Question about Craftsman Garden
Hi I have a 42" craftsman riding mower that I had
    President:
  • 1,273 Answers
Hello, W/D here.
There is the possibility that oil is leaking into either the cylinder or the exhaust side of the cylinder, and may indicate mechanical damage. Also, bad rings, or stuck rings may also create these symptoms. If you suspect damage may occur to run the engine, then have it serviced. If, however, you can account for how oil might have migrated to the cylinder from the crank case (was the mower stored on end?, Was the crank case overfilled?), you may wish to simply start the engine and let it run, burning the oil off as it runs. This is a judgment call that you will have to make. One easy way to free up the rings is to remove the spark plug, and spray the cylinder liberally with penetrating oil such as WD-40, and allow it to work into the rings. This has probably a 50/50 chance of working, but it can remedy the problem sometimes. The key to getting this to work is to spray liberally, rotate the engine, and respray. This causes the oil to be well distributed, allowing it to work better. Repeat several times, and loosely fit the spark plug back in the hole to keep dirt out between oilings. This can take between several hours and several days, but at some point you'll be wanting to try to run the engine. With the plug out, rotate the engine several revolutions to remove any excess oil, then replace the plug and connect the coil wire. When the engine starts, look for the oily smoke to begin to lessen. If it does, you may be OK, and can continue to run the engine. If it does not begin to clear up, you should shut it down and have it looked at. I know the cost will not be palatable, but it will be considerably less than the cost of a new engine.
Best regards, and I hope that this helps, --W/D--
Posted on Apr 11, 2011
Craftsman 42 " mower w/Kohler 18 horse engine clicks, but will not turn over.
my westwood tractor 1600hp will not charge the battery
Apr 17, 2013 | Craftsman Garden
Tip
My lawn tractor spit smoke and oil and will run sporatically and then die. Any...
Tip for 2008 Craftsman lawn tractor that runs for about 30 minutes then starts to cut out and dies, and will not restart. These tractors have a defective gas cap that will not vent. Simply remove gas cap and reinstall loosely. The best fix is replace gas cap. If your tractor is less than two years old Sears will replace it free. preview_graphic.jpg
on Apr 11, 2011 | Craftsman 42" Briggs Stratton 20 hp Gas...
Release clutch/ brake pedal engine stops / as well engage clutch lever for mover / engine stops. Thank you for taking my question . engine runs well no problem starting engine stops when place mower in...
Hi Carl,
Just had this happen to me. The mower had sat all winter. During that time a couple bearings froze up.
It took a pipe wrench to free them up.
I worked in some oil and that solved it.
You need to check each pulley and bearing to see if you can spin it. If you can't, oil it first, then try to **** it free.
Once it lets go, a little more oil and you are all set.
Best regards
Mike
May 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Murray riding mower 12.5 hp briggs & stratton spitting oil & gas out of carb & muffler when trying to start
Drain oil... it is full of gasoline due to a bad float pin and rubber gromet in your carb. When your float pin and gromet fail, gas just keeps flowing into your carburetor, eventually flooding your motor with gas and oil mix.
Jul 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
147 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
