Question about Bosch PowerStar AE125 AE125 Whole House Electric Tankless Water Heater...
Have an ae125 electric water htr. all power is at unit; elements ohm good and water is luke warm ; only pulling current on one circuit on each tank. power is present at board but does not seem to leave it am leaning toward board but hate to guess at that price cannot prove beyond shadow of doubt . how can i check flow sw or temp element?
I don't know exactly how to solve your Bosch tankless problem, but there are resources for troubleshooting including contacting Bosch and reading manual.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
You can buy 40 gallon tank-type electric water heater at Lowes for $207. Offer 10% less, and look for scratch and dent models with more markdown. Tank-type electric are easy to install and cheap to fix, cheap to maintain.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Apr 11, 2011
We have power to the system but elements do not come on and heat water when you turn on water. there is 238 volts between all phases. System does not kick on when you turn water on
Control unit or flow transducer. If the transducer(impeller in the clear tube) is spinning freely with waterflow, then the circuit board needs to be replaced.
Aug 05, 2013 | Bosch PowerStar AE125 AE125 Whole House...
I have a ruud ruudglas pacemaker electric hot water heater. model number pem52-2b. first person to ake show in the moring has hto water for about 5mins and then it turns luke warm . when you wati about 10...
sounds like thermostat but element can be checked with a multi-meter, turn power off at fuse panel, pull one wire of element put multimeter on both screws on element using continuity setting should show continuity or beep as most do if not its burned out and needs to be replaced
Dec 01, 2012 | Water Heaters
How do I test the heating elements on Bosch Powerstar AE125 with multimeter
Product manual shows electro-mechanical thermal cutout page 9 but offers no troubleshoot steps except to say that overheating is cause.
http://waterheatertimer.org/pdf/Bosch-AE115-AE125_manual.pdf
http://www.bosch-climate.us/files/201009211859150.EP-23_Removing_and_replacing_element_assembly.pdf
Test elements:
Remove both wires off element.
Set multimeter to read ohms.
Watt and volt rating appear on side of each element.
Ohm = Volts squared divided by wattage.
For example:
Assume 240Volt circuit (240 Volts squared = 57600)
Assume 9000 watt element > check side of element for rating.
So 57600 divided by 9000 watt element = 6.4 ohms
http://waterheatertimer.org/images/ohm-reading-for-emements.jpg
Have you de-limed this unit?
Is there a check valve causing closed system in the plumbing, that might also cause decreased water flow?
Are there reduced-flow faucets or clogged aerators?
What happens when suspect cut-out element is no longer connected? The unit should continue heating.
Sep 25, 2012 | Bosch PowerStar AE125 AE125 Whole House...
The thermal cutout pops on tank two after it shuts off. It boils then shuts off. It also turns off when taking a shower, producing cold water. I checked the ohm readings on the thermal cutout and the...
Question posted under Bosch tankless.
Question says 'tank'
Brand, model, and type heater unknown.
Elements mean electric.
'Thermal cutout pops when taking shower produces cold water' indicates tankless, since tank-type would maintain some hot water.
No error code might indicate tank-type.
Add a comment with type, brand and model number of heater for possible assistance.
Sep 24, 2012 | Bosch PowerStar AE125 AE125 Whole House...
HI i HAVE A rHEEM mODEL 11131507 SERIAL NO 2325549 MAN 16 nOV 2004 Rheemglas Electric Water Heater The water is never hot just luke warm very annoying Can you help please Wendy
You need to find and set at full its thermostat. Usually it is placed where its on light and power wire goes, open the screws and set thermostat on full position and close the screws again.
Jul 31, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Not sure if my first try worked so will try again. Bosch PowerStar AE125 Tankless Water Heater. Quit heating water. Water pressure and flow is good. Thermal Cut-outs are good - (not tripped) (Power at...
The easiest thing to do would be to call Bosch and just ask for a new heater for free. The other option is to call Bosch and have them send you all new elements. If there is power, there should be heat of some kind.
Sep 13, 2010 | Bosch PowerStar AE125 AE125 Whole House...
Water is no longer hot
A heating element is either good or bad and no inbetween. If your unit has two elements, then one of the elements is bad. If it is a single element unit then the thermostat has gone bad. Do a voltage check to see if you have power going to both elements and if you do then do a ohms test on the elements. They shoudl read 5 to 10 ohms. If one of them doens't, then you know it is bad. If by chance check the elements and everything is working, the only thing that can be left is that the dip tub has ruptured somewhere close to the top of the outlet. But I would put my money on a bad element.
Apr 07, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
New rheem water heater only gives about 5 minutes of luke warm water.checked the elements with ohm meter all ok.tstats ok.
Given that both elements are in working order, and the unit was filled before the elements were powered up. Here are a few other areas to troubleshoot.
Note: Electric water heaters contain high voltage, so care and safety must be employed when attempting any service or repair. Do not attempt any service, if you are not secure in your abilities.
Quality non-conductive gloves and eye protection should be worn.
First check that power is being supplied to each thermostat and then to the element when the thermostat is active. Make final temperature adjustments evenly, so as to not over work one element.
Next, check that trapped air is purged from the tank, by placing a catch pan under the TPRV (temperature and pressure relief valve) and quickly engaging it to see if air escapes, if it does then continue until only water is released.
Finally check to be sure that during installation, the cold water feed and the hot water supply lines were installed to their proper locations at top of tank.
Good luck...Let me know the results of your tests.
Feb 25, 2009 | Water Heaters
Water is lukewarm and the thermostat is set at maximum . I checked and only one of the element is getting power
It sounds like the element is burned out and needs to be replaced.
To do this the water supply to the tank needs to be turned off, as well as the power supply (Breakers) and the tank drained.
As a preventative measure replace them both while the tank in empty.
Note: do not power the unit until it is full of water and the tank is purged of all trapped air.
Good luck...
Aduz
Feb 21, 2009 | Bosch PowerStar AE125 AE125 Whole House...
PowerStar AE125 seems to have failed
You have a blown element. If you purchased the heater, call Bosch for technical assistance, and the unit should be under warranty. The grey matter your getting is the magnesium that the elements have in them.
Nov 12, 2008 | Bosch PowerStar AE125 AE125 Whole House...
Bosch PowerStar AE125 AE125 Whole House Electric Tankless Water Heater... Logo
172 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
