Question about Refrigerators
Electrolux icon refrigerator e23cs75dss7 Ice maker Auger motor does not turn when ice paddle is depressed. Motor turns when power is applied directly to it, so I know the motor works. Solenoid pops up, turning the metal rod to open the ice 'gate' above the paddle but usually sticks and doesn't go back down. Maybe the auger issue is the relay? Not sure about the solenoid.
3 Suggested Answers
SOURCE: GE refrigerator model GSS22 WGMD ice maker motor
If you cant manually turn your auger motor, it may be bad. Does it dispense solid ice or no ice at all? Another thing may be your control panel. That could be bad too, it's the one sending juice to both your solenoid and auger motor.
Posted on Jul 24, 2009
  • 1833 Answers
SOURCE: GE model GSS221FRFBB side by
The first thing you needto determine is if the problem is electrical or mechanical. To do this pressthe button to get ice, if you hear a noise and the ice dispenser doesn't workthe problem is mechanical and if you don't hear any noise the problem iselectrical. If you determine the problem is electrical. Thedispenser board is the most likely problem but it can be hard to check, so youneed to eliminate everything else first. If the flap opens when you push thebutton to get ice but none of the other mechanical parts move it can be a looseconnection at the door hinge or in the auger motor housing. First, take thecover off the freezer hinge and make sure the wires are plugged in good. Nowcheck to see if your problem is fixed. If not take the auger housing and checkto see if the all the plugs are in good. If all the connections are good,replace the dispenser board. If theflap doesn't move when you press the switch to get ice, then it may be themicro switch. Take the cover off the front of the dispenser then remove thedispenser control. Now you should be able to see the switch unplug refrigeratorand remove wires from switch. Using your ohmmeter, check the switch and youshould have continuity between the terminals that are marked C and NC when youdepress the switch. If you don't have continuity, replace the switch and if youdo, replace the dispenser board. Lookin the ice chute and see if ice is getting hung in there. If so the problem isin the ice chute. Ifthere is ice building up around the ice chute then something is wrong with theice flapper. First look to see if it is closed all the way. If not take the icebin out. Now push the switch to get ice and watch to see what the flap isdoing. If it opens and closes but not all the way, look to see if anything isblocking it. If not,it's the flap, the spring, the crank, or the solenoid. Now you need to removethe front cover off the dispenser. Then remove four screws behind the cover andremove the dispenser control. Once off you should see the flap. Inspect thespring to see if it is broke or out of place, if so, replace it. Then see ifthe crank is broke, if so, replace it. Now look at the flap to see if the edgesare rolled over or is broken, if so, replace it. Now forthe solenoid, sometimes it gets rusty and won't close all the way. Sometimes itoverheats and welds itself open, if this happens it won't open or close. In anycase, if it doesn't open or close properly replace it. If the problem is not theice chute and not electrical, the problem is either in the auger motor housingor the ice dispenser buckets. To determine this, first remove the ice dispenserbucket, select cubed ice, open the freezer door, press the door switch andpress the button to get ice. What should happen is the solenoid should lift upand the auger motor should turn. If the auger motor doesn't turn but thesolenoid lifts up the auger motor is frozen or bad.
Posted on Jul 11, 2011
Frigidaire frs6lf7fm. Ice maker dispenser, the auger won't turn (tested with ttay out). It makes ice and dumps it into the bin no problem. And the water side is fine.
[FIXED] Icemaker auger motor won't turn - ApplianceBlog
www.applianceblog.com/.../18196-FIXED-Icemaker-auger-motor-won-t...
Apr 16, 2010 - 9 posts - ‎2 authors Does the auger motor need to be re-set or something? I wonder if it shut itself down to prevent burnout (because it had been unable to turn the ... FIXED Auger won't turn to dispense ice.
Jun 1, 2014
Ice maker auger will not turn
Mar 17, 2013
FIXED Ice Auger won't turn
Sep 3, 2012
GE Icemaker: Makes Ice, Doesn't Dispense In Door?
Apr 19, 2005
More results from www.applianceblog.com
Oct 01, 2015 | Frigidaire Refrigerators
The ice maker will not dispense any ice. When the dispenser lever on front panel is pushed the dispenser door opens but the auger motor does not operate. If I thaw the freezer the auger motor will...
It sounds like your auger motor has an issue in my opinion. How i check them is: remove ice bin, open freezer door, hold door switch down, depress the freezer ice dispenser button on the door and see if the auger motor has the torque when it turns, if the motor has power and turns but cant turn w/ torque or has power and dosen't turn. you need a new auger motor. lmk if u need more help!
Aug 04, 2013 | Frigidaire FPUS2686LF Professional 26 Cu....
I have a Kenmore side by side, not sure the model, but it's probably 10 years old or so. It has an ice maker with water, cube and crushed ice dispenser. The ice maker works fine, but it will not dispense...
Most of the time the bin has been removed and not put back in properly. When this happens ice blocks the drive motor. Remove the bin and turn the auger by hand make sure it will turn and is not jammed. Now with the bin out push the light button in that turns the light out and have someone push the button for ice while the door is still open the motor should turn in the back make sure thereis no ice blocking it. If it turns nothing is wrong with the motor. The clicking sound is usually the motor jammed by ice or the auger not engaged on the motor. hope this helps good luck
Aug 15, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Whirlpool side by side GD27DQXFW01; ice cubes are not dispensing
We will need to check the voltage at the auger motor while depressing the dispense switch. If all the other features work on the dispenser panel while I would consider checking the voltage going to the motor. Some auger motors are in areas where water causes the voltage to be shorted by constant moisture. We will need to remove the panel and simulate what you have done on the outside but this time we need to see if the voltage has been altered or if the auger motor itself is defective. Sea Breeze
Oct 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice crusher does not turn
KSCS25FKSS is the model you posted under is this the correct model number.If so the motor should be behind the panel directly behind the ice bin inside the freezer.
Sep 24, 2009 | KitchenAid KSCS25FKSS Side by Side...
Jul 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker works on Kenmore side-by-side but will not dispense
If there is ice in the bin and you hear the auger motor running when depressing switch then the auger is broke or the ice bin is busted , pull the bin out and empty it and de ice it to inspect for cracks. you can also turn the auger/fork in the freezer and it should turn the motor and have some resistance when turning. let me know if you have any other questions.
Phil
Apr 11, 2009 | Refrigerators
Ice dispenser circuit board removal
Does auger motor get power when paddle is depressed? Must hold in door switch to check. Front panel screws in at bottom; remove drip tray. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Frigidaire FSC23F7D Side by Side...
Ice dispenser not working - GE side by side refrigerator
Check auger motor if getting power then probably motor gone , if
not may be switch. good luck
Nov 09, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
