Question about Garden
I have a Murray riding lawn mower that was made in 2004 (model # 425620X92A) that either clicks or turns over a little but won't start. I thought is was the ignition switch and replaced it, I had the starter checked and they said it is okay. It pulls 20 to 30 amps while it is trying to start and I have also replaced the battery. Can you help me by suggesting what the problem might be.
  • 44 Answers
Does sound like the solenoid. If you are a brave sole, you can test this in the following manner.
Take a car jumper cable and jump the PLUS side of the battery to the starter PLUS terminal and, if the engine turns over, get a new solenoid.
I should caution you that it will throw a heck of a spark when you do this so be prepared. Connect the jumper cable to the PLUS side of the battery FIRST so you don't draw the spark over the battery. Also, if your engine has seized up, this will draw max current from your battery which is not a good thing so use your own judgement on this.
Do this at your own risk and, If you are not sure you want to try it, probably best to just get a new solenoid as you are probably going to need it someday anyway.
Posted on Jun 01, 2011
I had the same type of problem with my 36" Murray with an 11HP Briggs and Straton. I think I have solved it now. The positive lead from the battery had some corrosion on it so did not seem to be working reliably. I made up a solution of baking powder and and warm water and used an old toothbrush to clean it up. Also disconnected and reconnected most other electrical leads and it then started working.
Posted on May 30, 2011
  • 608 Answers
Most likely the starter solenoid regards Phil
Posted on Apr 11, 2011
I am looking for a parts and repair manual for a 2004 model #385016X78A Murray ride on mower.
Murray went out of business and was bought out by new outfit. Do not know if new Murray (kept the name) manufacturer will support the older products produced previously. You can always check and cross your fingers.
Sep 29, 2016 | Murray Garden
I need a deck belt for my Murray riding lawn mower model number is 13an772s058
If you still have the old belt, even if it is broken. Taje it to your local lawn and garden center that sells parts and service on riding mowers. Have them measure the belt length and width. If the belt is missing, have them look up belt for the model number of the mower you have.
Oct 13, 2015 | Murray Garden
Lawn trc murray 17.5 hp 42in cut
my specialty,but,you didnt post what the problem is,so,here goes,if it wont start,it is probably a bad safety switch,take the small black wire off of the coil,if it starts,then its a safety switch,if it doesnt then it is the coil,if it only clicks with a charged battery,it is the solenoid,turn on your key and short between the two big bolts on it if it starts it is bad,if you need a belt,i will need the numbers under the seat,otherwise i will try to find them for you,i will post a user manual for you here, Murray 425607x52A 42 34 Lawn Tractor Parts
Murray 425016x48A 42 34 Lawn Tractor Parts
Murray 425306x48A 42 34 Lawn Tractor Parts
Murray 425600x48A 42 34 Lawn Tractor Parts
Murray 425618x48A 42 34 Lawn Tractor Parts
Murray 42560x52A 2000 42 34 Lawn Tractor Parts
Murray 42820x24A 1996 42 Inch Cut Lawn Tractor Parts
Murray 425619x24A 42 34 Lawn Tractor Parts
a few manuals,find yours here or go here to find it by the numbers under the seat,all part numbers are in them, Search eReplacementParts com
Apr 24, 2015 | Murray Garden
I am looking for an owners manual for 425000X8 Murray riding lawn mower
andrew?so you need a manual for 425000x8A this is a 2003 model I found this manual for free at murray.lawnmowerguides.com/murray-lawn-mower-manual.html when you see your model number on your mower it look like this 425000x8 the A tell you the year it was made the 2004 model is 425000x8B BOTH MOWERS LOOKS THE SAME AND THEY HAVE THE SAME FRONT GRILLE.
Sep 17, 2011 | Briggs & Stratton Garden
Need diagram to replace murray 42 inch cut belt
http://www.ereplacementparts.com/ type in model number of your mower ie 40560x50c All parts and diags ypu need ,Yours Henry
Aug 07, 2010 | Murray 38 Lawn Mower Blade Belt '90'96...
The mower deck drive belt slipped off the idler pulley on my 42'' Murray riding mower deck because the idler pulley was worn out. I need to know how to loop the belt back around the pulleys after I replace...
Get the model number off the tractor, go to:
www.murray.com
enter the model number and you will find a manual with pictures of how to route the belts along with a lot of other good information
Sep 30, 2009 | Garden
Model 40601B riding lawn mower-need tension pulley spring
Your owner's manual has a parts breakdown with all parts listed. Find the part # and order from local Sears store. No manual? Try the Murray website (www.Murray.com) and download the manual for model 425001x8D lawn tractor. Good luck!
Sep 15, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Deck belt diagram
Go to ... http://www.partstree.com/parts/ Then click on Cub Cadet, enter the model number on the left that is under the seat and all the different diagrams are there. Click on Mower Deck.
Jun 29, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
292 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
