Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston Data Traveller DT101 16 GB. Plug it in, no LED flicker as it usually had. PC assigns a drive letter as removable disk. Clicking drive letter results in "please insert disk". Second Data Traveller DT101 16 GB works fine. Tested across three Windows XP machines, one Vista home premium and one Windows 7 home premium pc. Drives are identical, purchased at the same time, and failed drive worked fine up until now. At last use, it was left in a pc as it was being shut down. Not a driver issue (other drive works fine). Not a connector problem on the mother board (all other drives work fine). Would like to recover files rather than simply reformat the dirve. Any odeas?
  • Kingston Master
  • 27,725 Answers
Click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options update driver disable uninstall scan for hardware changes
select properties you should see options in the general tab to troubleshoot policies volumes driver and details under the driver tab you will have the options to check the driver details update driver rollback driver or uninstall
hope this helps
Posted on Apr 11, 2011
The parameter is incorrect
yes the one posted in have really helped me out. as I was not sure of retrieving my datas. problems started with encryption and later the word related to parameter. I got really scared. but changing the name of mi drive without formatting it. and then later running chkdsk. I could break into my drive, to get it all. thanks alott
Jul 13, 2012 | Seagate Freeagent Goflex 500 GB USB 2.0...
How to format data traveler. its says write proteted
With the device connected ...
Click Start
Click Run
Type CMD
Press Enter
Type CHDSK /F m:
where 'm' is the drive-letter assigned to the Kingston.
Press Enter
After the "check-disk" completes, Windows should remove the "read-only" flag.
Nov 18, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I've a kingston flash drive of 4 GB when I try to copy sth or format the drive it gives the message "Media is Write Protected" Pls help me to fix this prob....
Click Start
Click Run
Type CMD
Press Enter
Type CHKDSK /F m:
When the "check-disk" completes, Windows will remove the "read-only" flag.
I HAVE A 4 GB KINGSTONE DATA TRAVELER SAY WRITE PROTECTED HOW CAN I FORMAT IT CAUSE WHEN I FORMAT IT DIRECTLY IT SAY DEVICE IS WRITE PROTECTED BUT MY USB DEVICE DOES NOT HAVE THAT KIND OF SPECIFICATION TO...
Click Start
Click Run
Type CMD
Press Enter
Type CHKDSK q: /F
where 'q:' is the drive-letter assigned by Windows to your Kingston.
Press Enter.
When "check-disk" has completed, Windows will remote the "write-protect".
Nov 13, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How can I retreive my files from a kingston 4GB DataTraveler
plug the 4kg data traveller it into a USB port open windows explorer open the data traveller select the files copy and paste into my documents on your computer
hope this helps
Aug 08, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
HOE TO FORMAT DATE TRAVELER
The simplest way to format a Flash Drive or a Pendrive is to format it from the My Computer without using any commands. Let's assume you are doing it on a Computer (Pc Desktop). Follow the instructions;
1. Connect you Data Traveler on one of the Usb port of your computer, and wait for few minutes.
2. After you know that it's been detected by the computer, open "My Computer" then right-click on the Data Traveler's Drive Icon e.g. Removable Disk (K:), etc.. and select "Format"
3. When the format dialog box is opened, click "Start" and then you'll be prompted with a warning message to confirm the proceed, click "Ok" to proceed. Formatting Dialog box bf3d566.jpg
Format Warning Message
4. Wait for few seconds and you'll get another message that the drive has been successfully formatted.
If you have problem, please let me know. Good luck.
Thanks for using FixYa.
Jul 09, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have lock my Kingston from imation lock.
you can try formatting it from the disk manager.
plug in the flash drive and remember what drive letter it gets assigned. right-click 'my computer' and choose manage from the drop-down menu. in the following window, click on disk management (under storage) on the left, then right-click on the flash drive and choose format...
Jun 22, 2009 | Kingston Technologies 512MB DataTraveler I...
I don't know how to save to the kingston 4GB USB2.0 data travelter - no instructions with it
You just plug it into a USB port and your computer will automatically detect it.
Please rate this solution and thanks for using FixYa
Jan 06, 2009 | Computers & Internet
I hav i/o error problem when i open my pen drive it is written i/o error it is not format
i have 2 GB kingston data traveller and other 64GB data traveller but i m fail to remove the loaded files and software please tell me how can i format my data traveller and which software can do this (without any cost).
mahiender kumar rr
Dec 27, 2008 | Electronics - Others
My DT100/4gb data traveller (kingston) pen drive is not working.
when i duble click on my pendrive icon it shows please insert a new disk. and it even doesnt open up
Oct 29, 2008 | Transcend (589307) Media
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
375 people viewed this question
Top Kingston Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
