wash/dryer Dryer squeaks so loud. How do I stop the squeak.
You probably have a bearing in one of the rollers that spin when the dryer is turning. You'll have to take the front panel off and remove the dryer tub by taking the belt off. You'll then see two doughnut shaped wheels attached to the back panel. Check and see if one or both are loose on the shaft that holds them. If they are replace them. Lubercating is not an option. If they seem ok, check the wheel that the belt loops through and make sure it spins without wobbling. One of the three things is causing the squeak.
I have a frigidaire stackable washer and dryer one solid unit the dryer will sqeek really loud when the drum turns but it sqeeks in the same position every time. but it does sometimes and sometimes it does...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Feb 01, 2011 | Frigidaire Dryers
My kenmore stackable dryer squeaks really loudly. how to stop this it's making me crazy
heatman101
Asker
Jan 23, 2011 | Kenmore Dryers
Kenmore 417.84042500 stackable gas dryer. Started
It sounds as if the bearings in the dryer have gone bad. The same thing happened to my dryer.
Oct 22, 2009 | Kenmore Dryers
Irregular squeaking from stackable dryer
Post your make and model please. Sounds like the rear drum bearing is dried up
Feb 20, 2009 | Frigidaire FEQ332E Electric Dryer
Dryer makes a loud squeaking/squealing noise while drying.
If the dryer model number begins with 417, the drum is supported by a ball bearing in back, and a seal and glides up front. Often, the bearing will become very dry, either from years of use, or from excessive lint blowing up into the bearing. If the bearing isn't cracked or otherwise noticeably bad, you can usually solve the issue simply by lubing the bearing with a high temp grease. While the machine is apart...(a major pain in the butt), make sure to check the condition of the seal and glides on the front panel, and replace the belt if it looks at all cracked or frayed.
If this dryer is not a 417 and/or does not have a rear bearing, it's best to get a maintainance kit (belt, idler pulley and drum rollers) and install all the aforementioned parts, as they are the most likely source of screech. Also, check the motor by spinning the shaft manually with the belt off....if that is squeeking, it's motor
time.
Jan 15, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
89 people viewed this question
Top Dryers Experts
