Question about Kodak ESP 5 Printer
My ESP 5 doesn't print the yellow color, or the black for b/w documents. Have done "clean printer nozzles" many many times, also alignment, etc.
  • 1,218 Answers
The following may work: remove all the ink supplies. Remove the printhead and soak it for about 5 minutes in 0.5" of very hot water. Gently blot the printhead on a soft damp paper towel to remove the excess water, then replace in the printer and then reinstall the ink supplies.
Posted on Apr 11, 2011
Why can't my kodak all in one ESP 5 not print black all of a sudden? There is no color ink but 3/4 of black ink and it will not print this letter so there isnt any color needed anyway.
Remove print head. Now take vessel with 10-20 ml of ISO PROPYL ALCHOHOL ( medical spirit).dip the ink head for 15- 20 min..some old ink may come out..some clogged nozzle should be realesed..no issue keep it.
U may repeat again.dry it.don't used hot blower..just Clean it with tissues.
Also try to clean golden point on printed circuit with wiping eraser carefully on it.make it clean n shiny
God bless
Jul 16, 2014 | Kodak ESP 5 Printer
Brother Printer-copy-scan-photo capture Model DCP-110C After replacing black ink and yellow ink, still says yellow ink low, and will just print out pink menu items, no message. I cleaned it 5 times. ...
place the printer cartridge into a small amount of water to make sure the yellow is flowing out. Let me know what this finds and try it again if yellow comes out.
Also, what exactly did you clean, the metal contacts?
Jul 03, 2008 | Brother Office Equipment & Supplies
Black doesn't print color ok
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Nov 24, 2012 | Brother MFC 490cw Color Inkjet...
I've installed color cartridge but it won't print in color
Try to re-insert the color cartridge into the printer and make sure it is properly seated in the cartridge carrier.
If that doesn't help, try to clean the print nozzles. Please follow the steps below:
1. Press Copy. 2. Press Options until Maintenance appears on the display. 3. Press the right arrow until Clean Cartridges appears on the display. 4. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles. 5. Print your document again to verify that your print quality has improved.
Oct 22, 2011 | Lexmark X6170 All-In-One InkJet Printer
The black ink has stopped printing. Put in two different new cartridges and that doesn't seem to be the problem. It was first noticed when photos were printing out funny even after changing the color...
Make sure you are inserting genuine Lexmark cartridges.
Try to clean the cartridge nozzles. Refer to the steps below:
Cleaning the Print Cartridge Nozzles:
1. Open the Lexmark Solution Center. Click Start > Programs or All Programs > Lexmark 1300 Series. Select Solution Center.
2. From the Maintenance tab, click Clean to fix horizontal streaks.
3. Click Print. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
4. Print the document again to verify that print quality has improved.
Using the control panel
1. Press Menu.
2. Press the down arrow button until you highlight Clean Cartridge.
3. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
Oct 13, 2011 | Lexmark P4350 All-In-One InkJet Printer
How do I correct this printing problem? My colored letters on the page print. Black print doesn't print onto the paper. I have a lexmark z615 printer.
Try to clean the print cartridge nozzles. On your computer, open the Lexmark Solution Center by going to the Start menu > Programs / All Programs > Lexmark Z600 Series > click the Maintenance tab > under Select Maintenance tool, select Clean to fix horizontal streaks > click Print. The printer will then print a test page forcing ink through the cartridge nozzles and clean them.
If that doesn't help, remove the black cartridge and try to manually wipe the cartridge nozzles with a slightly moistened soft cloth to clean it from dirt and clogs. After wiping the nozzles, reinsert the cartridge into the printer. Print a document again to verify that the problem is fixed.
If the problem continues, try to insert a different known working black cartridge to identify if it's a faulty cartridge issue.
If you still need assistance, please contact Lexmark Technical Support Center.
Sep 12, 2011 | Lexmark Z615 InkJet Printer
The print is faded . ther are three color bar missing on the test page ( yellow, black , and black).
Hi
Go into Maintenance in the Kodak Printer Management Program and try the Nozzle Check and Head Cleaning functions until the Test page prints clearly.
Head Cleaning might be necessary after every cartridge change.
I hope this helps.
Aug 26, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Lines running through pictures when printing color and/or black.
Hello sir;you missed one place that is ink cell.
Aug 28, 2009 | Kodak ESP 5 Printer
Kodak ESP 5 runs out of ink after about 40 pages of standard text black & white documents. Also the color ink level is dropping, but no color is being used (the printer is set for black & white...
As far as the quantity of black & white - to get more out of it - go to start menu.. Click on on settings,, then printers,, Right click on the ESP 5,, click on printing preferences,, then clcik on draft,, then click on (at the top) advanced,, click on black & white.. Then click on apply then ok..
Now - every time you print it will be in this mode.. If you want to print in color - you will have to choose that each time..
For you black & white docs - this will print faster & use allot less ink..
As far as your color issue & puddling - It could be the printer head.. If it is new enough - call Kodak & maybe get a replacement.. If to old - maybe keep the color cartrige out and caped with the plastic caps until you need to print color.. Snap it in & out as needed..
I hope this helped..
Jun 11, 2009 | Kodak ESP 5 Printer
Cartridges are full...but only one color, yellow, is printing.
Did you try the printer cleaning on the computer
yo my have to run it a couple of times
Feb 14, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Kodak ESP 5 Printer Logo
151 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
