Question about Telrad Avanti 3000 - - Phone
I don't know the voicemail password for my avanti 3025 phone at work, how do reset it to default so i can create my own
I bought an iphone 4G and I am having trouble changing up my voicemail. It is showing an error that it can't
This is going to depend on what carrier you have, if youre going through a carrier that supports visual voicemail (where its downloaded automatically to your device, not where you have to call in) then you may need to setup your voicemail again. If youve forgotten your password you can call your carrier and hVe them reset it for you. They will either give you a temp password or just remove the password. You now have to reestablish a password and then put it in your phone. To call voicemail either press and hold the number "1" on your keypad under "phone" or simply dial your number and hit call. Once in your voicemail listen to the options, and choose administrative, or setup(these may vary by carrier) then "change your password". Once youve done that, hangup and then choose voicemail under "phone", it should prompt you for your password, just enter the one you just created and the rest should take care of itself. You can also call your carrier and get their assistance if that doesn't work, just call from a different phone so they will be on the line while you work it out. Good Luck!
Apr 12, 2014 | Apple iPhone4 4G iPhone 4
Don't know password
feature 983
it will say log- press 1020000
it will say password-under that it says reset-push that soft key!! press release.
default will be 0000 once you access voicemail(981)
Jan 14, 2013 | NorStar M7310 Phone
I have a RICO AFICIO 3025 and i can't get into admin tools menu because i don't know the USER and PASS to login. How can i reset that USER and PASS to default
If nobody changed the original USER and PASS you just need to enter:
admin (for user) with no password.
If this doent work reply to me.
See you!
Jul 23, 2011 | Ricoh Aficio 3025P Black and White Copier
How do i reset the password for voicemail on a Panasonic KX-T7735
The only way to reset the password if you don't know or remember the original is to call the provider. If you don't know the customer service number, you can always dial 611 from the mobile phone itself.
May 04, 2011 | Cell Phones
I'm a new employee. I don't know the former person's password and no one else does. How do I reset the password on a Norstar M7310 telephone system if I don't know the old password?
Have your system administrator go into voicemail programming and reset the mailbox password. The default password will be "0000".
I hope you understand that having passwords in the first place is a security measure, so I will not give directions for hacking into your companies voicemail system.
Aug 18, 2010 | NorStar Meridian M7310 Phone
How to reset the password for a Lucent Partner 18 phone system. The product is a Lucent Partner Phone system
Depending on the type of voicemail you have, you''ll have to login to the admin mailbox. That's done by pressing your voicemail key or intercom 777. If you have a Partnermail VS the admin mailbox is 99 with the default password of 1234. If you mave a Partner Messaging System the admin mailbox is 0 with a default password of 1234 or 123456. Once your into the admin mailbox press 9 for admin programming. ,(depending on version) press either 2 or 4 administer extensions, enter the mailbox number of the box you want to reset, press 3 to re initalize the password, hang up when done. Your password will be the defaulted to1234.
Apr 17, 2010 | Lands Phones
Voicemail not working How to record a message
Depending on what type of voicemail you have installed this should be the way to setup your voicemail. Typically if you dial your voicemail extension and press * when the main greeting starts it will ask you for your mailbox number. Usually your mailbox number is the same as your extension number and you password is defaulted to your extension number plus 997. If your password doesnt work you will have to go into the administrator mailbox which is 999. the password is usually 999997. Go to option 8 on menu then option 4. this will reset your password on your mailbox to default. Also included a website with Toshiba manuals. Hope this helps.
Feb 24, 2010 | Toshiba DKT2010SD Phone
Need to reset my voicemail password without original password
To reset password on any tel set go to main set and press feature 983 this gets you in to programming you need a password and default password is normly
120000 for 2 digit locals and 1020000 for 3 digit locals etc.enter this password and press ok go in to
mbox type in mailbox press change , press reset password. hope this works
Sep 17, 2009 | NorStar T7208 Corded Phone
I don't know the voicemail password; I am trying to reset it to the default
you will need to log in from a main phone or phone with LCD screen and go to the set you need to set to default in the menu...this maybe only be done through your vendor unless you know the system password to get into the configuration mode.
May 29, 2009 | Comdial Impact 8024S Corded Phone
Samsung DCS Basic 12B phone voicemail
I assume you forgot the passcode to a voicemail box , not the pass code to the voice mail system. The easiest way to fix your problem is to enter voice mail programming(from a telephone) and delete the box and then create the same box again. That way the mailbox when created will come up with the system default pass code
Sep 10, 2008 | Samsung DCS 12 Corded Phone
Telrad Avanti 3000  - - Phone Logo
62 people viewed this question
Top Telrad Lands Phones Experts
Are you a Telrad Lands Phone Expert? Answer questions, earn points and help others
