Question about Bissell 6594 PowerForce Bagless Upright Vacuum
How to disassemble the brush to empty anything that might be stuck inside of the brush? The motor seems to be overheating, all belts have been checked, all airways are clear and the filter is clean. The vacuum is vibrating and releasing a burning smell, but still sucking up dirt. There is nothing stuck on the outside of the brush, but is there a way to check inside of it to see if that is where a clog is occuring?
  • 694 Answers
If there's a burning smell and the belts are fine, the problem is going to be hot wires causing the insulation to melt, or the motor going bad. Discontinue use and have it checked at a repair shop.
Posted on Apr 11, 2011
I replaced the belt but as soon as I start the vacuum I smell burning and the belt is broken?
The brush roller is clogged with debris and unable to rotate. Because of this, the new belt was unable to move and the motor shaft spun in one place until it burned through. The brush roller has to be removed and disassembled to allow the end caps to be cleaned inside.
Dec 26, 2016 | Vacuums
My dyson dc24 brush bar will not turn and there is a very loud screaming noise coming from the Hoover
Something has jammed the brush roller and the screaming sound is the motor shaft trying to move the stuck drive belt. The vacuum will have to be disassembled to find and remove the jamming material.
Oct 23, 2016 | Dyson Vacuums
The brush motor seems to be jammed with hair, I can't figure out how to clean it out. Can it be disassembled and cleaned?
depends onn make and model of vacuum. Most brushes are belt driven and not linked to a motor. For hair around the brush bristles carefully cut along the length of the brush roller taking care not to cut any of the bristles, then pull them off. Some makes have a releasable base to make this easier, these have several large plastic screws that turn with a coin. Hope this helps
Aug 03, 2016 | Vacuums
The brushes don't appear to be spinning...it looks like the belt falls off, though it's not broken. Also, the motor reves down to what seems to be very slow speed if it's been on for more than a few...
The brush roller may be clogged on the ends, causing the belt to stretch and fall off. If you remove the brush roller and check for free rotation of the ends you may have to disassemble it to remove hair and/or other debris.
Mar 03, 2014 | Shark Navigator Bagless Upright Vacuum
Sweeper brushes not rotating
I would say that your drive belt has broke or your brush roller bearing have stuck
Dec 11, 2011 | Vacuums
The vacuum is making a noise like something is stuck when it is in the carpet position but not when in the floor position. I can't find anything that is stuck in the areas that I can see. I have cleaned...
As far as the roller brush goes, yes, it does need to be cleaned. Follow the directions to remove it and clean as best you can of all debris. On both ends of the roller brush there will be two "holders" of sort that connect the brush to the frame of the vacuum. These need to be able to turn freely around the brush. Clean them as best you can and spray some WD40 in between the roller and both the holders. Work the holders around by hand to be sure they move freely. I would also check to see if your belts are snug.
Please let me know if this does not help solve your problems. Paul
Sep 19, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Caught rug, motor overheated, the brush wont turn at all, but suction is still there ...is there something I can do to reset it?
Assume that the belt is broken to the power brush /head. Did you happen to smell burning rubber at all when the motor got stuck? The motor may have a reset on it, if it was not operating, but that is not the case, as mentioned. Look in your manual for replacing power head/brushes belt! WalMart sells most types or your local vacuum repair facility.. check the Yellow pages and let your fingers do the walking.. Good luck
Apr 30, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
My brush will not turn, and the brush control is stuck on "off"
I have had problems with the belts on my Mach 5 overheating (smell of burning rubber) and also with the motor overheating and shutting down.
I learned the hard way that one of the issues might be that the roller/brush on the bottom of the unit has a metal bearing inside the roller/brush that can become clogged with hair (both human and pet hair) which effects performance of the unit.
It’s fairly easy to fix.
Lay the vacuum on the floor so that you can see the roller/brush. Then remove the phillip head screws that hold the protective plastic plate over the roller/brush. (There are about 6 screws that hold this plastic protective plate in place) Also, you will be removing the (1) screw that also holds the plastic plate over the belts. There are (2) belts that you can remove and when in doubt replace these (2) belts for around $9.00.
Once you have the protective plastic plate off that covers the roller/brush disconnect the belt is around the roller. Take the roller and cut off any hair that is wrapped around the roller. Next, grab the roller by each end and twist the ends caps and (1) of the ends will unscrew. Once you have unscrewed one of the ends remove any hair or dust that is trapped under this cap. (Be careful not to lose the small metal washer that sit on top of the bearing)You will notice under this cap is a metal bearing that can become clogged and jammed with hair. The hair should come out fairly easy and allow the brush to spin fairly easy once you have screwed the end caps back in place test that it spins freely. If it doesn’t spin freely replace the roller/brush with a new one for about $23.00.
When you put the belts back on the thick rubber one (Belt # 40201-271) has probably become stretched and should be replaced for about $3.00. The small diameter belt that goes over the roller/brush probably does not usually need to be replaced and does not usually fit very tight. I have heard that people will take the small roller/brush belt and turn it upside down to get a better fit.
I just did this on my Mach 5 and it runs like a new machine. I did end up replacing the roller/brush head.
Hopefully you will find this useful.
Jul 05, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Brushes not turning Electrolux Intensity (EL5020)
it needs a new brush they get stripped out by hair and stuff
Nov 20, 2008 | Electrolux EL5020 Vacuum
Bissell 6594 PowerForce Bagless Upright Vacuum Logo
99 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
